* | score: Static Objects_Information initialization | Sebastian Huber | 2018-12-14 | 1 | -0/+19 |
| | | | | | | | | | | | Statically allocate the objects information together with the initial set of objects either via <rtems/confdefs.h>. Provide default object informations with zero objects via librtemscpu.a. This greatly simplifies the workspace size estimate. RTEMS applications which do not use the unlimited objects option are easier to debug since all objects reside now in statically allocated objects of the right types. Close #3621. | ||||
* | rtems: Move internal structures to semdata.h | Sebastian Huber | 2018-11-12 | 1 | -0/+1 |
| | | | | Update #3598. | ||||
* | score: Initialize thread queue context early | Sebastian Huber | 2016-12-02 | 1 | -0/+1 |
| | | | | | | | | Initialize thread queue context early preferably outside the critical section. Remove implicit _Thread_queue_Context_initialize() from _Thread_Wait_acquire(). | ||||
* | score: Introduce thread resource count methods | Sebastian Huber | 2016-11-03 | 1 | -1/+1 |
| | | | | | This makes it easier to conditionally enable/disable the thread resource count usage. | ||||
* | rtems: Fix binary semaphore resource count | Sebastian Huber | 2016-11-03 | 1 | -4/+1 |
| | | | | | | Binary semaphores (not simple binary semaphores) maintain the resource count since 8797c76addf22a2f0ffc3717ff977695e35b9b0b. Do this also for initially locked binary semaphores. | ||||
* | score: Introduce Thread_Scheduler_control::home | Sebastian Huber | 2016-11-02 | 1 | -2/+2 |
| | | | | | | | | Replace Thread_Scheduler_control::control and Thread_Scheduler_control::own_control with new Thread_Scheduler_control::home. Update #2556. | ||||
* | score: Introduce Thread_queue_Lock_context | Sebastian Huber | 2016-09-08 | 1 | -1/+1 |
| | | | | | | Introduce Thread_queue_Lock_context to contain the context necessary for thread queue lock and thread wait lock acquire/release operations to reduce the Thread_Control size. | ||||
* | score: Introduce map priority scheduler operation | Sebastian Huber | 2016-06-22 | 1 | -0/+2 |
| | | | | | | | | | | | Introduce map/unmap priority scheduler operations to map thread priority values from/to the user domain to/from the scheduler domain. Use the map priority operation to validate the thread priority. The EDF schedulers use this new operation to distinguish between normal priorities and priorities obtain through a job release. Update #2173. Update #2556. | ||||
* | rtems: Rework RTEMS API to SuperCore priority | Sebastian Huber | 2016-06-22 | 1 | -32/+50 |
| | | | | | Use same structure as POSIX API for thread priority conversion to/from SuperCore. | ||||
* | rtems: Fix rtems_semaphore_create() | Sebastian Huber | 2016-06-16 | 1 | -0/+4 |
| | | | | | Destroy the thread queue in case of a priority ceiling violation, otherwise the SMP profiling data gets corrupted. | ||||
* | rtems: Simplify rtems_semaphore_create() | Sebastian Huber | 2016-06-07 | 1 | -132/+113 |
| | | | | | Remove superfluous includes. Use one attribute compare for each semaphore variant. Text size drops by 10% on PowerPC due to this. | ||||
* | rtems: Fix semaphore field name | Sebastian Huber | 2016-05-30 | 1 | -2/+2 |
* | rtems: Move MrsP semaphore operations | Sebastian Huber | 2016-05-30 | 1 | -1/+1 |
| | | | | | Move MrsP semaphore operations to a less prominent location. Fix field name. | ||||
* | score: Rework CORE inherit priority mutex | Sebastian Huber | 2016-05-30 | 1 | -20/+15 |
| | | | | | Provide dedicated seize and surrender methods for inherit priority mutexes. This eliminates CORE_mutex_Attributes. | ||||
* | score: Rework CORE priority ceiling mutex | Sebastian Huber | 2016-05-30 | 1 | -13/+28 |
| | | | | | Rework seize and surrender methods to use CORE_ceiling_mutex_Control. This eliminates CORE_mutex_Disciplines. | ||||
* | score: Add CORE mutex variants | Sebastian Huber | 2016-05-30 | 1 | -27/+32 |
| | | | | | | | | Add CORE_recursive_mutex_Control and CORE_ceiling_mutex_Control to avoid the run-time evaluation of attributes to figure out how a particular mutex methods should behave. Start with the no protocol variants. This eliminates the CORE_MUTEX_DISCIPLINES_FIFO and CORE_MUTEX_DISCIPLINES_PRIORITY disciplines. | ||||
* | score: Simplify CORE mutex | Sebastian Huber | 2016-05-30 | 1 | -21/+22 |
