1999-10-04 | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bug | Joel Sherrill | 4 | -12/+12 | |
where wrapup left pieces out of the librtemsall.a. | |||||
1999-09-07 | Applied patch rtems-rc-19990820-6.diff.gz from | Joel Sherrill | 4 | -0/+57 | |
Ralf Corsepius <corsepiu@faw.uni-ulm.de> which converted many Makefile.in's to Makefile.am's. This added a lot of files. | |||||
1999-08-30 | Removed definition of NO_IMPLICIT_EXTERN_C since it is supposed to be | Joel Sherrill | 1 | -2/+0 | |
in the compiler not in the header file. | |||||
1999-08-10 | Added NO_IMPLICIT_EXTERN_C at suggestion of Jason Merrill. | Joel Sherrill | 1 | -0/+2 | |
1999-06-09 | Modified to return an error when a bogus return address for the | Joel Sherrill | 1 | -0/+3 | |
old_priority parameter is provided. | |||||
1999-05-27 | Corrected macro names. | Joel Sherrill | 1 | -2/+6 | |
1999-05-17 | Fixed some typos. | Joel Sherrill | 1 | -4/+4 | |
1999-05-17 | Split Interrupt Manager into one routine per file. | Joel Sherrill | 2 | -36/+55 | |
1999-05-17 | Split Signal Manager into one routine per file. | Joel Sherrill | 3 | -108/+154 | |
1999-05-17 | Dual-Ported Memory Manager split into one routine per file. | Joel Sherrill | 6 | -236/+346 | |
1999-05-17 | Split Partition Manager into one routine per file. | Joel Sherrill | 6 | -299/+414 | |
1999-05-17 | Split Timer Manager into one routine per file. | Joel Sherrill | 8 | -308/+469 | |
1999-05-17 | Split Event Manager into one routine per file. | Joel Sherrill | 6 | -342/+456 | |
1999-05-17 | Split Rate Monotonic Manager into one routine per file. | Joel Sherrill | 8 | -416/+568 | |
1999-05-17 | Split the Semaphore Manager into one routine per file. | Joel Sherrill | 7 | -484/+766 | |
1999-05-17 | Moved some MP routines to semmp.c. | Joel Sherrill | 2 | -55/+54 | |
1999-05-17 | Forgot to actually remove the routines. :) | Joel Sherrill | 1 | -748/+0 | |
1999-05-17 | Split Message Manager into one routine per file. | Joel Sherrill | 12 | -0/+1105 | |
1999-05-17 | Moved an MP routine from msg.c to here. | Joel Sherrill | 1 | -0/+26 | |
1999-05-17 | Cleaned up some multiprocessing issues. | Joel Sherrill | 1 | -17/+15 | |
1999-05-17 | Split Clock Manager into one routine per file. | Joel Sherrill | 4 | -129/+194 | |
1999-05-17 | Split Region Manager into one routine per file. | Joel Sherrill | 8 | -455/+618 | |
1999-05-17 | Split Task Manager into multiple files. Eventually this effort will | Joel Sherrill | 15 | -961/+1381 | |
reduce the size of executables. | |||||
1999-05-17 | Patch from D. V. Henkel-Wallace <gumby@zembu.com>: | Joel Sherrill | 1 | -0/+16 | |
Here's a tiny patch that shreds memory returned to the pool (such as by free() and delete). This may help people find some nasty bugs, so here it is. | |||||
1999-05-07 | Made all calls to _Thread_Yield_processor consistent in how they are | Joel Sherrill | 1 | -7/+6 | |
wrapped by calls to _Thread_Enable_dispatch and _Thread_Disable_dispatch. | |||||
1999-03-17 | Unlimited objects patch from Chris Johns <ccj@acm.org>. Email follows: | Joel Sherrill | 1 | -15/+17 | |
First, the unlimited patch. I have compiled the unlmited patch for the Linux posix BSP only and it seems to work cleanly. I would like a really major application run on this change before commiting as the changes are very core and significant. I am currently building all the tests to run. I have no targets suitable to test on at the moment. I have tested the patch for inline functions and macros. Turning macros on has found some core bugs. I have fixed these but have not run all the tests. Please review the patch for these changes. They are: 1) The conditional compilation for MP support broke the core messages code. You cannot embed a conditional macro in another macro. The Send and Urgent Send calls are macros. 2) User extensions handler initialisation now has two parameters. I have updated the macros to support the extra parameter. The patch also contains the gcc-target-default.cfg fix required to build the kernel. More of a by product than a fix for you. | |||||
1999-02-10 | Comments fixed after problem report from Ian Lance Taylor <ian@airs.com>. | Joel Sherrill | 1 | -19/+10 | |
