path: root/cpukit/rtems/src/taskmode.c (follow)
* rtems misc: Clean up Doxygen GCI Task #7Alex Ivanov2012-12-051-18/+7
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/7950206
* score: Add and use <rtems/score/userextimpl.h>Sebastian Huber2012-11-221-1/+0
| | | | | This file contains the parts of <rtems/score/userext.h> that are only necessary for the RTEMS implementation.
* 2010-07-26 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-07-271-10/+6
| | | | | | * rtems/src/taskmode.c, score/inline/rtems/score/thread.inl: Rework a bit to eliminate unreachable path for task blocked while calling rtems_task_mode() on itself.
* 2010-06-28 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-06-291-1/+0
| | | | | | | | | | | | | | | | | | | PR 1573/cpukit * configure.ac, posix/src/killinfo.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadcreate.c, posix/src/pthreadkill.c, posix/src/pthreadsigmask.c, rtems/src/signalsend.c, rtems/src/taskmode.c, score/Makefile.am, score/preinstall.am, score/include/rtems/system.h, score/include/rtems/score/context.h, score/include/rtems/score/isr.h, score/include/rtems/score/thread.h, score/src/isr.c, score/src/isrthreaddispatch.c, score/src/thread.c, score/src/threaddispatch.c, score/src/threadloadenv.c: Add a per cpu data structure which contains the information required by RTEMS for each CPU core. This encapsulates information such as thread executing, heir, idle and dispatch needed. * score/include/rtems/score/percpu.h, score/src/percpu.c: New files.
* 2009-09-04 Sebastian Huber <Sebastian.Huber@embedded-brains.de>Joel Sherrill2009-09-041-1/+1
| | | | | | | | * rtems/src/taskmode.c, sapi/src/exshutdown.c, score/include/rtems/score/sysstate.h, score/inline/rtems/score/sysstate.inl: Added _System_state_Is_shutdown(). Removed direct uses of _System_state_Current. Documentation.
* Eliminate TRUE/FALSE.Ralf Corsepius2009-01-061-3/+3
* Convert to "bool".Ralf Corsepius2008-09-041-5/+5
* 2008-08-05 Xudong Guan <xudong.guan@criticalsoftware.com>Joel Sherrill2008-08-051-2/+3
| | | | | | | | | PR 1212/cpukit * rtems/src/taskmode.c, score/src/threadtickletimeslice.c: Time slicing will not happen if the task mode is changed from a non-timeslicing mode to timeslicing mode if it is done by the executing thread (e.g. in its task body). This change includes sp44 to demonstrate the problem and verify the correction.
* Include config.h.Ralf Corsepius2005-01-181-0/+4
* 2004-05-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-05-061-0/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 618/rtems * rtems/include/rtems/rtems/status.h, rtems/src/clockget.c, rtems/src/clockset.c, rtems/src/dpmemcreate.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmeminternal2external.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventsend.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c, rtems/src/msgqsubmit.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionreturnsegment.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/taskcreate.c, rtems/src/taskgetnote.c, rtems/src/taskmode.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasksetnote.c, rtems/src/tasksuspend.c, rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c, rtems/src/taskwakewhen.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, score/include/rtems/score/object.h, score/src/coretodvalidate.c, score/src/objectnametoid.c: Add NULL checks.
