Updates #3053.
Add a "Constraints" paragraph to the documentation.
Provide prototypes for programming language bindings. Use the macro
implementation to implement the corresponding functions.
Update #3993.
Use common phrases for the file brief descriptions.
Update #3706.
application visible API.
http://www.google-melange.com/gci/task/view/google/gci2012/7950205
* itron/src/exd_tsk.c, itron/src/task.c, libmisc/capture/capture.c,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-symbols.c, posix/src/cancelrun.c,
posix/src/pthreadexit.c, rtems/Makefile.am, rtems/preinstall.am,
rtems/include/rtems.h, rtems/include/rtems/rtems/support.h,
rtems/inline/rtems/rtems/tasks.inl, rtems/src/eventmp.c,
rtems/src/msgmp.c, rtems/src/partmp.c, rtems/src/regionmp.c,
rtems/src/rtemsobjectgetname.c, rtems/src/semmp.c,
rtems/src/signalmp.c, rtems/src/taskdelete.c, rtems/src/taskmp.c,
rtems/src/timerserver.c, score/Makefile.am,
score/inline/rtems/score/object.inl, score/src/Unlimited.txt,
score/src/objectgetnameasstring.c,
score/src/threadqextractwithproxy.c: Add new Object Services
collection. This changed the name of a few previously public but
undocumented services and added a some new services.
* rtems/include/rtems/rtems/object.h, rtems/src/rtemsbuildid.c,
rtems/src/rtemsbuildname.c, rtems/src/rtemsobjectapimaximumclass.c,
rtems/src/rtemsobjectapiminimumclass.c,
rtems/src/rtemsobjectgetapiclassname.c,
rtems/src/rtemsobjectgetapiname.c,
rtems/src/rtemsobjectgetclassicname.c,
rtems/src/rtemsobjectgetclassinfo.c,
rtems/src/rtemsobjectidapimaximum.c,
rtems/src/rtemsobjectidapiminimum.c, rtems/src/rtemsobjectidgetapi.c,
rtems/src/rtemsobjectidgetclass.c, rtems/src/rtemsobjectidgetindex.c,
rtems/src/rtemsobjectidgetnode.c, rtems/src/rtemsobjectsetname.c,
score/src/objectapimaximumclass.c, score/src/objectgetinfo.c,
score/src/objectgetinfoid.c, score/src/objectsetname.c: New files.
* rtems/src/rtemsidtoname.c: Removed.
* optman/Makefile.am, optman/preinstall.am, optman/rtems/no-dpmem.c,
optman/rtems/no-event.c, optman/rtems/no-mp.c, optman/rtems/no-msg.c,
optman/rtems/no-part.c, optman/rtems/no-region.c,
optman/rtems/no-rtmon.c, optman/rtems/no-sem.c,
optman/rtems/no-signal.c, optman/rtems/no-timer.c,
optman/sapi/no-ext.c: Add optional manager stub for Barrier. Simplify
other optional managers so using them reduces application size
instead of increasing it.
* optman/rtems/no-barrier.c: New file.
* optman/rtems/no-dpmem.c, optman/rtems/no-mp.c,
optman/rtems/no-msg.c, optman/rtems/no-part.c,
optman/rtems/no-region.c, optman/rtems/no-rtmon.c,
optman/rtems/no-sem.c, optman/rtems/no-timer.c,
optman/sapi/no-ext.c, optman/sapi/no-io.c: Convert to using c99
fixed size types.
* rtems/no-dpmem.c, rtems/no-event.c, rtems/no-mp.c, rtems/no-msg.c,
rtems/no-part.c, rtems/no-region.c, rtems/no-rtmon.c, rtems/no-sem.c,
rtems/no-signal.c, rtems/no-timer.c, sapi/no-ext.c, sapi/no-io.c: URL
for license changed.
like signal dispatching.