1998-12-03 | Corrected ifdef on RTEMS_MULTIPROCESSING so the queue is actually closed. | Joel Sherrill | 1 | -2/+4 | |
1998-11-23 | Added --disable-multiprocessing flag and modified a lot of files to make | Joel Sherrill | 21 | -103/+367 | |
it work. | |||||
1998-08-24 | Added __RTEMS_INSIDE__ macro to insure that ".inl" files are ALWAYS included | Joel Sherrill | 1 | -1/+1 | |
when building the executive source. | |||||
1998-08-21 | Added system task attribute to allow one to create a task with "0" priority | Joel Sherrill | 4 | -9/+40 | |
via the user api. | |||||
1998-06-18 | All task delete API level services were incorrectly assuming that the | Joel Sherrill | 1 | -1/+10 | |
task to be deleted was created via the same API (i.e. were of the object class created by this API). For example, a POSIX thread calling the rtems_task_delete(SELF) directive would incorrectly update the RTEMS object local pointer table. Jennifer discovered this when moving tests implemented in C using the Classic RTEMS API into a tree of Ada tests. The Ada tests were implicitly using POSIX services. This lead to some unexpected behavior. | |||||
1998-02-17 | updated copyright to 1998 | Joel Sherrill | 85 | -85/+85 | |
1997-10-21 | Added check that return argument pointer for old_isr_handler was valid. | Joel Sherrill | 1 | -0/+3 | |
1997-10-08 | Fixed typo in the pointer to the license terms. | Joel Sherrill | 85 | -170/+170 | |
1997-10-06 | Make Post an atomic operation. | Joel Sherrill | 2 | -2/+12 | |
1997-08-28 | Added RTEMS_IO_ERROR status code. | Joel Sherrill | 1 | -1/+2 | |
1997-08-02 | Added these files to contain bodies for routines included in the API | Joel Sherrill | 2 | -0/+101 | |
but which did not have real bodies. This is necessary for languages like Ada95 which must have real entries in a library for bindings. | |||||
1997-07-31 | Added rtems_message_queue_get_number_pending directive. | Joel Sherrill | 4 | -17/+107 | |
1997-07-18 | fixed typo | Joel Sherrill | 1 | -4/+4 | |
1997-07-09 | Corrected typos and spacing. | Joel Sherrill | 1 | -3/+3 | |
1997-05-28 | Added support for context switching the data used by the gcc m68k | Joel Sherrill | 1 | -1/+1 | |
software floating point emulation code. Code implemented by Karen Sara Looney <Karen.Looney@colorado.edu> with much email assistance from Joel. | |||||
1997-04-25 | Corrected by adding check for NULL address passed into get_status | Joel Sherrill | 1 | -0/+3 | |
directive. | |||||
1997-04-25 | Added to comment header block to include new status directive. | Joel Sherrill | 1 | -0/+1 | |
1997-04-22 | promote TOD_MICROSECONDS_TO_TICKS through API as RTEMS_MICROSECONDS_PER_TICK. | Joel Sherrill | 1 | -0/+2 | |
1997-04-22 | File changed to reflect change in license and copyright. | Joel Sherrill | 1 | -5/+5 | |
1997-04-22 | headers updated to reflect new style copyright notice as part | Joel Sherrill | 82 | -410/+410 | |
of switching to the modified GNU GPL. | |||||
1997-04-09 | added support for statistics on rate monotonic periods. | Joel Sherrill | 2 | -10/+110 | |
1997-03-08 | Modified calls to _Thread_Change_priority to take a third argument. The new | Joel Sherrill | 1 | -1/+1 | |
argument indicates whether the task is to be placed at the head or tail of its priority fifo when it is lowering its own priority. POSIX normally follows the RTEMS API conventions but GNAT expects that all lowering of a task's priority by the task itself will result in being placed at the head of the priority FIFO. Normally, this would only occur as the result of lose of inherited priority. The RTEMS API always puts tasks at the end of their priority group except upon loss of inherited priority. | |||||
1996-12-02 | Suggested changes from Mark Jordan which eliminate warnings and errors | Joel Sherrill | 7 | -14/+19 | |
he received using the Microtec C++ compiler. Most of these are either missing casts from/to (void *), heavy handed use of enumerated types, or simply assumed conversions. There is at least one actual bug in an error path in thread.c in which the wrong argument was passed to _Thread_Stack_Free and was not being caught by gcc. |
