Use common phrases for the file brief descriptions.
Update #3706.
Use the maximum ID for the ID to object translation. Using the maximum
ID gets rid of an additional load from the object information in
_Objects_Get(). In addition, object lookups fail for every ID in case
the object information is cleared to zero. This makes it a bit more
robust during system startup (see new tests in spconfig02).
The local table no longer needs a NULL pointer entry at array index
zero. Adjust all the object iteration loops accordingly.
Remove Objects_Information::minimum_id since it contains only redundant
information. Add _Objects_Get_minimum_id() to get the minimum ID.
Update #3621.
Update #3111.
architectures
The RTEMS print user need to know nothing about a particular printer
implementation. In particular get rid of the <stdio.h> include which
would be visible via <rtems.h>.
of this patch set.
This was obsolete and broken based upon recent time keeping changes.
Thie build option was previously enabled by adding
USE_TICKS_FOR_STATISTICS=1 to the configure command line.
This propagated into the code as preprocessor conditionals
using the __RTEMS_USE_TICKS_FOR_STATISTICS__ conditional.
Move implementation specific parts of ratemon.h and ratemon.inl into
new header file ratemonimpl.h. The ratemon.h contains now only the
application visible API.
http://www.google-melange.com/gci/task/view/google/gci2012/7950206
* rtems/src/ratemonreportstatistics.c, rtems/src/ratemonresetall.c:
Remove unchecked return status pointed out by clang.
* libcsupport/src/__times.c, libmisc/cpuuse/cpuusagedata.c,
libmisc/cpuuse/cpuusagereport.c, libmisc/cpuuse/cpuusagereset.c,
rtems/include/rtems/rtems/types.h, rtems/src/ratemongetstatistics.c,
rtems/src/ratemonreportstatistics.c, score/src/threaddispatch.c,
score/src/threadinitialize.c, score/src/threadtickletimeslice.c:
Updated copyright line.
* configure.ac, libcsupport/src/__times.c,
libmisc/cpuuse/cpuusagedata.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuusagereset.c, rtems/include/rtems/rtems/ratemon.h,
rtems/src/ratemongetstatus.c, rtems/src/ratemonperiod.c,
score/include/rtems/score/thread.h, score/src/threaddispatch.c,
Changed the configuration of statistics granularity to use just one
define.
* rtems/src/ratemonreportstatistics.c: owner field is always set so
safe to use. Reformat.
* rtems/src/regionresizesegment.c: Always evaluate the blocked queue
if the resize succeeded.
* rtems/src/tasksetnote.c: Spacing.
* rtems/include/rtems/rtems/ratemon.h,
score/include/rtems/score/thread.h, score/src/coretodgetuptime.c:
Make all Thread and Period Statistics use publicly defined types. Do
not leak the SuperCore Timestamp type through the APIs.
* libcsupport/src/__times.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuusagereset.c, posix/src/clockgettime.c,
posix/src/pthread.c, posix/src/timersettime.c,
rtems/src/clockgetsecondssinceepoch.c, rtems/src/clockgetuptime.c,
rtems/src/ratemonreportstatistics.c, rtems/src/taskwakewhen.c,
rtems/src/timerfirewhen.c, rtems/src/timerserver.c,
rtems/src/timerserverfirewhen.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/thread.h,
score/include/rtems/score/tod.h, score/src/coretod.c,
score/src/coretodget.c, score/src/coretodgetuptime.c,
score/src/coretodset.c, score/src/coretodtickle.c,
score/src/threaddispatch.c, score/src/threadinitialize.c: Add
SuperCore handler Timestamp to provide an opaque class for the
representation and manipulation of uptime, time of day, and the
difference between two timestamps. By using SuperCore Timestamp, it
is clear which methods and APIs really have to be struct timespec and
which can be in an optimized native format.
* score/include/rtems/score/timestamp.h,
score/src/coretodgetuptimetimespec.c: New files.
* posix/src/sleep.c, posix/src/usleep.c: Add copyright header.
* rtems/src/ratemonreportstatistics.c, rtems/src/timerserver.c:
Minor cleanup to improve testability and eliminate dead code.
* libmisc/cpuuse/cpuusagereport.c, rtems/src/ratemonreportstatistics.c:
Cleaned up reports and fixed a bug related the printf format which
resulted in lack of leading zeroes and misleading magnitude.
* score/src/timespecdivide.c: Fixed bugs related to zero divide case.
* libcsupport/Makefile.am, libcsupport/src/printk.c:
* libcsupport/src/printk_plugin.c: New file.
include/rtems/bspIo.h, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuuse.h, libmisc/stackchk/check.c,
libmisc/stackchk/stackchk.h: rtems/include/rtems/rtems/ratemon.h,
rtems/src/ratemonreportstatistics.c: Added capability to specify
your own "printf" routine to various reporting functions. This
added an XXX_with_plugin as the underlying implementation for
+ rtems_rate_monotonic_report_statistics
+ rtems_stack_checker_report_usage
+ rtems_cpu_usage_report
As demonstration, the http netdemo can now print out stack
and cpu usage reports.
* rtems/src/ratemonperiod.c: Clean up.
* rtems/src/ratemonreportstatistics.c: Clarify period statistics output.
* ChangeLog, configure.ac, libcsupport/src/__times.c,
libmisc/cpuuse/cpuuse.c, libmisc/stackchk/check.c,
rtems/include/rtems/rtems/ratemon.h, rtems/src/ratemongetstatus.c,
rtems/src/ratemonperiod.c, rtems/src/ratemonreportstatistics.c,
rtems/src/ratemonresetall.c, rtems/src/ratemontimeout.c,
score/Makefile.am, score/include/rtems/score/thread.h,
score/include/rtems/score/timespec.h, score/src/threaddispatch.c,
score/src/threadinitialize.c, score/src/threadtickletimeslice.c,
score/src/timespecdivide.c: Add nanoseconds granularity to the rate
monotonic period statistics and CPU usage statistics. This capability
is enabled by default although may be conditionally disabled by the
user. It could be too much overhead on small targets but it does not
appear to be bad in early testing. Its impact on code size has not
been evaluated either. It is possible that both forms of statistics
gathering could be disabled with further tweaking of the conditional
compilation.
* score/src/timespecdividebyinteger.c: New file.
* Makefile.am, preinstall.am, libmisc/Makefile.am, rtems/Makefile.am,
rtems/include/rtems.h, rtems/include/rtems/rtems/ratemon.h,
rtems/inline/rtems/rtems/ratemon.inl, rtems/src/ratemoncancel.c,
rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c,
rtems/src/ratemonperiod.c, rtems/src/ratemontimeout.c,
score/Makefile.am, score/include/rtems/score/object.h,
score/src/threadhandler.c, wrapup/Makefile.am: Integrate Rate
Monotonic Statistics and Period Usage into Rate Monotonic Manager.
Added the following directives: rtems_rate_monotonic_get_statistics,
rtems_rate_monotonic_reset_statistics,
rtems_rate_montonic_reset_all_statistics,
rtems_rate_montonic_report_statistics, and rtems_object_get_name.
Obsoleted the rtems/rtmonuse.h file as a public interface.
* rtems/src/ratemongetstatistics.c,
rtems/src/ratemonreportstatistics.c, rtems/src/ratemonresetall.c,
rtems/src/ratemonresetstatistics.c, rtems/src/rtemsobjectgetname.c,
score/src/objectgetnameasstring.c: New files.
* libmisc/rtmonuse/rtmonuse.c, libmisc/rtmonuse/rtmonuse.h: Removed.
