* | The files in libcpu should not be directly dependent on any BSP. In | Joel Sherrill | 1999-11-04 | 1 | -1/+0 | |
| | | | | | | | | | | | particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated. | |||||
* | Split Heap and Time of Day Handlers. | Joel Sherrill | 1999-11-02 | 2 | -0/+129 | |
* | Added comment to make sure Classic API priority to Core priority | Joel Sherrill | 1999-11-02 | 1 | -0/+1 | |
| | | | | is added in the future. | |||||
* | Added comments for _RTEMS_tasks_Create_extension, | Joel Sherrill | 1999-11-02 | 1 | -4/+9 | |
| | | | | | _RTEMS_tasks_Start_extension, _RTEMS_tasks_Delete_extension, and _RTEMS_tasks_Switch_extension. | |||||
* | Added a case to support the core semaphore error returned when the | Joel Sherrill | 1999-11-02 | 1 | -0/+8 | |
| | | | | maximum semaphore count is exceeded. | |||||
* | Added code to utilize the maximum_count attribute of core semaphores | Joel Sherrill | 1999-11-02 | 1 | -0/+7 | |
| | | | | | and initialize it to a value that would keep it from every being a problem. | |||||
* | Removed warning. | Joel Sherrill | 1999-10-21 | 1 | -0/+2 | |
* | Added rtems_semaphore_flush directive. | Joel Sherrill | 1999-10-21 | 2 | -0/+104 | |
* | Added prototype for rtems_task_is_suspended at request of | Joel Sherrill | 1999-10-20 | 1 | -1/+12 | |
| | | | | Eric Norum. | |||||
* | New directive added -- rtems_task_is_suspended. | Joel Sherrill | 1999-10-07 | 1 | -0/+76 | |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bug | Joel Sherrill | 1999-10-04 | 4 | -12/+12 | |
| | | | | where wrapup left pieces out of the librtemsall.a. | |||||
* | Applied patch rtems-rc-19990820-6.diff.gz from | Joel Sherrill | 1999-09-07 | 4 | -0/+57 | |
| | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> which converted many Makefile.in's to Makefile.am's. This added a lot of files. | |||||
* | Removed definition of NO_IMPLICIT_EXTERN_C since it is supposed to be | Joel Sherrill | 1999-08-30 | 1 | -2/+0 | |
| | | | | in the compiler not in the header file. | |||||
* | Added NO_IMPLICIT_EXTERN_C at suggestion of Jason Merrill. | Joel Sherrill | 1999-08-10 | 1 | -0/+2 | |
* | Modified to return an error when a bogus return address for the | Joel Sherrill | 1999-06-09 | 1 | -0/+3 | |
| | | | | old_priority parameter is provided. | |||||
* | Corrected macro names. | Joel Sherrill | 1999-05-27 | 1 | -2/+6 | |
* | Fixed some typos. | Joel Sherrill | 1999-05-17 | 1 | -4/+4 | |
* | Split Interrupt Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 2 | -36/+55 | |
* | Split Signal Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 3 | -108/+154 | |
* | Dual-Ported Memory Manager split into one routine per file. | Joel Sherrill | 1999-05-17 | 6 | -236/+346 | |
* | Split Partition Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 6 | -299/+414 | |
* | Split Timer Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 8 | -308/+469 | |
* | Split Event Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 6 | -342/+456 | |
* | Split Rate Monotonic Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 8 | -416/+568 | |
* | Split the Semaphore Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 7 | -484/+766 | |
* | Moved some MP routines to semmp.c. | Joel Sherrill | 1999-05-17 | 2 | -55/+54 | |
* | Forgot to actually remove the routines. :) | Joel Sherrill | 1999-05-17 | 1 | -748/+0 | |
* | Split Message Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 12 | -0/+1105 | |
* | Moved an MP routine from msg.c to here. | Joel Sherrill | 1999-05-17 | 1 | -0/+26 | |
* | Cleaned up some multiprocessing issues. | Joel Sherrill | 1999-05-17 | 1 | -17/+15 | |
* | Split Clock Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 4 | -129/+194 | |
* | Split Region Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 8 | -455/+618 | |
* | Split Task Manager into multiple files. Eventually this effort will | Joel Sherrill | 1999-05-17 | 15 | -961/+1381 | |
