2012-11-05 | rtems: Transient event documentation | Sebastian Huber | 1 | -6/+6 | |
2012-11-02 | libnetworking: Use system events | Sebastian Huber | 1 | -0/+10 | |
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP. Add and use rtems_bsdnet_event_send(). | |||||
2012-11-02 | rtems: Use event 31 for the transient event | Sebastian Huber | 1 | -1/+1 | |
This avoids conflicts with the netisr events of the network stack. | |||||
2012-10-31 | rtems: Use correct sync state for system events | Sebastian Huber | 3 | -29/+12 | |
2012-10-30 | rtems: Add system events | Sebastian Huber | 7 | -0/+343 | |
System events are similar to normal events. They offer a second set of events. These events are intended for internal RTEMS use and should not be used by applications (with the exception of the transient system event). | |||||
2012-10-30 | rtems: Reusable event implementation | Sebastian Huber | 9 | -218/+140 | |
Change event implementation to enable reuse for system events. | |||||
2012-10-30 | rtems: Remove unused event_condition member | Sebastian Huber | 2 | -3/+0 | |
2012-10-25 | score: Change _Heap_Extend() API | Sebastian Huber | 1 | -4/+3 | |
The _Heap_Extend() has now the same signature as _Heap_Initialize(). The 4th parameter is ignored (page size in _Heap_Initialize()). Add Heap_Area and Heap_Initialization_or_extend_handler. Add and test _Heap_No_extend(). This helps to do a table based heap initialization and extension. Create a table of Heap_Area elements and iterate through it. Set the handler to _Heap_Initialize() in the first iteration and then to _Heap_Extend(). | |||||
2012-10-08 | rtems: PR1844: Fix MP process packet size | Sebastian Huber | 1 | -2/+2 | |
2012-07-17 | score: Change greedy allocation API | Sebastian Huber | 2 | -5/+12 | |
2012-06-14 | score: New structure TOD_Control | Sebastian Huber | 6 | -6/+6 | |
Group the global TOD variables (_TOD_Now, _TOD_Uptime, and _TOD_Is_set) in a structure to reduce address loads in _TOD_Tickle_ticks(). | |||||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 210 | -422/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2012-05-09 | Score ISR - Minimize Capabilities When Not Simple Vectored | Joel Sherrill | 1 | -2/+6 | |
In particular CPU_INTERRUPT_NUMBER_OF_VECTORS and CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER are only used on Simple Vectored Architectures, so do not depend on them being defined. This disables as much as possible that is specific to the Simple Vectored Model and not expected to be used on architectures which use the Programmable Interrupt Controller model for interrupt handler vectoring. | |||||
2012-05-07 | Revert: Remove CVS Ids | Joel Sherrill | 1 | -0/+4 | |
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | |||||
2012-05-04 | Remove CVS-Ids. | Ralf Corsépius | 1 | -4/+0 | |
2012-04-20 | score: Fix comment | Sebastian Huber | 1 | -1/+2 | |
2012-02-17 | Add functions for greedy workspace allocation | Sebastian Huber | 3 | -0/+57 | |
Various tests must check program paths that result due to failed memory allocations from the workspace. To avoid tinkering with internal workspace structures throughout the test code these functions should be used. | |||||
2012-02-02 | PR 1991/cpukit - attr.c (really mode code) warning rework | Joel Sherrill | 3 | -8/+33 | |
This PR was about a warning for no previous prototype for rtems_interrupt_level_attribute. This method exists (like a few others) to have real bodies for Classic API services implemented as macros. These macros are not available from anything but C and C++. The most explicit use was in the Ada binding but these would be needed from assembly language or any other non-C based language. On top of needing a prototype, the methods were misnamed. They were related to modes. This renames them, moves the file, fixes test code, etc. | |||||
2012-02-01 | Remove all .cvsignore files. | Joel Sherrill | 1 | -2/+0 | |
2011-12-10 | 2011-12-10 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+6 | |
PR 1986/libcpu * rtems/include/rtems/rtems/cache.h: Add rtems_cache_aligned_malloc decl. | |||||
2011-12-09 | 2011-12-09 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+1 | |
* rtems/src/rtemsobjectsetname.c: Include <rtems/rtems/object.h> (Missing prototype). | |||||
* rtems/src/rtemsobjectgetclassicname.c: Include <rtems/rtems/object.h> (Missing prototype). | |||||
