* | rtems: Canonicalize Doxygen @file comments | Sebastian Huber | 2020-12-02 | 1 | -0/+9 |
| | | | | | | Use common phrases for the file brief descriptions. Update #3706. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -2/+2 |
* | score: Introduce Thread_Scheduler_control::home | Sebastian Huber | 2016-11-02 | 1 | -1/+1 |
| | | | | | | | | Replace Thread_Scheduler_control::control and Thread_Scheduler_control::own_control with new Thread_Scheduler_control::home. Update #2556. | ||||
* | Replace *_Get_interrupt_disable() with *_Get() | Sebastian Huber | 2016-05-20 | 1 | -1/+1 |
| | | | | | Uniformly use *_Get() to get an object by identifier with a lock context. | ||||
* | score: Avoid Giant lock for scheduler set/get | Sebastian Huber | 2016-05-12 | 1 | -29/+23 |
| | | | | Update #2555. | ||||
* | rtems: Clarify task set/get scheduler parameters | Sebastian Huber | 2014-05-20 | 1 | -2/+2 |
* | rtems: Add task get/set scheduler | Sebastian Huber | 2014-04-15 | 1 | -0/+60 |
