Move _Status_Object_name_errors_to_status to a separate file to avoid a
dependency on errno. Dependencies to errno are hard to be removed by
the linker garbage collection.
Based on correlation with the enum for object lookup errors in
cpukit/score/include/rtems/score/objectimpl.h:
typedef enum {
OBJECTS_NAME_OR_ID_LOOKUP_SUCCESSFUL,
OBJECTS_INVALID_NAME,
OBJECTS_INVALID_ADDRESS,
OBJECTS_INVALID_ID,
OBJECTS_INVALID_NODE
} Objects_Name_or_id_lookup_errors;
update the comments regarding the object lookup error to status map to
match.
Signed-off-by: Martin Erik Werner <martin.werner@aacmicrotec.com>
Renames rtems_deviceio_errno to rtems_status_code_to_errno and
integrates it into the Classic API Status Handler. This function
can now be called by including status.h
Move implementation specific parts of status.h and status.inl into new
header file statusimpl.h. The status.h contains now only the
application visible API.
http://www.google-melange.com/gci/task/view/google/gci2012/7950205
* rtems/Makefile.am: Add src/status.c.
* rtems/include/rtems/rtems/status.h: Make
_Status_Object_name_errors_to_status an external variable.
* rtems/src/status.c: New (split out from
rtems/include/rtems/rtems/status.h).