2011-12-08 | 2011-12-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+1 | |
* rtems/src/rtemsobjectgetname.c: Include <rtems/rtems/object.h> (Missing prototype). | |||||
2011-12-07 | 2011-12-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+3 | |
* rtems/src/rtemsobjectapiminimumclass.c: Include <rtems/rtems/object.h> (Missing prototype). Adjust rtems_object_api_minimum_class to prototype. | |||||
* rtems/src/workspace.c: Include <rtems/rtems/support.h> (Missing prototypes). | |||||
2011-12-06 | 2011-12-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* rtems/src/ratemonperiod.c: Make _Rate_monotonic_Update_statistics static. | |||||
2011-12-05 | 2011-12-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+1 | |
* rtems/src/rtemsobjectapimaximumclass.c: Include <rtems/rtems/object.h> (Missing prototypes). * sapi/src/exshutdown.c: Include <rtems/init.h> (Missing prototypes). | |||||
2011-12-05 | 2011-12-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+13 | |
* posix/include/rtems/posix/pthread.h: Add _POSIX_Threads_Initialize_user_threads_body. * rtems/include/rtems/rtems/tasks.h: Add _RTEMS_tasks_Initialize_user_tasks_body. * sapi/include/confdefs.h: Remove conditional, nested redeclaration of _POSIX_Threads_Initialize_user_threads_body, _RTEMS_tasks_Initialize_user_tasks_body. | |||||
2011-12-05 | 2011-12-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* rtems/src/tasks.c: Fix typos. | |||||
* rtems/src/taskinitusers.c: Fix typos. | |||||
2011-12-05 | 2011-12-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
* rtems/include/rtems/rtems/tasks.h: Typo fixes. | |||||
2011-12-02 | 2011-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -5/+5 | |
* rtems/src/tasks.c: Make _RTEMS_tasks_Create_extension, _RTEMS_tasks_Start_extension, _RTEMS_tasks_Delete_extension, _RTEMS_tasks_Switch_extension, _RTEMS_tasks_Post_switch_extension static. * score/src/scheduleredf.c: Make _Scheduler_EDF_RBTree_compare_function static. | |||||
2011-11-10 | 2011-11-10 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 1 | -4/+4 | |
* rtems/include/rtems/rtems/event.h: Revert parameter name change. | |||||
2011-11-10 | 2011-11-10 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 3 | -86/+219 | |
* rtems/include/rtems/rtems/event.h, rtems/include/rtems/rtems/eventset.h, rtems/inline/rtems/rtems/eventset.inl: Documentation. | |||||
2011-10-25 | 2011-10-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 3 | -16/+32 | |
* rtems/Makefile.am: Add src/status.c. * rtems/include/rtems/rtems/status.h: Make _Status_Object_name_errors_to_status an external variable. * rtems/src/status.c: New (split out from rtems/include/rtems/rtems/status.h). | |||||
2011-10-25 | 2011-10-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -56/+153 | |
* rtems/Makefile.am: Reformat. | |||||
2011-10-19 | 2011-10-18 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 1 | -4/+3 | |
PR 1939/cpukit * rtems/src/ratemonperiod.c: Fixed type mismatch. | |||||
2011-09-29 | 2011-09-29 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2 | -10/+21 | |
* score/include/rtems/score/tod.h: Declare _TOD_Set_with_timestamp() and _TOD_Get_as_timestamp(). * score/src/coretodset.c: Define _TOD_Set_with_timestamp(). * score/src/coretodget.c: Define _TOD_Get_as_timestamp(). * rtems/src/clockset.c: Use _TOD_Set_with_timestamp(). * score/include/rtems/score/timestamp64.h, score/src/ts64set.c: Changed parameter types of _Timestamp64_Set(). * rtems/src/clocktodtoseconds.c: Year 2100 is not a leap year. | |||||
2011-09-28 | 2011-09-28 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2 | -2/+2 | |
* rtems/include/rtems/rtems/clock.h, rtems/src/clockset.c: Added const qualifier in rtems_clock_set(). | |||||
2011-09-20 | 2011-09-20 Petr Benes <benesp16@fel.cvut.cz> | Joel Sherrill | 1 | -1/+1 | |
PR 1916/testing * rtems/src/ratemondelete.c, score/src/schedulercbsreleasejob.c, score/src/scheduleredfupdate.c, score/src/scheduleredfyield.c: Rework to improve coverage. | |||||
2011-09-09 | 2011-09-09 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 3 | -8/+8 | |
PR 1844/cpukit * rtems/include/rtems/rtems/msgmp.h: Define MESSAGE_QUEUE_MP_PACKET_SIZE. * rtems/src/msgmp.c, rtems/src/msgqcreate.c: Use MESSAGE_QUEUE_MP_PACKET_SIZE. | |||||
2011-09-09 | 2011-09-09 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 7 | -0/+38 | |
