Update #2825.
The fatal is internal indicator is redundant since the fatal source and
error code uniquely identify a fatal error. Keep the fatal user
extension is internal parameter for backward compatibility and set it to
false always.
Update #2825.
This avoids potential dead code in _Thread_Handler(). It gets rid of
the dangerous function pointer casts.
Update #2514.
Update #2514.
This simplifies the global construction.
Update #2514.
Ensure that the global construction is performed in the context of the
first initialization thread. On SMP this was not guaranteed in the
previous implementation.
Rename _Internal_error_Occurred() into _Terminate().
TOD_MILLISECONDS_TO_TICKS().
application visible API.
Move implementation specific parts of tqdata.h, threadq.h and
threadq.inl into new header file threadqimpl.h. The threadq.h contains
now only the application visible API.
Delete tqdata.h.
Move implementation specific parts of states.h and states.inl into new
header file statesimpl.h. The states.h contains now only the
Move implementation specific parts of tasks.h and tasks.inl into new
header file tasksimpl.h. The tasks.h contains now only the application
visible API.
http://www.google-melange.com/gci/task/view/google/gci2012/8015207
This file contains the parts of <rtems/score/userext.h> that are only
necessary for the RTEMS implementation.
* rtems/src/taskinitusers.c: Fix typos.
* rtems/src/taskinitusers.c: Restructure to eliminate dead check --
loop will not be executed when 0 tasks. Also improved comments and
eliminated a local variable.
* itron/include/rtems/itron/itronapi.h, libmisc/capture/capture.c,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-mpci.c,
posix/include/rtems/posix/config.h,
posix/include/rtems/posix/posixapi.h,
rtems/include/rtems/rtems/config.h,
rtems/include/rtems/rtems/rtemsapi.h, rtems/src/taskinitusers.c,
sapi/include/confdefs.h, sapi/include/rtems/config.h,
sapi/include/rtems/init.h, sapi/src/exinit.c, sapi/src/itronapi.c,
sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/isr.c,
score/src/thread.c, score/src/threadcreateidle.c,
score/src/threadstackallocate.c, score/src/threadstackfree.c,
score/src/wkspace.c: Eliminate pointers to API configuration tables
in the main configuration table. Reference the main configuration
table and the API configuration tables directly using the confdefs.h
version rather than obtaining a pointer to it. This eliminated some
variables, a potential fatal error, some unnecessary default
configuration structures. Overall, about a 4.5% reduction in the code
size for minimum and hello on the SPARC.
the size of the BSS section when an optional manageer stub is used. Some tests showed about a 600 byte reduction in BSS size. Also eliminated the variables _RTEMS_tasks_User_initialization_tasks and _RTEMS_tasks_Number_of_initialization_tasks because they were only used in one place after initialized. It was a waste of space.
* itron/Makefile.am, itron/src/eventflags.c, itron/src/fmempool.c,
itron/src/itronintr.c, itron/src/itrontime.c, itron/src/network.c,
itron/src/port.c, itron/src/sysmgmt.c, itron/src/task.c,
itron/src/vmempool.c, posix/Makefile.am, posix/src/pthread.c,
rtems/src/taskinitusers.c, rtems/src/tasks.c,
sapi/include/confdefs.h, sapi/src/io.c: Various modification to
reduce executable size. Most were refactoring of files. Split ITRON
API files. Implemented mechanism to avoid initialization task/thread
loop being linked in when that style of task initialization was not
being used.
