http://www.google-melange.com/gci/task/view/google/gci2012/7950206
* rtems/src/workspace.c:
Include <rtems/rtems/support.h> (Missing prototypes).
PR 1411/cpukit
* rtems/src/workspace.c, score/include/rtems/score/protectedheap.h,
score/src/pheapgetfreeinfo.c, score/src/pheapgetinfo.c: Improve
workspace wrapper methods.
* rtems/include/rtems/rtems/region.h,
rtems/include/rtems/rtems/support.h,
rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c,
rtems/src/workspace.c: Revert ssize_t patch.
* libcsupport/src/malloc_statistics_helpers.c,
libcsupport/src/realloc.c, rtems/include/rtems/rtems/region.h,
rtems/src/workspace.c, sapi/include/confdefs.h,
score/include/rtems/score/heap.h,
score/include/rtems/score/wkspace.h, score/src/heap.c,
score/src/heapallocate.c, score/src/heapallocatealigned.c,
score/src/heapextend.c, score/src/heapresizeblock.c,
score/src/heapsizeofuserarea.c, score/src/pheapgetblocksize.c,
score/src/wkspace.c: Change size_t to ssize_t on all Heap, Workspace
and Region calls. On 16-bit architectures, size_t can be 16-bits
which would limit sizes to 64K.
* rtems/Makefile.am, rtems/include/rtems/rtems/support.h: Added
workspace manipulation routines for testing.
* rtems/src/workspace.c: New file.
