path: root/cpukit/rtems/src/msgqflush.c (follow)
* 2009-12-15 Glenn Humphrey <glenn.humphrey@OARcorp.com>Glenn Humphrey2009-12-151-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * rtems/include/rtems/rtems/dpmem.h, rtems/include/rtems/rtems/event.h, rtems/include/rtems/rtems/message.h, rtems/include/rtems/rtems/part.h, rtems/include/rtems/rtems/ratemon.h, rtems/include/rtems/rtems/region.h, rtems/include/rtems/rtems/semmp.h, rtems/include/rtems/rtems/signal.h, rtems/include/rtems/rtems/signalmp.h, rtems/include/rtems/rtems/tasks.h, rtems/include/rtems/rtems/timer.h, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/eventsend.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c, rtems/src/msgqurgent.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partreturnbuffer.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskissuspended.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/tasksuspend.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c: Changed Objects_Id to rtems_id in the public API.
* 2007-11-30 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-11-301-7/+8
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * rtems/src/barrierdelete.c, rtems/src/barrierrelease.c, rtems/src/barriertranslatereturncode.c, rtems/src/barrierwait.c, rtems/src/clockget.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmeminternal2external.c, rtems/src/eventsend.c, rtems/src/eventtimeout.c, rtems/src/msgqbroadcast.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c, rtems/src/msgqurgent.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partreturnbuffer.c, rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signalsend.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskissuspended.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c, rtems/src/timercancel.c, rtems/src/timerdelete.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c: Restructured all code with the switch (location) pattern so that OBJECTS_LOCAL is first and we can fall into it and the OBJECTS_ERROR case breaks to a return RTEMS_INVALID_ID. This eliminates the return RTEMS_INTERNAL_ERROR at the bottom of each of these files which was unreachable and untestable code. This resulted in a code savings of approximately 20 bytes per file on the SPARC/ERC32.
* 2007-10-26 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-10-261-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * itron/src/can_wup.c, itron/src/chg_pri.c, itron/src/del_mbf.c, itron/src/del_mbx.c, itron/src/del_sem.c, itron/src/del_tsk.c, itron/src/frsm_tsk.c, itron/src/ref_mbf.c, itron/src/ref_mbx.c, itron/src/ref_sem.c, itron/src/ref_tsk.c, itron/src/rel_wai.c, itron/src/rsm_tsk.c, itron/src/sig_sem.c, itron/src/snd_mbx.c, itron/src/sta_tsk.c, itron/src/sus_tsk.c, itron/src/ter_tsk.c, itron/src/trcv_mbf.c, itron/src/trcv_mbx.c, itron/src/tsnd_mbf.c, itron/src/twai_sem.c, posix/src/cancel.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignalsupp.c, posix/src/condwaitsupp.c, posix/src/keydelete.c, posix/src/keygetspecific.c, posix/src/keysetspecific.c, posix/src/mqueueclose.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c, posix/src/pbarrierdestroy.c, posix/src/pbarrierwait.c, posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c, posix/src/pspindestroy.c, posix/src/pspinlock.c, posix/src/pspintrylock.c, posix/src/pspinunlock.c, posix/src/pthreaddetach.c, posix/src/pthreadequal.c, posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c, posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c, posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c, rtems/src/barrierdelete.c, rtems/src/barrierrelease.c, rtems/src/barrierwait.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmeminternal2external.c, rtems/src/eventsend.c, rtems/src/eventtimeout.c, rtems/src/msgqbroadcast.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c, rtems/src/msgqurgent.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partreturnbuffer.c, rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/signalsend.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskissuspended.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c, rtems/src/timercancel.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/extensiondelete.c, score/include/rtems/score/object.h, score/src/corerwlocktimeout.c, score/src/mpci.c, score/src/objectgetnameasstring.c, score/src/threaddelayended.c, score/src/threadqtimeout.c: When multiprocessing is disabled, do not even allow the constant OBJECTS_REMOTE to appear in the source. Even at -O2, the presence of a case OBJECTS_REMOTE in each id->pointer _Objects_Get switch results in the generation of binary code which can NOT be reached.
