This avoids having conditional statements to get the API-specific status
code.
Use common phrases for the file brief descriptions.
Update #3706.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Use Processor_mask instead.
Update #2514.
Uniformly use *_Get() to get an object by identifier with a lock
context.
Update #2555.
Clustered/partitioned scheduling helps to control the worst-case
latencies in the system. The goal is to reduce the amount of shared
state in the system and thus prevention of lock contention. Modern
multi-processor systems tend to have several layers of data and
instruction caches. With clustered/partitioned scheduling it is
possible to honour the cache topology of a system and thus avoid
expensive cache synchronization traffic.
We have clustered scheduling in case the set of processors of a system
is partitioned into non-empty pairwise-disjoint subsets. These subsets
are called clusters. Clusters with a cardinality of one are partitions.
Each cluster is owned by exactly one scheduler instance.
Scheduler operations must be free of a global scheduler context to
enable partitioned/clustered scheduling.
Add the following methods:
+ rtems_task_get_affinity
+ rtems_task_set_affinity
