application visible API.
Move implementation specific parts of part.h and part.inl into new
header file partimpl.h. The part.h contains now only the application
visible API.
Move implementation specific parts of status.h and status.inl into new
header file statusimpl.h. The status.h contains now only the
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8025203
* rtems/include/rtems/rtems/dpmem.h, rtems/include/rtems/rtems/event.h,
rtems/include/rtems/rtems/message.h,
rtems/include/rtems/rtems/part.h,
rtems/include/rtems/rtems/region.h,
rtems/include/rtems/rtems/semmp.h,
rtems/include/rtems/rtems/signal.h,
rtems/include/rtems/rtems/signalmp.h,
rtems/include/rtems/rtems/tasks.h, rtems/include/rtems/rtems/timer.h,
rtems/src/msgqreceive.c, rtems/src/msgqsend.c,
rtems/src/msgqurgent.c, rtems/src/partcreate.c,
rtems/src/partident.c, rtems/src/partreturnbuffer.c,
rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c,
rtems/src/taskident.c, rtems/src/taskissuspended.c,
rtems/src/tasksuspend.c, rtems/src/timercancel.c,
rtems/src/timercreate.c, rtems/src/timerdelete.c,
rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c,
rtems/src/timergetinfo.c, rtems/src/timerident.c,
rtems/src/timerserverfirewhen.c: Changed Objects_Id to rtems_id in
the public API.
* itron/include/rtems/itron/object.h, itron/src/cre_tsk.c,
libblock/src/show_bdbuf.c, libmisc/capture/capture-cli.c,
libmisc/capture/capture.c, libmisc/monitor/mon-manager.c,
libmisc/stackchk/check.c, posix/src/condinit.c,
posix/src/keycreate.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueuenametoid.c,
posix/src/mqueueopen.c, posix/src/mqueueunlink.c,
posix/src/mutexinit.c, posix/src/pbarrierinit.c,
posix/src/prwlockinit.c, posix/src/pspininit.c,
posix/src/pthreadcreate.c, posix/src/pthreadexit.c,
posix/src/semaphorecreatesupp.c, posix/src/semaphorenametoid.c,
posix/src/timercreate.c, rtems/src/barrierident.c,
rtems/src/dpmemident.c, rtems/src/msgqident.c, rtems/src/partident.c,
rtems/src/ratemonident.c, rtems/src/regionident.c,
rtems/src/semident.c, rtems/src/taskident.c, rtems/src/timerident.c,
sapi/src/extensionident.c, score/Makefile.am,
score/inline/rtems/score/object.inl, score/src/apimutexallocate.c,
score/src/objectgetnameasstring.c, score/src/objectmp.c,
score/src/objectnametoid.c: Convert the Objects_Name type from a
* score/src/objectclearname.c, score/src/objectcomparenameraw.c,
score/src/objectcopynamestring.c: Removed.
* rtems/include/rtems.h,
rtems/include/rtems/rtems/asr.h,
rtems/include/rtems/rtems/attr.h,
rtems/include/rtems/rtems/clock.h,
rtems/include/rtems/rtems/config.h,
rtems/include/rtems/rtems/eventset.h,
rtems/include/rtems/rtems/modes.h,
rtems/include/rtems/rtems/msgmp.h,
rtems/include/rtems/rtems/options.h,
rtems/include/rtems/rtems/regionmp.h,
rtems/include/rtems/rtems/sem.h,
rtems/include/rtems/rtems/support.h,
rtems/include/rtems/rtems/taskmp.h,
rtems/inline/rtems/rtems/part.inl,
rtems/inline/rtems/rtems/region.inl,
rtems/macros/rtems/rtems/part.inl,
rtems/src/attr.c,
rtems/src/dpmem.c,
rtems/src/msg.c,
rtems/src/msgmp.c,
rtems/src/msgqsubmit.c,
rtems/src/part.c,
rtems/src/partmp.c,
rtems/src/region.c,
rtems/src/sem.c,
rtems/src/semmp.c,
rtems/src/taskmp.c,
rtems/src/tasks.c,
rtems/src/timerserver.c: Convert to using c99 fixed size types.
