* | cpukit/rtems/src/[s-z]*.c: Change license to BSD-2 | Joel Sherrill | 2022-02-28 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | rtems: Move scheduler directives to own header | Sebastian Huber | 2021-12-02 | 1 | -2/+2 |
| | | | | | | Move all rtems_scheduler_* directives to the new header file <rtems/rtems/scheduler.h>. Add a Scheduler Manager API and implementation group. | ||||
* | rtems: rtems_scheduler_ident_by_processor_set() | Sebastian Huber | 2021-05-06 | 1 | -0/+4 |
| | | | | Check for a NULL processor set pointer. | ||||
* | rtems: Canonicalize Doxygen @file comments | Sebastian Huber | 2020-12-02 | 1 | -0/+9 |
| | | | | | | Use common phrases for the file brief descriptions. Update #3706. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | rtems: Add rtems_scheduler_ident_by_processor_set | Sebastian Huber | 2017-07-11 | 1 | -0/+60 |
Update #3070. |
