Use common phrases for the file brief descriptions.
Update #3706.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Add _Thread_queue_Context_set_MP_callout() to simplify
_Thread_queue_Context_initialize(). This makes it possible to more
easily add additional fields to Thread_queue_Context.
Unify the status codes of the Classic and POSIX API to use the new enum
Status_Control. This eliminates the Thread_Control::Wait::timeout_code
field and the timeout parameter of _Thread_queue_Enqueue_critical() and
_MPCI_Send_request_packet(). It gets rid of the status code translation
tables and instead uses simple bit operations to get the status for a
particular API. This enables translation of status code constants at
compile time. Add _Thread_Wait_get_status() to avoid direct access of
thread internal data structures.
Drop the multiprocessing (MP) dependent callout parameter from the
thread queue extract, dequeue, flush and unblock methods. Merge this
parameter with the lock context into new structure Thread_queue_Context.
This helps to gets rid of the conditionally compiled method call
helpers.
Get rid of the mp_id parameter used for some thread queue methods. Use
THREAD_QUEUE_QUEUE_TO_OBJECT() instead.
Uniformly use *_Get() to get an object by identifier with a lock
context.
Use _Objects_Get_local() for _Message_queue_Get_interrupt_disable() to
get rid of the location parameter. Move remote object handling to
message queue MPCI support.
The thread queue implementation was heavily reworked to support SMP.
This broke the multiprocessing support of the thread queues. This is
fixed by this patch.
A thread proxy is unblocked due to three reasons
1) timeout,
2) request satisfaction, and
3) extraction.
In case 1) no MPCI message must be sent. This is ensured via the
_Thread_queue_MP_callout_do_nothing() callout set during
_Thread_MP_Allocate_proxy().
In case 2) and 3) an MPCI message must be sent. In case we interrupt
the blocking operation during _Thread_queue_Enqueue_critical(), then
this message must be sent by the blocking thread. For this the new
fields Thread_Proxy_control::thread_queue_callout and
Thread_Proxy_control::thread_queue_id are used.
Delete the individual API MP callout types and use
Thread_queue_MP_callout throughout. This type is only defined in
multiprocessing configurations. Prefix the multiprocessing parameters
with mp_ to ease code review. Multiprocessing specific parameters are
optional due to use of a similar macro pattern. There is no overhead
for non-multiprocessing configurations.
Aggregate several critical sections into a bigger one. Sending and
receiving messages is now protected by an ISR lock. Thread dispatching
is only disabled in case a blocking operation is necessary. The message
copy procedure is done inside the critical section (interrupts
disabled). Thus this change may have a negative impact on the interrupt
latency in case very large messages are transferred.
Update #2273.
application visible API.
Move implementation specific parts of mpci.h into new header file
mpciimpl.h. The mpci.h contains now only the application visible API.
Move implementation specific parts of states.h and states.inl into new
header file statesimpl.h. The states.h contains now only the
Move implementation specific parts of attr.h and attr.inl into new
header file attrimpl.h. The attr.h contains now only the application
visible API.
Move implementation specific parts of coremsg.h and coremsg.inl into new
header file coremsgimpl.h. The coremsg.h contains now only the
Move implementation specific parts of message.h and message.inl into new
header file messageimpl.h. The message.h contains now only the
Add and use _Objects_Put_without_thread_dispatch(). These two functions
pair with the _Objects_Get() function. This helps to introduce object
specific SMP locks to avoid lock contention.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8025203
* rtems/include/rtems/rtems/dpmem.h, rtems/include/rtems/rtems/event.h,
rtems/include/rtems/rtems/message.h,
rtems/include/rtems/rtems/part.h,
rtems/include/rtems/rtems/region.h,
rtems/include/rtems/rtems/semmp.h,
rtems/include/rtems/rtems/signal.h,
rtems/include/rtems/rtems/signalmp.h,
rtems/include/rtems/rtems/tasks.h, rtems/include/rtems/rtems/timer.h,
rtems/src/msgqreceive.c, rtems/src/msgqsend.c,
rtems/src/msgqurgent.c, rtems/src/partcreate.c,
rtems/src/partident.c, rtems/src/partreturnbuffer.c,
rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c,
rtems/src/taskident.c, rtems/src/taskissuspended.c,
rtems/src/tasksuspend.c, rtems/src/timercancel.c,
rtems/src/timercreate.c, rtems/src/timerdelete.c,
rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c,
rtems/src/timergetinfo.c, rtems/src/timerident.c,
rtems/src/timerserverfirewhen.c: Changed Objects_Id to rtems_id in
the public API.