* include/rtems.h, include/rtems/rtems/asr.h,
include/rtems/rtems/attr.h, include/rtems/rtems/cache.h,
include/rtems/rtems/clock.h, include/rtems/rtems/config.h,
include/rtems/rtems/dpmem.h, include/rtems/rtems/event.h,
include/rtems/rtems/eventmp.h, include/rtems/rtems/eventset.h,
include/rtems/rtems/intr.h, include/rtems/rtems/message.h,
include/rtems/rtems/modes.h, include/rtems/rtems/mp.h,
include/rtems/rtems/msgmp.h, include/rtems/rtems/options.h,
include/rtems/rtems/part.h, include/rtems/rtems/partmp.h,
include/rtems/rtems/ratemon.h, include/rtems/rtems/region.h,
include/rtems/rtems/regionmp.h, include/rtems/rtems/rtemsapi.h,
include/rtems/rtems/sem.h, include/rtems/rtems/semmp.h,
include/rtems/rtems/signal.h, include/rtems/rtems/signalmp.h,
include/rtems/rtems/status.h, include/rtems/rtems/support.h,
include/rtems/rtems/taskmp.h, include/rtems/rtems/tasks.h,
include/rtems/rtems/timer.h, include/rtems/rtems/types.h,
inline/rtems/rtems/asr.inl, inline/rtems/rtems/attr.inl,
inline/rtems/rtems/dpmem.inl, inline/rtems/rtems/event.inl,
inline/rtems/rtems/eventset.inl, inline/rtems/rtems/message.inl,
inline/rtems/rtems/modes.inl, inline/rtems/rtems/options.inl,
inline/rtems/rtems/part.inl, inline/rtems/rtems/ratemon.inl,
inline/rtems/rtems/region.inl, inline/rtems/rtems/sem.inl,
inline/rtems/rtems/status.inl, inline/rtems/rtems/support.inl,
inline/rtems/rtems/tasks.inl, inline/rtems/rtems/timer.inl,
macros/rtems/rtems/asr.inl, macros/rtems/rtems/attr.inl,
macros/rtems/rtems/dpmem.inl, macros/rtems/rtems/event.inl,
macros/rtems/rtems/eventset.inl, macros/rtems/rtems/message.inl,
macros/rtems/rtems/modes.inl, macros/rtems/rtems/options.inl,
macros/rtems/rtems/part.inl, macros/rtems/rtems/ratemon.inl,
macros/rtems/rtems/region.inl, macros/rtems/rtems/sem.inl,
macros/rtems/rtems/status.inl, macros/rtems/rtems/support.inl,
macros/rtems/rtems/tasks.inl, macros/rtems/rtems/timer.inl,
src/attr.c, src/clockget.c, src/clockset.c, src/clocktick.c,
src/dpmem.c, src/dpmemcreate.c, src/dpmemdelete.c,
src/dpmemexternal2internal.c, src/dpmemident.c,
src/dpmeminternal2external.c, src/event.c, src/eventmp.c,
src/eventreceive.c, src/eventseize.c, src/eventsend.c,
src/eventsurrender.c, src/eventtimeout.c, src/intr.c, src/intrbody.c,
src/intrcatch.c, src/mp.c, src/msg.c, src/msgmp.c,
src/msgqallocate.c, src/msgqbroadcast.c, src/msgqcreate.c,
src/msgqdelete.c, src/msgqflush.c, src/msgqgetnumberpending.c,
src/msgqident.c, src/msgqreceive.c, src/msgqsend.c, src/msgqsubmit.c,
src/msgqtranslatereturncode.c, src/msgqurgent.c, src/part.c,
src/partcreate.c, src/partdelete.c, src/partgetbuffer.c,
src/partident.c, src/partmp.c, src/partreturnbuffer.c, src/ratemon.c,
src/ratemoncancel.c, src/ratemoncreate.c, src/ratemondelete.c,
src/ratemongetstatus.c, src/ratemonident.c, src/ratemonperiod.c,
src/ratemontimeout.c, src/region.c, src/regioncreate.c,
src/regiondelete.c, src/regionextend.c, src/regiongetinfo.c,
src/regiongetsegment.c, src/regiongetsegmentsize.c,
src/regionident.c, src/regionmp.c, src/regionreturnsegment.c,
src/rtclock.c, src/rtemsidtoname.c, src/rtemstimer.c, src/sem.c,
src/semcreate.c, src/semdelete.c, src/semflush.c, src/semident.c,
src/semmp.c, src/semobtain.c, src/semrelease.c,
src/semtranslatereturncode.c, src/signal.c, src/signalcatch.c,
src/signalmp.c, src/signalsend.c, src/taskcreate.c, src/taskdelete.c,
src/taskgetnote.c, src/taskident.c, src/taskinitusers.c,
src/taskissuspended.c, src/taskmode.c, src/taskmp.c,
src/taskrestart.c, src/taskresume.c, src/tasks.c, src/tasksetnote.c,
src/tasksetpriority.c, src/taskstart.c, src/tasksuspend.c,
src/taskvariableadd.c, src/taskvariabledelete.c,
src/taskvariableget.c, src/taskwakeafter.c, src/taskwakewhen.c,
src/timercancel.c, src/timercreate.c, src/timerdelete.c,
src/timerfireafter.c, src/timerfirewhen.c, src/timergetinfo.c,
src/timerident.c, src/timerreset.c, src/timerserver.c,
src/timerserverfireafter.c, src/timerserverfirewhen.c: URL for
license changed.
* Makefile.am, include/rtems.h, include/rtems/rtems/status.h,
src/dpmemident.c, src/msgqident.c, src/partident.c,
src/ratemonident.c, src/regionident.c, src/semident.c,
src/taskident.c, src/timerident.c: Added ID to name lookup service
and changed name of id/name translation status code. This propagated
to multiple functions. The user API service added was
rtems_object_id_to_name()
* src/rtemsidtoname.c: New file.
* src/dpmemcreate.c, src/dpmemident.c, src/msgqcreate.c,
src/msgqident.c, src/partcreate.c, src/partident.c,
src/ratemoncreate.c, src/ratemonident.c, src/regioncreate.c,
src/regionident.c, src/semcreate.c, src/semident.c, src/taskcreate.c,
src/taskident.c, src/timercreate.c, src/timerident.c: Added casts
to Objects_Name to eliminate warnings.
* src/dpmemident.c, src/msgqident.c, src/partident.c,
src/timerident.c: Corrected use of name parameter to
be consistent with fixes implemented to string name processing
which were committed with the POSIX Message Queue update.
