* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | score: Remove CPU_set_Control | Sebastian Huber | 2017-10-11 | 1 | -1/+0 |
| | | | | | | Use Processor_mask instead. Update #2514. | ||||
* | Remove obsolete __RTEMS_HAVE_SYS_CPUSET_H__ | Joel Sherrill | 2017-01-11 | 1 | -3/+0 |
* | Replace *_Get_interrupt_disable() with *_Get() | Sebastian Huber | 2016-05-20 | 1 | -1/+1 |
| | | | | | Uniformly use *_Get() to get an object by identifier with a lock context. | ||||
* | score: Avoid Giant lock _Scheduler_Get_affinity() | Sebastian Huber | 2016-05-12 | 1 | -24/+27 |
| | | | | Update #2555. | ||||
* | score: _Scheduler_Get_affinity() | Sebastian Huber | 2014-06-02 | 1 | -1/+0 |
| | | | | Drop scheduler parameter. Coding style. | ||||
* | score: Add scheduler control to scheduler ops | Sebastian Huber | 2014-04-04 | 1 | -5/+8 |
| | | | | | Scheduler operations must be free of a global scheduler context to enable partitioned/clustered scheduling. | ||||
* | rtems: Move affinity from thread to scheduler. | Jennifer Averett | 2014-04-03 | 1 | -3/+3 |
* | Remove trailing whitespace in previous patches | Jennifer Averett | 2014-03-07 | 1 | -1/+1 |
* | rtems: Add Classic API get and set affinity methods. | Jennifer Averett | 2014-03-07 | 1 | -0/+63 |
Add the following methods: + rtems_task_get_affinity + rtems_task_set_affinity |