| | | | | reduce the size of executables. | |||||
* | Patch from D. V. Henkel-Wallace <gumby@zembu.com>: | Joel Sherrill | 1999-05-17 | 1 | -0/+16 | |
| | | | | | | Here's a tiny patch that shreds memory returned to the pool (such as by free() and delete). This may help people find some nasty bugs, so here it is. | |||||
* | Made all calls to _Thread_Yield_processor consistent in how they are | Joel Sherrill | 1999-05-07 | 1 | -7/+6 | |
| | | | | wrapped by calls to _Thread_Enable_dispatch and _Thread_Disable_dispatch. | |||||
* | Unlimited objects patch from Chris Johns <ccj@acm.org>. Email follows: | Joel Sherrill | 1999-03-17 | 1 | -15/+17 | |
| | | | | | | | | | | | | | | | | | | | | | | | | | First, the unlimited patch. I have compiled the unlmited patch for the Linux posix BSP only and it seems to work cleanly. I would like a really major application run on this change before commiting as the changes are very core and significant. I am currently building all the tests to run. I have no targets suitable to test on at the moment. I have tested the patch for inline functions and macros. Turning macros on has found some core bugs. I have fixed these but have not run all the tests. Please review the patch for these changes. They are: 1) The conditional compilation for MP support broke the core messages code. You cannot embed a conditional macro in another macro. The Send and Urgent Send calls are macros. 2) User extensions handler initialisation now has two parameters. I have updated the macros to support the extra parameter. The patch also contains the gcc-target-default.cfg fix required to build the kernel. More of a by product than a fix for you. | |||||
* | Comments fixed after problem report from Ian Lance Taylor <ian@airs.com>. | Joel Sherrill | 1999-02-10 | 1 | -19/+10 | |
* | Corrected ifdef on RTEMS_MULTIPROCESSING so the queue is actually closed. | Joel Sherrill | 1998-12-03 | 1 | -2/+4 | |
* | Added --disable-multiprocessing flag and modified a lot of files to make | Joel Sherrill | 1998-11-23 | 21 | -103/+367 | |
| | | | | it work. | |||||
* | Added __RTEMS_INSIDE__ macro to insure that ".inl" files are ALWAYS included | Joel Sherrill | 1998-08-24 | 1 | -1/+1 | |
| | | | | when building the executive source. | |||||
* | Added system task attribute to allow one to create a task with "0" priority | Joel Sherrill | 1998-08-21 | 4 | -9/+40 | |
| | | | | via the user api. | |||||
* | All task delete API level services were incorrectly assuming that the | Joel Sherrill | 1998-06-18 | 1 | -1/+10 | |
| | | | | | | | | | | | task to be deleted was created via the same API (i.e. were of the object class created by this API). For example, a POSIX thread calling the rtems_task_delete(SELF) directive would incorrectly update the RTEMS object local pointer table. Jennifer discovered this when moving tests implemented in C using the Classic RTEMS API into a tree of Ada tests. The Ada tests were implicitly using POSIX services. This lead to some unexpected behavior. | |||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 85 | -85/+85 | |
* | Added check that return argument pointer for old_isr_handler was valid. | Joel Sherrill | 1997-10-21 | 1 | -0/+3 | |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 85 | -170/+170 | |
* | Make Post an atomic operation. | Joel Sherrill | 1997-10-06 | 2 | -2/+12 | |
* | Added RTEMS_IO_ERROR status code. | Joel Sherrill | 1997-08-28 | 1 | -1/+2 | |
* | Added these files to contain bodies for routines included in the API | Joel Sherrill | 1997-08-02 | 2 | -0/+101 | |
| | | | | | but which did not have real bodies. This is necessary for languages like Ada95 which must have real entries in a library for bindings. | |||||
* | Added rtems_message_queue_get_number_pending directive. | Joel Sherrill | 1997-07-31 | 4 | -17/+107 | |
* | fixed typo | Joel Sherrill | 1997-07-18 | 1 | -4/+4 | |
