are automatically activated upon insertion.
possible synchronization actions. This should have made it harder to
avoid a case.
like signal dispatching.
correct Information block.
+ Added name pointer to Object_Control.
+ Modified Object Open and Close to address name field.
+ Removed name as separate element from Thread and Proxy Control.
+ Added parameter "object class" to calls to Initialize Information
blocking mechanism for it.
