* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | score: Simplify _Scheduler_Get_by_id() | Sebastian Huber | 2016-11-09 | 1 | -1/+2 |
| | | | | | | | | | | Avoid dead code in non-SMP configurations. Return scheduler identifier independent of the current processor count of the scheduler via rtems_scheduler_ident(), since this value may change during run-time. Check the processor count in _Scheduler_Set() under scheduler lock protection. Update #2797. | ||||
* | rtems: Add rtems_task_get_priority() | Sebastian Huber | 2016-09-21 | 1 | -0/+77 |
Update #2556. Update #2784. |