| | | | | | Remove superfluous support for simple binary semaphores. With this we can get rid of the CORE_MUTEX_NESTING_BLOCKS variant. | ||||
* | score: Add semaphore variants | Sebastian Huber | 2016-05-30 | 1 | -16/+15 |
* | score: Add Status_Control for all APIs | Sebastian Huber | 2016-05-26 | 1 | -15/+10 |
| | | | | | | | | | | | Unify the status codes of the Classic and POSIX API to use the new enum Status_Control. This eliminates the Thread_Control::Wait::timeout_code field and the timeout parameter of _Thread_queue_Enqueue_critical() and _MPCI_Send_request_packet(). It gets rid of the status code translation tables and instead uses simple bit operations to get the status for a particular API. This enables translation of status code constants at compile time. Add _Thread_Wait_get_status() to avoid direct access of thread internal data structures. | ||||
* | score: Use constant for maximum count of CORE sema | Sebastian Huber | 2016-03-29 | 1 | -1/+0 |
* | score: Remove Thread_queue_Queue::operations field | Sebastian Huber | 2016-03-29 | 1 | -9/+5 |
| | | | | | | | | | Remove the Thread_queue_Queue::operations field to reduce the size of this structure. Add a thread queue operations parameter to the _Thread_queue_First(), _Thread_queue_First_locked(), _Thread_queue_Enqueue(), _Thread_queue_Dequeue() and _Thread_queue_Flush() functions. This is a preparation patch to reduce the size of several synchronization objects. | ||||
* | score: Multiprocessor Resource Sharing Protocol | Sebastian Huber | 2014-05-28 | 1 | -3/+35 |
| | | | | | | | | | | | | | | | | | | | | | | Add basic support for the Multiprocessor Resource Sharing Protocol (MrsP). The Multiprocessor Resource Sharing Protocol (MrsP) is defined in A. Burns and A.J. Wellings, A Schedulability Compatible Multiprocessor Resource Sharing Protocol - MrsP, Proceedings of the 25th Euromicro Conference on Real-Time Systems (ECRTS 2013), July 2013. It is a generalization of the Priority Ceiling Protocol to SMP systems. Each MrsP semaphore uses a ceiling priority per scheduler instance. These ceiling priorities can be specified with rtems_semaphore_set_priority(). A task obtaining or owning a MrsP semaphore will execute with the ceiling priority for its scheduler instance as specified by the MrsP semaphore object. Tasks waiting to get ownership of a MrsP semaphore will not relinquish the processor voluntarily. In case the owner of a MrsP semaphore gets preempted it can ask all tasks waiting for this semaphore to help out and temporarily borrow the right to execute on one of their assigned processors. The help out feature is not implemented with this patch. | ||||
* | score: Delete CORE_mutex_Control::lock | Sebastian Huber | 2014-03-31 | 1 | -1/+1 |
| | | | | | | | | The holder field is enough to determine if a mutex is locked or not. This leads also to better error status codes in case a rtems_semaphore_release() is done for a mutex without having the ownership. | ||||
* | score: PR2152: Use allocator mutex for objects | Sebastian Huber | 2014-03-31 | 1 | -7/+5 |
| | | | | | Use allocator mutex for objects allocate/free. This prevents that the thread dispatch latency depends on the workspace/heap fragmentation. | ||||
* | rtems/*.c: Remove use of register keyword | Joel Sherrill | 2014-02-03 | 1 | -2/+2 |
* | rtems: classic api to/from core priority conversions | Daniel Ramirez | 2013-12-21 | 1 | -1/+4 |
* | score: Create object implementation header | Sebastian Huber | 2013-07-26 | 1 | -1/+0 |
| | | | | | | Move implementation specific parts of object.h and object.inl into new header file objectimpl.h. The object.h contains now only the application visible API. | ||||
* | Include missing <rtems/score/threaddispatch.h> | Sebastian Huber | 2013-07-26 | 1 | -1/+1 |
* | score: Create mpci implementation header | Sebastian Huber | 2013-07-26 | 1 | -3/+0 |
| | | | | | Move implementation specific parts of mpci.h into new header file mpciimpl.h. The mpci.h contains now only the application visible API. | ||||
* | score: Create threadq implementation header | Sebastian Huber | 2013-07-26 | 1 | -1/+0 |
| | | | | | | | | Move implementation specific parts of tqdata.h, threadq.h and threadq.inl into new header file threadqimpl.h. The threadq.h contains now only the application visible API. Delete tqdata.h. | ||||
* | score: Create states implementation header | Sebastian Huber | 2013-07-26 | 1 | -1/+0 |