* Include config.h.Ralf Corsepius2005-01-181-0/+4
* 2004-05-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-05-061-0/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 618/rtems * rtems/include/rtems/rtems/status.h, rtems/src/clockget.c, rtems/src/clockset.c, rtems/src/dpmemcreate.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmeminternal2external.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventsend.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c, rtems/src/msgqsubmit.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionreturnsegment.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/taskcreate.c, rtems/src/taskgetnote.c, rtems/src/taskmode.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasksetnote.c, rtems/src/tasksuspend.c, rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c, rtems/src/taskwakewhen.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, score/include/rtems/score/object.h, score/src/coretodvalidate.c, score/src/objectnametoid.c: Add NULL checks.
* 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-291-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * rtems/include/rtems.h, rtems/include/rtems/rtems/asr.h, rtems/include/rtems/rtems/attr.h, rtems/include/rtems/rtems/clock.h, rtems/include/rtems/rtems/config.h, rtems/include/rtems/rtems/dpmem.h, rtems/include/rtems/rtems/eventset.h, rtems/include/rtems/rtems/message.h, rtems/include/rtems/rtems/modes.h, rtems/include/rtems/rtems/msgmp.h, rtems/include/rtems/rtems/options.h, rtems/include/rtems/rtems/part.h, rtems/include/rtems/rtems/ratemon.h, rtems/include/rtems/rtems/region.h, rtems/include/rtems/rtems/regionmp.h, rtems/include/rtems/rtems/sem.h, rtems/include/rtems/rtems/support.h, rtems/include/rtems/rtems/taskmp.h, rtems/include/rtems/rtems/tasks.h, rtems/include/rtems/rtems/timer.h, rtems/inline/rtems/rtems/part.inl, rtems/inline/rtems/rtems/region.inl, rtems/macros/rtems/rtems/part.inl, rtems/src/attr.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmeminternal2external.c, rtems/src/eventseize.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c, rtems/src/msgqsubmit.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/ratemon.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regionextend.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionmp.c, rtems/src/regionreturnsegment.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semtranslatereturncode.c, rtems/src/taskcreate.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/taskstart.c, rtems/src/timerserver.c: Convert to using c99 fixed size types.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems.h, include/rtems/rtems/asr.h, include/rtems/rtems/attr.h, include/rtems/rtems/cache.h, include/rtems/rtems/clock.h, include/rtems/rtems/config.h, include/rtems/rtems/dpmem.h, include/rtems/rtems/event.h, include/rtems/rtems/eventmp.h, include/rtems/rtems/eventset.h, include/rtems/rtems/intr.h, include/rtems/rtems/message.h, include/rtems/rtems/modes.h, include/rtems/rtems/mp.h, include/rtems/rtems/msgmp.h, include/rtems/rtems/options.h, include/rtems/rtems/part.h, include/rtems/rtems/partmp.h, include/rtems/rtems/ratemon.h, include/rtems/rtems/region.h, include/rtems/rtems/regionmp.h, include/rtems/rtems/rtemsapi.h, include/rtems/rtems/sem.h, include/rtems/rtems/semmp.h, include/rtems