path: root/cpukit/rtems/src/regionmp.c (follow)
* Suggested changes from Mark Jordan which eliminate warnings and errorsJoel Sherrill1996-12-021-1/+1
| | | | | | | | he received using the Microtec C++ compiler. Most of these are either missing casts from/to (void *), heavy handed use of enumerated types, or simply assumed conversions. There is at least one actual bug in an error path in thread.c in which the wrong argument was passed to _Thread_Stack_Free and was not being caught by gcc.
* posix support initially addedJoel Sherrill1995-09-261-4/+4
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-10/+12
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-281-1/+1
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-2/+2
* Initial revisionJoel Sherrill1995-05-111-0/+308