| | | | | | | Move implementation specific parts of states.h and states.inl into new header file statesimpl.h. The states.h contains now only the application visible API. | ||||
* | rtems: Create attr implementation header | Sebastian Huber | 2013-07-23 | 1 | -1/+1 |
| | | | | | | Move implementation specific parts of attr.h and attr.inl into new header file attrimpl.h. The attr.h contains now only the application visible API. | ||||
* | score: Create semaphore implementation header | Sebastian Huber | 2013-07-22 | 1 | -1/+1 |
| | | | | | | Move implementation specific parts of coresem.h and coresem.inl into new header file coresemimpl.h. The coresem.h contains now only the application visible API. | ||||
* | score: Avoid direct usage of _Thread_Executing | Sebastian Huber | 2013-07-18 | 1 | -0/+1 |
| | | | | | | Pass the executing thread as a function parameter. Obtain the executing thread inside a thread dispatch critical section to avoid problems on SMP. | ||||
* | score: Create mutex implementation header | Sebastian Huber | 2013-07-18 | 1 | -1/+1 |
| | | | | | | Move implementation specific parts of coremutex.h and coremutex.inl into new header file coremuteximpl.h. The coremutex.h contains now only the application visible API. | ||||
* | rtems: Create semaphore implementation header | Sebastian Huber | 2013-07-18 | 1 | -1/+1 |
| | | | | | | Move implementation specific parts of sem.h and sem.inl into new header file semimpl.h. The sem.h contains now only the application visible API. | ||||
* | rtems misc: Clean up Doxygen GCI Task #5 | Mathew Kallada | 2012-12-05 | 1 | -16/+7 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8015207 | ||||
* | 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-07-24 | 1 | -2/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -1/+1 |
* | 2009-10-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-30 | 1 | -1/+1 |
| | | | | * rtems/src/semcreate.c: Fix mismatched brace in multiprocessing code. | ||||
* | 2009-07-09 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-09 | 1 | -47/+46 |
| | | | | | * rtems/src/semcreate.c: Clean up rework to eliminate the goto and fix a bug introduced by rework. | ||||
* | 2009-07-08 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-08 | 1 | -61/+57 |
| | | | | | * rtems/src/semcreate.c: Restructure to simplify and improve ability to anlize this routine for coverage. | ||||
* | 2009-05-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-05-28 | 1 | -9/+11 |
| | | | | | | | | | PR 1415/cpukit * rtems/src/semcreate.c, rtems/src/semtranslatereturncode.c, score/include/rtems/score/coremutex.h, score/inline/rtems/score/coremutex.inl, score/src/coremutex.c: Address two paths where a task with a priority above the ceiling could obtain a priority ceiling mutex. | ||||
* | 2009-03-02 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-03-02 | 1 | -1/+5 |
| | | | | | | | PR 1388/cpukit * rtems/src/semcreate.c: Classic Semaphores allow both priority inherit and ceiling attributes to be set on semaphore create. These attributes are mutually exclusive and this should be an error. | ||||
* | Eliminate TRUE/FALSE. | Ralf Corsepius | 2009-01-06 | 1 | -4/+4 |
* | Use rtems_id for semaphores. | Ralf Corsepius | 2005-02-04 | 1 | -1/+1 |
* | Include config.h. | Ralf Corsepius | 2005-01-18 | 1 | -0/+4 |
* | 2004-05-06 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-05-06 | 1 | -0/+3 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 618/rtems * rtems/include/rtems/rtems/status.h, rtems/src/clockget.c, rtems/src/clockset.c, rtems/src/dpmemcreate.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmeminternal2external.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventsend.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c, rtems/src/msgqsubmit.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionreturnsegment.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/taskcreate.c, rtems/src/taskgetnote.c, rtems/src/taskmode.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasksetnote.c, rtems/src/tasksuspend.c, rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c, rtems/src/taskwakewhen.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, score/include/rtems/score/object.h, score/src/coretodvalidate.c, score/src/objectnametoid.c: Add NULL checks. |