* itron/src/acp_por.c, itron/src/act_cyc.c, itron/src/cal_por.c,
itron/src/chg_iXX.c, itron/src/clr_flg.c, itron/src/cre_flg.c,
itron/src/cre_mpf.c, itron/src/cre_mpl.c, itron/src/cre_por.c,
itron/src/def_alm.c, itron/src/def_cyc.c, itron/src/def_exc.c,
itron/src/def_int.c, itron/src/def_svc.c, itron/src/del_flg.c,
itron/src/del_mpf.c, itron/src/del_mpl.c, itron/src/del_por.c,
itron/src/dis_int.c, itron/src/dly_tsk.c, itron/src/ena_int.c,
itron/src/fwd_por.c, itron/src/get_blf.c, itron/src/get_blk.c,
itron/src/get_tim.c, itron/src/get_ver.c, itron/src/itroninittasks.c,
itron/src/loc_cpu.c, itron/src/nget_nod.c, itron/src/nget_ver.c,
itron/src/nrea_dat.c, itron/src/nwri_dat.c, itron/src/pacp_por.c,
itron/src/pcal_por.c, itron/src/pget_blf.c, itron/src/pget_blk.c,
itron/src/pol_flg.c, itron/src/ref_alm.c, itron/src/ref_cfg.c,
itron/src/ref_cyc.c, itron/src/ref_flg.c, itron/src/ref_iXX.c,
itron/src/ref_mpf.c, itron/src/ref_mpl.c, itron/src/ref_por.c,
itron/src/ref_sys.c, itron/src/rel_blf.c, itron/src/rel_blk.c,
itron/src/ret_int.c, itron/src/ret_tmr.c, itron/src/ret_wup.c,
itron/src/rpl_rdv.c, itron/src/set_flg.c, itron/src/set_tim.c,
itron/src/tacp_por.c, itron/src/tcal_por.c, itron/src/tget_blf.c,
itron/src/tget_blk.c, itron/src/twai_flg.c, itron/src/unl_cpu.c,
itron/src/wai_flg.c, posix/src/pthreadinitthreads.c: New files.
* rtems/include/rtems.h,
rtems/include/rtems/rtems/asr.h,
rtems/include/rtems/rtems/attr.h,
rtems/include/rtems/rtems/clock.h,
rtems/include/rtems/rtems/dpmem.h,
rtems/include/rtems/rtems/eventset.h,
rtems/include/rtems/rtems/message.h,
rtems/include/rtems/rtems/modes.h,
rtems/include/rtems/rtems/msgmp.h,
rtems/include/rtems/rtems/options.h,
rtems/include/rtems/rtems/part.h,
rtems/include/rtems/rtems/region.h,
rtems/include/rtems/rtems/regionmp.h,
rtems/include/rtems/rtems/sem.h,
rtems/include/rtems/rtems/support.h,
rtems/include/rtems/rtems/taskmp.h,
rtems/include/rtems/rtems/tasks.h,
rtems/include/rtems/rtems/timer.h,
rtems/inline/rtems/rtems/part.inl,
rtems/inline/rtems/rtems/region.inl,
rtems/macros/rtems/rtems/part.inl,
rtems/src/attr.c,
rtems/src/dpmem.c,
rtems/src/msg.c,
rtems/src/msgmp.c,
rtems/src/msgqsend.c,
rtems/src/msgqsubmit.c,
rtems/src/part.c,
rtems/src/partmp.c,
rtems/src/region.c,
rtems/src/sem.c,
rtems/src/semmp.c,
rtems/src/taskmp.c,
rtems/src/tasks.c,
rtems/src/timerserver.c: Convert to using c99 fixed size types.
* include/rtems.h, include/rtems/rtems/asr.h,
include/rtems/rtems/attr.h, include/rtems/rtems/cache.h,
include/rtems/rtems/clock.h, include/rtems/rtems/config.h,
include/rtems/rtems/dpmem.h, include/rtems/rtems/event.h,
include/rtems/rtems/eventmp.h, include/rtems/rtems/eventset.h,
include/rtems/rtems/intr.h, include/rtems/rtems/message.h,
include/rtems/rtems/modes.h, include/rtems/rtems/mp.h,
include/rtems/rtems/msgmp.h, include/rtems/rtems/options.h,
include/rtems/rtems/part.h, include/rtems/rtems/partmp.h,
include/rtems/rtems/ratemon.h, include/rtems/rtems/region.h,
include/rtems/rtems/regionmp.h, include/rtems/rtems/rtemsapi.h,
include/rtems/rtems/sem.h, include/rtems/rtems/semmp.h,
include/rtems/rtems/signal.h, include/rtems/rtems/signalmp.h,
include/rtems/rtems/status.h, include/rtems/rtems/support.h,
