path: root/cpukit/rtems/src/rtemsbuildname.c (follow)
* rtemsbuildname.c: Fix missing prototype warningsJoel Sherrill2013-09-221-1/+19
* score: Create object implementation headerSebastian Huber2013-07-261-1/+0
| | | | | | Move implementation specific parts of object.h and object.inl into new header file objectimpl.h. The object.h contains now only the application visible API.
* rtems misc: Clean up Doxygen GCI Task #4Alex Ivanov2012-12-041-2/+7
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/7950205
* Whitespace removal.Ralf Corsepius2009-11-301-1/+1
* 2008-01-29 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-01-291-0/+31
* itron/src/exd_tsk.c, itron/src/task.c, libmisc/capture/capture.c, libmisc/monitor/mon-config.c, libmisc/monitor/mon-driver.c, libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c, libmisc/monitor/mon-symbols.c, posix/src/cancelrun.c, posix/src/pthreadexit.c, rtems/Makefile.am, rtems/preinstall.am, rtems/include/rtems.h, rtems/include/rtems/rtems/support.h, rtems/inline/rtems/rtems/tasks.inl, rtems/src/eventmp.c, rtems/src/msgmp.c, rtems/src/partmp.c, rtems/src/regionmp.c, rtems/src/rtemsobjectgetname.c, rtems/src/semmp.c, rtems/src/signalmp.c, rtems/src/taskdelete.c, rtems/src/taskmp.c, rtems/src/timerserver.c, score/Makefile.am, score/include/rtems/score/object.h, score/inline/rtems/score/object.inl, score/src/Unlimited.txt, score/src/objectgetnameasstring.c, score/src/threadqextractwithproxy.c: Add new Object Services collection. This changed the name of a few previously public but undocumented services and added a some new services. * rtems/include/rtems/rtems/object.h, rtems/src/rtemsbuildid.c, rtems/src/rtemsbuildname.c, rtems/src/rtemsobjectapimaximumclass.c, rtems/src/rtemsobjectapiminimumclass.c, rtems/src/rtemsobjectgetapiclassname.c, rtems/src/rtemsobjectgetapiname.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemsobjectgetclassinfo.c, rtems/src/rtemsobjectidapimaximum.c, rtems/src/rtemsobjectidapiminimum.c, rtems/src/rtemsobjectidgetapi.c, rtems/src/rtemsobjectidgetclass.c, rtems/src/rtemsobjectidgetindex.c, rtems/src/rtemsobjectidgetnode.c, rtems/src/rtemsobjectsetname.c, score/src/objectapimaximumclass.c, score/src/objectgetinfo.c, score/src/objectgetinfoid.c, score/src/objectsetname.c: New files. * rtems/src/rtemsidtoname.c: Removed.