* score/include/rtems/score/basedefs.h: Typo. * score/src/mpci.c, rtems/src/eventmp.c, rtems/src/msgmp.c, rtems/src/partmp.c, rtems/src/regionmp.c, rtems/src/semmp.c, rtems/src/signalmp.c, rtems/src/taskmp.c: Use RTEMS_STATIC_ASSERT() to ensure that the packet size is small enough. | |||||
2011-09-01 | 2011-09-01 Petr Benes <benesp16@fel.cvut.cz> | Joel Sherrill | 3 | -2/+7 | |
PR 1895/cpukit * rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c, rtems/src/ratemonperiod.c, sapi/include/confdefs.h, score/Makefile.am, score/include/rtems/score/scheduler.h, score/include/rtems/score/schedulerpriority.h, score/include/rtems/score/schedulersimple.h, score/include/rtems/score/schedulersimplesmp.h, score/inline/rtems/score/scheduler.inl, score/inline/rtems/score/schedulerpriority.inl, score/src/coremutexseize.c: Add priority_compare and release_job hooks interfaces to scheduler interface. * score/src/schedulerpriorityprioritycompare.c, score/src/schedulerpriorityreleasejob.c: New files. | |||||
2011-08-29 | 2011-08-29 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 1 | -4/+5 | |
* rtems/include/rtems/rtems/tasks.h: Formatting. | |||||
2011-07-24 | 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 103 | -312/+156 | |
* ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script. | |||||
2011-07-19 | 2011-07-19 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 1 | -1/+4 | |
* rtems/src/msgqcreate.c: Make packet size check consistent with _Message_queue_MP_Send_request_packet(). | |||||
2011-07-18 | 2011-07-18 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 1 | -1/+0 | |
* rtems/src/msgmp.c: Getting a remote object does not start a critical section. | |||||
2011-06-28 | 2011-06-28 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 4 | -0/+95 | |
PR 1826/cpukit * libmisc/cpuuse/cpuusagereport.c, rtems/Makefile.am, rtems/preinstall.am, rtems/include/rtems.h: Add SMP Helper methods to Classic API. * rtems/include/rtems/rtems/smp.h: New file. | |||||
2011-06-24 | 2011-06-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 7 | -15/+26 | |
* include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h, include/rtems/pci.h, include/rtems/userenv.h, libblock/include/rtems/flashdisk.h, libblock/include/rtems/nvdisk-sram.h, libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h, libcsupport/include/console.h, libcsupport/include/iosupp.h, libcsupport/include/spurious.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h, libcsupport/include/rtems/framebuffer.h, libcsupport/include/rtems/gxx_wrappers.h, libcsupport/include/rtems/libcsupport.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/malloc.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h, libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h, libmisc/capture/capture-cli.h, libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h, libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h, libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h, libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h, libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h, posix/include/mqueue.h, posix/include/semaphore.h, posix/include/rtems/posix/aio_misc.h, posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/posixapi.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/ptimer.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/sigset.h, posix/include/rtems/posix/spinlock.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/time.h, posix/include/rtems/posix/timer.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/priority.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/spinlock.inl, posix/inline/rtems/posix/timer.inl, rtems/mainpage.h, rtems/include/rtems/rtems/barrier.h, rtems/include/rtems/rtems/object.h, rtems/include/rtems/rtems/timer.h, rtems/inline/rtems/rtems/barrier.inl, rtems/inline/rtems/rtems/timer.inl, rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h, sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h, score/include/rtems/score/object.h, score/include/rtems/score/priority.h, score/inline/rtems/score/object.inl, score/inline/rtems/score/priority.inl: Add @file Doxygen directives and descriptions to files which originated with RTEMS. This improves the file list page generated by Doxygen. | |||||
2011-06-17 | 2011-06-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -1/+3 | |
* rtems/include/rtems/rtems/tasks.h: Complete manager description. |