include/rtems/rtems/taskmp.h, include/rtems/rtems/tasks.h,
include/rtems/rtems/timer.h, include/rtems/rtems/types.h,
inline/rtems/rtems/asr.inl, inline/rtems/rtems/attr.inl,
inline/rtems/rtems/dpmem.inl, inline/rtems/rtems/event.inl,
inline/rtems/rtems/eventset.inl, inline/rtems/rtems/message.inl,
inline/rtems/rtems/modes.inl, inline/rtems/rtems/options.inl,
inline/rtems/rtems/part.inl, inline/rtems/rtems/ratemon.inl,
inline/rtems/rtems/region.inl, inline/rtems/rtems/sem.inl,
inline/rtems/rtems/status.inl, inline/rtems/rtems/support.inl,
inline/rtems/rtems/tasks.inl, inline/rtems/rtems/timer.inl,
macros/rtems/rtems/asr.inl, macros/rtems/rtems/attr.inl,
macros/rtems/rtems/dpmem.inl, macros/rtems/rtems/event.inl,
macros/rtems/rtems/eventset.inl, macros/rtems/rtems/message.inl,
macros/rtems/rtems/modes.inl, macros/rtems/rtems/options.inl,
macros/rtems/rtems/part.inl, macros/rtems/rtems/ratemon.inl,
macros/rtems/rtems/region.inl, macros/rtems/rtems/sem.inl,
macros/rtems/rtems/status.inl, macros/rtems/rtems/support.inl,
macros/rtems/rtems/tasks.inl, macros/rtems/rtems/timer.inl,
src/attr.c, src/clockget.c, src/clockset.c, src/clocktick.c,
src/dpmem.c, src/dpmemcreate.c, src/dpmemdelete.c,
src/dpmemexternal2internal.c, src/dpmemident.c,
src/dpmeminternal2external.c, src/event.c, src/eventmp.c,
src/eventreceive.c, src/eventseize.c, src/eventsend.c,
src/eventsurrender.c, src/eventtimeout.c, src/intr.c, src/intrbody.c,
src/intrcatch.c, src/mp.c, src/msg.c, src/msgmp.c,
src/msgqallocate.c, src/msgqbroadcast.c, src/msgqcreate.c,
src/msgqdelete.c, src/msgqflush.c, src/msgqgetnumberpending.c,
src/msgqident.c, src/msgqreceive.c, src/msgqsend.c, src/msgqsubmit.c,
src/msgqtranslatereturncode.c, src/msgqurgent.c, src/part.c,
src/partcreate.c, src/partdelete.c, src/partgetbuffer.c,
src/partident.c, src/partmp.c, src/partreturnbuffer.c, src/ratemon.c,
src/ratemoncancel.c, src/ratemoncreate.c, src/ratemondelete.c,
src/ratemongetstatus.c, src/ratemonident.c, src/ratemonperiod.c,
src/ratemontimeout.c, src/region.c, src/regioncreate.c,
src/regiondelete.c, src/regionextend.c, src/regiongetinfo.c,
src/regiongetsegment.c, src/regiongetsegmentsize.c,
src/regionident.c, src/regionmp.c, src/regionreturnsegment.c,
src/rtclock.c, src/rtemsidtoname.c, src/rtemstimer.c, src/sem.c,
src/semcreate.c, src/semdelete.c, src/semflush.c, src/semident.c,
src/semmp.c, src/semobtain.c, src/semrelease.c,
src/semtranslatereturncode.c, src/signal.c, src/signalcatch.c,
src/signalmp.c, src/signalsend.c, src/taskcreate.c, src/taskdelete.c,
src/taskgetnote.c, src/taskident.c, src/taskinitusers.c,
src/taskissuspended.c, src/taskmode.c, src/taskmp.c,
src/taskrestart.c, src/taskresume.c, src/tasks.c, src/tasksetnote.c,
src/tasksetpriority.c, src/taskstart.c, src/tasksuspend.c,
src/taskvariableadd.c, src/taskvariabledelete.c,
src/taskvariableget.c, src/taskwakeafter.c, src/taskwakewhen.c,
src/timercancel.c, src/timercreate.c, src/timerdelete.c,
src/timerfireafter.c, src/timerfirewhen.c, src/timergetinfo.c,
src/timerident.c, src/timerreset.c, src/timerserver.c,
src/timerserverfireafter.c, src/timerserverfirewhen.c: URL for
license changed.
reduce the size of executables.
