http://www.google-melange.com/gci/task/view/google/gci2012/7950205
* rtems/Makefile.am: Add src/status.c.
* rtems/include/rtems/rtems/status.h: Make
_Status_Object_name_errors_to_status an external variable.
* rtems/src/status.c: New (split out from
rtems/include/rtems/rtems/status.h).