* rtems/include/rtems/rtems/sem.h, rtems/src/semobtain.c:
Changed option set type to rtems_option.
* score/src/objectgetinfo.c: Check return value of
_Objects_API_maximum_class().
* libmisc/monitor/mon-mpci.c, libmisc/monitor/monitor.h,
rtems/include/rtems/rtems/message.h, rtems/src/msgmp.c,
rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c,
rtems/src/msgqcreate.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c,
rtems/src/msgqurgent.c, score/include/rtems/score/coremsg.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/thread.h,
score/inline/rtems/score/coremsg.inl, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgseize.c,
score/src/coremsgsubmit.c:
Removed parameters of _Message_queue_Allocate(). Changed option set
type to rtems_option. Changed type of maximum message and packet size
to size_t. Changed the input buffer type for message send functions to
"const void *". Changed the pointer to the second return argument in
the thread wait information to a union. This union can contain a
pointer to an immutable or a mutable object. This is somewhat fragile.
An alternative would be to add a third pointer for immutable objects,
but this would increase the structure size.
* rtems/src/barrierdelete.c, rtems/src/barrierrelease.c,
rtems/src/barriertranslatereturncode.c, rtems/src/barrierwait.c,
rtems/src/clockget.c, rtems/src/dpmemdelete.c,
rtems/src/eventtimeout.c, rtems/src/msgqbroadcast.c,
rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c,
rtems/src/msgqsend.c, rtems/src/msgqurgent.c, rtems/src/partdelete.c,
rtems/src/partgetbuffer.c, rtems/src/partreturnbuffer.c,
rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c,
rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c,
rtems/src/ratemontimeout.c, rtems/src/semdelete.c,
rtems/src/semflush.c, rtems/src/semobtain.c, rtems/src/semrelease.c,
rtems/src/semtranslatereturncode.c, rtems/src/signalsend.c,
rtems/src/taskissuspended.c, rtems/src/taskrestart.c,
rtems/src/taskresume.c, rtems/src/tasksetnote.c,
rtems/src/tasksetpriority.c, rtems/src/taskstart.c,
rtems/src/tasksuspend.c, rtems/src/taskvariableadd.c,
rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c,
rtems/src/timercancel.c, rtems/src/timerdelete.c,
rtems/src/timerserverfirewhen.c: Restructured all code with
the switch (location) pattern so that OBJECTS_LOCAL is first
and we can fall into it and the OBJECTS_ERROR case breaks
to a return RTEMS_INVALID_ID. This eliminates the return
RTEMS_INTERNAL_ERROR at the bottom of each of these files which
was unreachable and untestable code. This resulted in a code
savings of approximately 20 bytes per file on the SPARC/ERC32.
* itron/src/can_wup.c, itron/src/chg_pri.c, itron/src/del_mbf.c,
itron/src/del_mbx.c, itron/src/del_sem.c, itron/src/del_tsk.c,
itron/src/frsm_tsk.c, itron/src/ref_mbf.c, itron/src/ref_mbx.c,
itron/src/ref_sem.c, itron/src/ref_tsk.c, itron/src/rel_wai.c,
itron/src/rsm_tsk.c, itron/src/sig_sem.c, itron/src/snd_mbx.c,
itron/src/sta_tsk.c, itron/src/sus_tsk.c, itron/src/ter_tsk.c,
itron/src/trcv_mbf.c, itron/src/trcv_mbx.c, itron/src/tsnd_mbf.c,
itron/src/twai_sem.c, posix/src/cancel.c, posix/src/conddestroy.c,
posix/src/condinit.c, posix/src/condsignalsupp.c,
posix/src/condwaitsupp.c, posix/src/keydelete.c,
posix/src/keygetspecific.c, posix/src/keysetspecific.c,
posix/src/mqueueclose.c, posix/src/mqueuegetattr.c,
posix/src/mutexinit.c, posix/src/mutexlocksupp.c,
posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c,
posix/src/pbarrierdestroy.c, posix/src/pbarrierwait.c,
posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c,
posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c,
posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c,
posix/src/pspindestroy.c, posix/src/pspinlock.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/pthreaddetach.c, posix/src/pthreadequal.c,
posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c,
posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c,
posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c,
rtems/src/barrierwait.c, rtems/src/dpmemdelete.c,
rtems/src/ratemontimeout.c, rtems/src/regiondelete.c,
rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c,
rtems/src/regionreturnsegment.c, rtems/src/semdelete.c,
rtems/src/signalsend.c, rtems/src/taskdelete.c,
rtems/src/taskgetnote.c, rtems/src/taskissuspended.c,
rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c,
rtems/src/taskvariableget.c, rtems/src/timercancel.c,
rtems/src/timerserverfirewhen.c, sapi/src/extensiondelete.c,
score/include/rtems/score/object.h, score/src/corerwlocktimeout.c,
score/src/mpci.c, score/src/objectgetnameasstring.c,
score/src/threaddelayended.c, score/src/threadqtimeout.c: When
multiprocessing is disabled, do not even allow the constant
OBJECTS_REMOTE to appear in the source. Even at -O2, the presence of
a case OBJECTS_REMOTE in each id->pointer _Objects_Get switch results
in the generation of binary code which can NOT be reached.