* Remove stray white spaces.Ralf Corsepius2004-04-181-1/+1
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems.h, include/rtems/rtems/asr.h, include/rtems/rtems/attr.h, include/rtems/rtems/cache.h, include/rtems/rtems/clock.h, include/rtems/rtems/config.h, include/rtems/rtems/dpmem.h, include/rtems/rtems/event.h, include/rtems/rtems/eventmp.h, include/rtems/rtems/eventset.h, include/rtems/rtems/intr.h, include/rtems/rtems/message.h, include/rtems/rtems/modes.h, include/rtems/rtems/mp.h, include/rtems/rtems/msgmp.h, include/rtems/rtems/options.h, include/rtems/rtems/part.h, include/rtems/rtems/partmp.h, include/rtems/rtems/ratemon.h, include/rtems/rtems/region.h, include/rtems/rtems/regionmp.h, include/rtems/rtems/rtemsapi.h, include/rtems/rtems/sem.h, include/rtems/rtems/semmp.h, include/rtems/rtems/signal.h, include/rtems/rtems/signalmp.h, include/rtems/rtems/status.h, include/rtems/rtems/support.h, include/rtems/rtems/taskmp.h, include/rtems/rtems/tasks.h, include/rtems/rtems/timer.h, include/rtems/rtems/types.h, inline/rtems/rtems/asr.inl, inline/rtems/rtems/attr.inl, inline/rtems/rtems/dpmem.inl, inline/rtems/rtems/event.inl, inline/rtems/rtems/eventset.inl, inline/rtems/rtems/message.inl, inline/rtems/rtems/modes.inl, inline/rtems/rtems/options.inl, inline/rtems/rtems/part.inl, inline/rtems/rtems/ratemon.inl, inline/rtems/rtems/region.inl, inline/rtems/rtems/sem.inl, inline/rtems/rtems/status.inl, inline/rtems/rtems/support.inl, inline/rtems/rtems/tasks.inl, inline/rtems/rtems/timer.inl, macros/rtems/rtems/asr.inl, macros/rtems/rtems/attr.inl, macros/rtems/rtems/dpmem.inl, macros/rtems/rtems/event.inl, macros/rtems/rtems/eventset.inl, macros/rtems/rtems/message.inl, macros/rtems/rtems/modes.inl, macros/rtems/rtems/options.inl, macros/rtems/rtems/part.inl, macros/rtems/rtems/ratemon.inl, macros/rtems/rtems/region.inl, macros/rtems/rtems/sem.inl, macros/rtems/rtems/status.inl, macros/rtems/rtems/support.inl, macros/rtems/rtems/tasks.inl, macros/rtems/rtems/timer.inl, src/attr.c, src/clockget.c, src/clockset.c, src/clocktick.c, src/dpmem.c, src/dpmemcreate.c, src/dpmemdelete.c, src/dpmemexternal2internal.c, src/dpmemident.c, src/dpmeminternal2external.c, src/event.c, src/eventmp.c, src/eventreceive.c, src/eventseize.c, src/eventsend.c, src/eventsurrender.c, src/eventtimeout.c, src/intr.c, src/intrbody.c, src/intrcatch.c, src/mp.c, src/msg.c, src/msgmp.c, src/msgqallocate.c, src/msgqbroadcast.c, src/msgqcreate.c, src/msgqdelete.c, src/msgqflush.c, src/msgqgetnumberpending.c, src/msgqident.c, src/msgqreceive.c, src/msgqsend.c, src/msgqsubmit.c, src/msgqtranslatereturncode.c, src/msgqurgent.c, src/part.c, src/partcreate.c, src/partdelete.c, src/partgetbuffer.c, src/partident.c, src/partmp.c, src/partreturnbuffer.c, src/ratemon.c, src/ratemoncancel.c, src/ratemoncreate.c, src/ratemondelete.c, src/ratemongetstatus.c, src/ratemonident.c, src/ratemonperiod.c, src/ratemontimeout.c, src/region.c, src/regioncreate.c, src/regiondelete.c, src/regionextend.c, src/regiongetinfo.c, src/regiongetsegment.c, src/regiongetsegmentsize.c, src/regionident.c, src/regionmp.c, src/regionreturnsegment.c, src/rtclock.c, src/rtemsidtoname.c, src/rtemstimer.c, src/sem.c, src/semcreate.c, src/semdelete.c, src/semflush.c, src/semident.c, src/semmp.c, src/semobtain.c, src/semrelease.c, src/semtranslatereturncode.c, src/signal.c, src/signalcatch.c, src/signalmp.c, src/signalsend.c, src/taskcreate.c, src/taskdelete.c, src/taskgetnote.c, src/taskident.c, src/taskinitusers.c, src/taskissuspended.c, src/taskmode.c, src/taskmp.c, src/taskrestart.c, src/taskresume.c, src/tasks.c, src/tasksetnote.c, src/tasksetpriority.c, src/taskstart.c, src/tasksuspend.c, src/taskvariableadd.c, src/taskvariabledelete.c, src/taskvariableget.c, src/taskwakeafter.c, src/taskwakewhen.c, src/timercancel.c, src/timercreate.c, src/timerdelete.c, src/timerfireafter.c, src/timerfirewhen.c, src/timergetinfo.c, src/timerident.c, src/timerreset.c, src/timerserver.c, src/timerserverfireafter.c, src/timerserverfirewhen.c: URL for license changed.
* 2001-01-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-161-2/+3
| | | | | * src/taskmode.c: Ensure the this service does not dispatch before tasking is enabled at initialization time.
* Split Task Manager into multiple files. Eventually this effort willJoel Sherrill1999-05-171-0/+122
reduce the size of executables.