/rtems/signal.h, include/rtems/rtems/signalmp.h, include/rtems/rtems/status.h, include/rtems/rtems/support.h, include/rtems/rtems/taskmp.h, include/rtems/rtems/tasks.h, include/rtems/rtems/timer.h, include/rtems/rtems/types.h, inline/rtems/rtems/asr.inl, inline/rtems/rtems/attr.inl, inline/rtems/rtems/dpmem.inl, inline/rtems/rtems/event.inl, inline/rtems/rtems/eventset.inl, inline/rtems/rtems/message.inl, inline/rtems/rtems/modes.inl, inline/rtems/rtems/options.inl, inline/rtems/rtems/part.inl, inline/rtems/rtems/ratemon.inl, inline/rtems/rtems/region.inl, inline/rtems/rtems/sem.inl, inline/rtems/rtems/status.inl, inline/rtems/rtems/support.inl, inline/rtems/rtems/tasks.inl, inline/rtems/rtems/timer.inl, macros/rtems/rtems/asr.inl, macros/rtems/rtems/attr.inl, macros/rtems/rtems/dpmem.inl, macros/rtems/rtems/event.inl, macros/rtems/rtems/eventset.inl, macros/rtems/rtems/message.inl, macros/rtems/rtems/modes.inl, macros/rtems/rtems/options.inl, macros/rtems/rtems/part.inl, macros/rtems/rtems/ratemon.inl, macros/rtems/rtems/region.inl, macros/rtems/rtems/sem.inl, macros/rtems/rtems/status.inl, macros/rtems/rtems/support.inl, macros/rtems/rtems/tasks.inl, macros/rtems/rtems/timer.inl, src/attr.c, src/clockget.c, src/clockset.c, src/clocktick.c, src/dpmem.c, src/dpmemcreate.c, src/dpmemdelete.c, src/dpmemexternal2internal.c, src/dpmemident.c, src/dpmeminternal2external.c, src/event.c, src/eventmp.c, src/eventreceive.c, src/eventseize.c, src/eventsend.c, src/eventsurrender.c, src/eventtimeout.c, src/intr.c, src/intrbody.c, src/intrcatch.c, src/mp.c, src/msg.c, src/msgmp.c, src/msgqallocate.c, src/msgqbroadcast.c, src/msgqcreate.c, src/msgqdelete.c, src/msgqflush.c, src/msgqgetnumberpending.c, src/msgqident.c, src/msgqreceive.c, src/msgqsend.c, src/msgqsubmit.c, src/msgqtranslatereturncode.c, src/msgqurgent.c, src/part.c, src/partcreate.c, src/partdelete.c, src/partgetbuffer.c, src/partident.c, src/partmp.c, src/partreturnbuffer.c, src/ratemon.c, src/ratemoncancel.c, src/ratemoncreate.c, src/ratemondelete.c, src/ratemongetstatus.c, src/ratemonident.c, src/ratemonperiod.c, src/ratemontimeout.c, src/region.c, src/regioncreate.c, src/regiondelete.c, src/regionextend.c, src/regiongetinfo.c, src/regiongetsegment.c, src/regiongetsegmentsize.c, src/regionident.c, src/regionmp.c, src/regionreturnsegment.c, src/rtclock.c, src/rtemsidtoname.c, src/rtemstimer.c, src/sem.c, src/semcreate.c, src/semdelete.c, src/semflush.c, src/semident.c, src/semmp.c, src/semobtain.c, src/semrelease.c, src/semtranslatereturncode.c, src/signal.c, src/signalcatch.c, src/signalmp.c, src/signalsend.c, src/taskcreate.c, src/taskdelete.c, src/taskgetnote.c, src/taskident.c, src/taskinitusers.c, src/taskissuspended.c, src/taskmode.c, src/taskmp.c, src/taskrestart.c, src/taskresume.c, src/tasks.c, src/tasksetnote.c, src/tasksetpriority.c, src/taskstart.c, src/tasksuspend.c, src/taskvariableadd.c, src/taskvariabledelete.c, src/taskvariableget.c, src/taskwakeafter.c, src/taskwakewhen.c, src/timercancel.c, src/timercreate.c, src/timerdelete.c, src/timerfireafter.c, src/timerfirewhen.c, src/timergetinfo.c, src/timerident.c, src/timerreset.c, src/timerserver.c, src/timerserverfireafter.c, src/timerserverfirewhen.c: URL for license changed.
* Split Message Manager into one routine per file.Joel Sherrill1999-05-171-0/+87
