Remove unused supports_global parameter. Convert
_Objects_Initialize_information() to a macro to avoid use of
RTEMS_MULTIPROCESSING define for each caller.
Update #2408.
application visible API.
Move implementation specific parts of part.h and part.inl into new
header file partimpl.h. The part.h contains now only the application
visible API.
http://www.google-melange.com/gci/task/view/google/gci2012/8019205
* rtems/Makefile.am, rtems/include/rtems/rtems/attr.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/dpmem.h, rtems/include/rtems/rtems/intr.h,
rtems/include/rtems/rtems/message.h,
rtems/include/rtems/rtems/part.h,
rtems/include/rtems/rtems/region.h, rtems/include/rtems/rtems/sem.h,
rtems/include/rtems/rtems/tasks.h, rtems/include/rtems/rtems/timer.h,
rtems/src/barrier.c, rtems/src/dpmem.c, rtems/src/msg.c,
rtems/src/part.c, rtems/src/ratemon.c, rtems/src/region.c,
rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/tasks.c,
sapi/src/rtemsapi.c: Convert manager initialization routines to
directly pull parameters from configuration table. Eliminate empty
routines sportted.
* rtems/src/intr.c: Removed.
* rtems/include/rtems.h,
rtems/include/rtems/rtems/asr.h,
rtems/include/rtems/rtems/clock.h,
rtems/include/rtems/rtems/config.h,
rtems/include/rtems/rtems/eventset.h,
rtems/include/rtems/rtems/modes.h,
rtems/include/rtems/rtems/msgmp.h,
rtems/include/rtems/rtems/options.h,
rtems/include/rtems/rtems/regionmp.h,
rtems/include/rtems/rtems/support.h,
rtems/include/rtems/rtems/taskmp.h,
rtems/inline/rtems/rtems/part.inl,
rtems/inline/rtems/rtems/region.inl,
rtems/macros/rtems/rtems/part.inl,
rtems/src/attr.c,
rtems/src/dpmem.c,
rtems/src/msg.c,
rtems/src/msgmp.c,
rtems/src/msgqsend.c,
rtems/src/msgqsubmit.c,
rtems/src/part.c,
rtems/src/partmp.c,
rtems/src/region.c,
rtems/src/sem.c,
rtems/src/semmp.c,
rtems/src/taskmp.c,
rtems/src/tasks.c,
rtems/src/timerserver.c: Convert to using c99 fixed size types.
* include/rtems.h, include/rtems/rtems/asr.h,
include/rtems/rtems/attr.h, include/rtems/rtems/cache.h,
include/rtems/rtems/clock.h, include/rtems/rtems/config.h,
include/rtems/rtems/dpmem.h, include/rtems/rtems/event.h,
include/rtems/rtems/eventmp.h, include/rtems/rtems/eventset.h,
include/rtems/rtems/intr.h, include/rtems/rtems/message.h,
include/rtems/rtems/modes.h, include/rtems/rtems/mp.h,
include/rtems/rtems/msgmp.h, include/rtems/rtems/options.h,
include/rtems/rtems/part.h, include/rtems/rtems/partmp.h,
include/rtems/rtems/ratemon.h, include/rtems/rtems/region.h,
include/rtems/rtems/regionmp.h, include/rtems/rtems/rtemsapi.h,
include/rtems/rtems/sem.h, include/rtems/rtems/semmp.h,
include/rtems/rtems/signal.h, include/rtems/rtems/signalmp.h,
include/rtems/rtems/status.h, include/rtems/rtems/support.h,
include/rtems/rtems/taskmp.h, include/rtems/rtems/tasks.h,
include/rtems/rtems/timer.h, include/rtems/rtems/types.h,
inline/rtems/rtems/asr.inl, inline/rtems/rtems/attr.inl,
inline/rtems/rtems/dpmem.inl, inline/rtems/rtems/event.inl,
inline/rtems/rtems/eventset.inl, inline/rtems/rtems/message.inl,
inline/rtems/rtems/modes.inl, inline/rtems/rtems/options.inl,
inline/rtems/rtems/part.inl, inline/rtems/rtems/ratemon.inl,
inline/rtems/rtems/region.inl, inline/rtems/rtems/sem.inl,
inline/rtems/rtems/status.inl, inline/rtems/rtems/support.inl,
inline/rtems/rtems/tasks.inl, inline/rtems/rtems/timer.inl,
macros/rtems/rtems/asr.inl, macros/rtems/rtems/attr.inl,
macros/rtems/rtems/dpmem.inl, macros/rtems/rtems/event.inl,
macros/rtems/rtems/eventset.inl, macros/rtems/rtems/message.inl,
macros/rtems/rtems/modes.inl, macros/rtems/rtems/options.inl,
macros/rtems/rtems/part.inl, macros/rtems/rtems/ratemon.inl,
macros/rtems/rtems/region.inl, macros/rtems/rtems/sem.inl,
macros/rtems/rtems/status.inl, macros/rtems/rtems/support.inl,
macros/rtems/rtems/tasks.inl, macros/rtems/rtems/timer.inl,
