- Move the heap sbrk code into a separate routnine.
- Update heap and workspace greedy allocators to use the common
sbrk greedy support.
Closes #3982
Use common phrases for the file brief descriptions.
Update #3706.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Move implementation specific parts of heap.h and heap.inl into new
header file heapimpl.h. The heap.h contains now only the application
visible API.
Add rtems_workspace_greedy_allocate_all_except_largest() and
rtems_heap_greedy_allocate_all_except_largest().
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8025204
Various tests must check program paths that result due to failed memory
allocations from the workspace. To avoid tinkering with internal
workspace structures throughout the test code these functions should be
used.
