Move implementation specific parts of message.h and message.inl into new
header file messageimpl.h. The message.h contains now only the
application visible API.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8025204
the size of the BSS section when an optional manageer stub is used. Some tests showed about a 600 byte reduction in BSS size. Also eliminated the variables _RTEMS_tasks_User_initialization_tasks and _RTEMS_tasks_Number_of_initialization_tasks because they were only used in one place after initialized. It was a waste of space.
