#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Avoid dead code in non-SMP configurations. Return scheduler identifier
independent of the current processor count of the scheduler via
rtems_scheduler_ident(), since this value may change during run-time.
Check the processor count in _Scheduler_Set() under scheduler lock
protection.
Update #2797.
Avoid the SMP_FATAL_SCHEDULER_WITHOUT_PROCESSORS fatal error and make it
a run-time error in rtems_scheduler_ident() and _Scheduler_Get_by_id().