src/attr.c, src/clockget.c, src/clockset.c, src/clocktick.c,
src/dpmem.c, src/dpmemcreate.c, src/dpmemdelete.c,
src/dpmemexternal2internal.c, src/dpmemident.c,
src/dpmeminternal2external.c, src/event.c, src/eventmp.c,
src/eventreceive.c, src/eventseize.c, src/eventsend.c,
src/eventsurrender.c, src/eventtimeout.c, src/intr.c, src/intrbody.c,
src/intrcatch.c, src/mp.c, src/msg.c, src/msgmp.c,
src/msgqallocate.c, src/msgqbroadcast.c, src/msgqcreate.c,
src/msgqdelete.c, src/msgqflush.c, src/msgqgetnumberpending.c,
src/msgqident.c, src/msgqreceive.c, src/msgqsend.c, src/msgqsubmit.c,
src/msgqtranslatereturncode.c, src/msgqurgent.c, src/part.c,
src/partcreate.c, src/partdelete.c, src/partgetbuffer.c,
src/partident.c, src/partmp.c, src/partreturnbuffer.c, src/ratemon.c,
src/ratemoncancel.c, src/ratemoncreate.c, src/ratemondelete.c,
src/ratemongetstatus.c, src/ratemonident.c, src/ratemonperiod.c,
src/ratemontimeout.c, src/region.c, src/regioncreate.c,
src/regiondelete.c, src/regionextend.c, src/regiongetinfo.c,
src/regiongetsegment.c, src/regiongetsegmentsize.c,
src/regionident.c, src/regionmp.c, src/regionreturnsegment.c,
src/rtclock.c, src/rtemsidtoname.c, src/rtemstimer.c, src/sem.c,
src/semcreate.c, src/semdelete.c, src/semflush.c, src/semident.c,
src/semmp.c, src/semobtain.c, src/semrelease.c,
src/semtranslatereturncode.c, src/signal.c, src/signalcatch.c,
src/signalmp.c, src/signalsend.c, src/taskcreate.c, src/taskdelete.c,
src/taskgetnote.c, src/taskident.c, src/taskinitusers.c,
src/taskissuspended.c, src/taskmode.c, src/taskmp.c,
src/taskrestart.c, src/taskresume.c, src/tasks.c, src/tasksetnote.c,
src/tasksetpriority.c, src/taskstart.c, src/tasksuspend.c,
src/taskvariableadd.c, src/taskvariabledelete.c,
src/taskvariableget.c, src/taskwakeafter.c, src/taskwakewhen.c,
src/timercancel.c, src/timercreate.c, src/timerdelete.c,
src/timerfireafter.c, src/timerfirewhen.c, src/timergetinfo.c,
src/timerident.c, src/timerreset.c, src/timerserver.c,
src/timerserverfireafter.c, src/timerserverfirewhen.c: URL for
license changed.
* src/msg.c, src/part.c, src/sem.c, src/tasks.c: Correct object
class control structure initialization for multiprocessing
configurations.
* Mega patch merge to change the format of the object IDs to
loosen the dependency between the SCORE and the various APIs.
There was considerable work to simplify the object name management
and it appears that the name_table field is no longer needed.
This patch also includes the addition of the internal mutex
which is currently only used to protect some types of allocation
and deallocation. This significantly can reduce context
switch latency under certain circumstances. In particular,
some heap/region operations were O(n) and had dispatching
disabled. This should help enormously. With this merge,
the patch is not as clean as it should be. In particular,
the documentation has not been modified to reflect the new object
ID layout, the IDs in the test screens are not updated, and
_Objects_Get_information needs to be a real routine not inlined.
As part of this patch a lot of MP code for thread/proxy blocking
was made conditional and cleaned up.
* include/rtems.h, inline/rtems/rtems/region.inl,
macros/rtems/rtems/region.inl, src/dpmem.c, src/dpmemcreate.c,
src/msg.c, src/msgqcreate.c, src/part.c, src/partcreate.c,
src/ratemon.c, src/ratemoncreate.c, src/region.c, src/regioncreate.c,
src/regionident.c, src/regionreturnsegment.c, src/rtemstimer.c,
src/sem.c, src/semcreate.c, src/taskcreate.c, src/taskident.c,
src/tasks.c, src/timercreate.c: Modified as part of above.
it work.
like signal dispatching.
correct Information block.
+ Added name pointer to Object_Control.
+ Modified Object Open and Close to address name field.
+ Removed name as separate element from Thread and Proxy Control.
+ Added parameter "object class" to calls to Initialize Information