PR 618/rtems
* rtems/include/rtems/rtems/status.h, rtems/src/clockget.c,
rtems/src/clockset.c, rtems/src/dpmemcreate.c,
rtems/src/dpmeminternal2external.c, rtems/src/eventmp.c,
rtems/src/eventreceive.c, rtems/src/eventsend.c,
rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c,
rtems/src/msgqreceive.c, rtems/src/msgqsubmit.c,
rtems/src/partcreate.c, rtems/src/partdelete.c,
rtems/src/partgetbuffer.c, rtems/src/ratemoncancel.c,
rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c,
rtems/src/ratemonperiod.c, rtems/src/regioncreate.c,
rtems/src/regiondelete.c, rtems/src/regionextend.c,
rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c,
rtems/src/regionreturnsegment.c, rtems/src/semcreate.c,
rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c,
rtems/src/taskcreate.c, rtems/src/taskgetnote.c,
rtems/src/taskmode.c, rtems/src/taskrestart.c,
rtems/src/taskwakewhen.c, rtems/src/timercreate.c,
rtems/src/timerfirewhen.c, rtems/src/timerserverfireafter.c,
rtems/src/timerserverfirewhen.c, score/include/rtems/score/object.h,
score/src/coretodvalidate.c, score/src/objectnametoid.c: Add NULL
checks.
* rtems/include/rtems.h,
rtems/include/rtems/rtems/asr.h,
rtems/include/rtems/rtems/attr.h,
rtems/include/rtems/rtems/clock.h,
rtems/include/rtems/rtems/config.h,
rtems/include/rtems/rtems/eventset.h,
rtems/include/rtems/rtems/modes.h,
rtems/include/rtems/rtems/msgmp.h,
rtems/include/rtems/rtems/options.h,
rtems/include/rtems/rtems/regionmp.h,
rtems/include/rtems/rtems/support.h,
rtems/include/rtems/rtems/taskmp.h,
rtems/inline/rtems/rtems/part.inl,
rtems/inline/rtems/rtems/region.inl,
rtems/macros/rtems/rtems/part.inl,
rtems/src/attr.c,
rtems/src/dpmem.c,
rtems/src/msg.c,
rtems/src/msgmp.c,
rtems/src/part.c,
rtems/src/partmp.c,
rtems/src/region.c,
rtems/src/sem.c,
rtems/src/semmp.c,
rtems/src/taskmp.c,
rtems/src/tasks.c,
rtems/src/timerserver.c: Convert to using c99 fixed size types.
