Update #3598.
The _Thread_Lock_acquire() function had a potentially infinite run-time
due to the lack of fairness at atomic operations level.
Update #2412.
Update #2556.
Update #2765.
Unify the status codes of the Classic and POSIX API to use the new enum
Status_Control. This eliminates the Thread_Control::Wait::timeout_code
field and the timeout parameter of _Thread_queue_Enqueue_critical() and
_MPCI_Send_request_packet(). It gets rid of the status code translation
tables and instead uses simple bit operations to get the status for a
particular API. This enables translation of status code constants at
compile time. Add _Thread_Wait_get_status() to avoid direct access of
thread internal data structures.
Remove _Thread_Acquire() and _Thread_Acquire_for_executing(). Add
utility functions for the default thread lock. Use the default thread
lock for the RTEMS events. There is no need to disable thread
dispatching and a Giant acquire in _Event_Timeout() since this was
already done by the caller.
Update #2273.
Use the ISR lock of the thread object to protect the event state and
use the Giant lock only for the blocking operations.
Update #2273.
Move implementation specific parts of states.h and states.inl into new
header file statesimpl.h. The states.h contains now only the
application visible API.
Move implementation specific parts of event.h, event.inl, eventset.h and
eventset.inl into new header file eventimpl.h. The event.h contains now
only the application visible API.
System events are similar to normal events. They offer a second set of
events. These events are intended for internal RTEMS use and should not
be used by applications (with the exception of the transient system
event).
