brains GmbH.
Use early returns to simplify rtems_scheduler_ident().
Updates #4625.
Updates #3053.
Move all rtems_scheduler_* directives to the new header file
<rtems/rtems/scheduler.h>. Add a Scheduler Manager API and
implementation group.
Use common phrases for the file brief descriptions.
Update #3706.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Avoid dead code in non-SMP configurations. Return scheduler identifier
independent of the current processor count of the scheduler via
rtems_scheduler_ident(), since this value may change during run-time.
Check the processor count in _Scheduler_Set() under scheduler lock
protection.
Update #2797.
Avoid the SMP_FATAL_SCHEDULER_WITHOUT_PROCESSORS fatal error and make it
a run-time error in rtems_scheduler_ident() and _Scheduler_Get_by_id().