* include/rtems.h, include/rtems/rtems/asr.h,
include/rtems/rtems/attr.h, include/rtems/rtems/cache.h,
include/rtems/rtems/clock.h, include/rtems/rtems/config.h,
include/rtems/rtems/dpmem.h, include/rtems/rtems/event.h,
include/rtems/rtems/eventmp.h, include/rtems/rtems/eventset.h,
include/rtems/rtems/intr.h, include/rtems/rtems/message.h,
include/rtems/rtems/modes.h, include/rtems/rtems/mp.h,
include/rtems/rtems/msgmp.h, include/rtems/rtems/options.h,
include/rtems/rtems/part.h, include/rtems/rtems/partmp.h,
include/rtems/rtems/ratemon.h, include/rtems/rtems/region.h,
include/rtems/rtems/regionmp.h, include/rtems/rtems/rtemsapi.h,
include/rtems/rtems/sem.h, include/rtems/rtems/semmp.h,
include/rtems/rtems/signal.h, include/rtems/rtems/signalmp.h,
include/rtems/rtems/status.h, include/rtems/rtems/support.h,
include/rtems/rtems/taskmp.h, include/rtems/rtems/tasks.h,
include/rtems/rtems/timer.h, include/rtems/rtems/types.h,
inline/rtems/rtems/asr.inl, inline/rtems/rtems/attr.inl,
inline/rtems/rtems/dpmem.inl, inline/rtems/rtems/event.inl,
inline/rtems/rtems/eventset.inl, inline/rtems/rtems/message.inl,
inline/rtems/rtems/modes.inl, inline/rtems/rtems/options.inl,
inline/rtems/rtems/part.inl, inline/rtems/rtems/ratemon.inl,
inline/rtems/rtems/region.inl, inline/rtems/rtems/sem.inl,
inline/rtems/rtems/status.inl, inline/rtems/rtems/support.inl,
inline/rtems/rtems/tasks.inl, inline/rtems/rtems/timer.inl,
macros/rtems/rtems/asr.inl, macros/rtems/rtems/attr.inl,
macros/rtems/rtems/dpmem.inl, macros/rtems/rtems/event.inl,
macros/rtems/rtems/eventset.inl, macros/rtems/rtems/message.inl,
macros/rtems/rtems/modes.inl, macros/rtems/rtems/options.inl,
macros/rtems/rtems/part.inl, macros/rtems/rtems/ratemon.inl,
macros/rtems/rtems/region.inl, macros/rtems/rtems/sem.inl,
macros/rtems/rtems/status.inl, macros/rtems/rtems/support.inl,
macros/rtems/rtems/tasks.inl, macros/rtems/rtems/timer.inl,
src/attr.c, src/clockget.c, src/clockset.c, src/clocktick.c,
src/dpmem.c, src/dpmemcreate.c, src/dpmemdelete.c,
src/dpmemexternal2internal.c, src/dpmemident.c,
src/dpmeminternal2external.c, src/event.c, src/eventmp.c,
src/eventreceive.c, src/eventseize.c, src/eventsend.c,
src/eventsurrender.c, src/eventtimeout.c, src/intr.c, src/intrbody.c,
src/intrcatch.c, src/mp.c, src/msg.c, src/msgmp.c,
src/msgqallocate.c, src/msgqbroadcast.c, src/msgqcreate.c,
src/msgqdelete.c, src/msgqflush.c, src/msgqgetnumberpending.c,
src/msgqident.c, src/msgqreceive.c, src/msgqsend.c, src/msgqsubmit.c,
src/msgqtranslatereturncode.c, src/msgqurgent.c, src/part.c,
src/partcreate.c, src/partdelete.c, src/partgetbuffer.c,
src/partident.c, src/partmp.c, src/partreturnbuffer.c, src/ratemon.c,
src/ratemoncancel.c, src/ratemoncreate.c, src/ratemondelete.c,
src/ratemongetstatus.c, src/ratemonident.c, src/ratemonperiod.c,
src/ratemontimeout.c, src/region.c, src/regioncreate.c,
src/regiondelete.c, src/regionextend.c, src/regiongetinfo.c,
src/regiongetsegment.c, src/regiongetsegmentsize.c,
src/regionident.c, src/regionmp.c, src/regionreturnsegment.c,
src/rtclock.c, src/rtemsidtoname.c, src/rtemstimer.c, src/sem.c,
src/semcreate.c, src/semdelete.c, src/semflush.c, src/semident.c,
src/semmp.c, src/semobtain.c, src/semrelease.c,
src/semtranslatereturncode.c, src/signal.c, src/signalcatch.c,
src/signalmp.c, src/signalsend.c, src/taskcreate.c, src/taskdelete.c,
src/taskgetnote.c, src/taskident.c, src/taskinitusers.c,
src/taskissuspended.c, src/taskmode.c, src/taskmp.c,
src/taskrestart.c, src/taskresume.c, src/tasks.c, src/tasksetnote.c,
src/tasksetpriority.c, src/taskstart.c, src/tasksuspend.c,
src/taskvariableadd.c, src/taskvariabledelete.c,
src/taskvariableget.c, src/taskwakeafter.c, src/taskwakewhen.c,
src/timercancel.c, src/timercreate.c, src/timerdelete.c,
src/timerfireafter.c, src/timerfirewhen.c, src/timergetinfo.c,
src/timerident.c, src/timerreset.c, src/timerserver.c,
src/timerserverfireafter.c, src/timerserverfirewhen.c: URL for
license changed.
