path: root/cpukit/rtems/src/mp.c (follow)
* rtems: Delete empty functionSebastian Huber2015-12-151-4/+0
* score: Create mpci implementation headerSebastian Huber2013-07-261-3/+1
| | | | | Move implementation specific parts of mpci.h into new header file mpciimpl.h. The mpci.h contains now only the application visible API.
* cpukit: Clean up Doxygen #3 (GCI 2012)Alex Ivanov2012-12-031-13/+7
* 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-07-241-4/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script.
* Include config.h.Ralf Corsepius2005-01-181-0/+4
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems.h, include/rtems/rtems/asr.h, include/rtems/rtems/attr.h, include/rtems/rtems/cache.h, include/rtems/rtems/clock.h, include/rtems/rtems/config.h, include/rtems/rtems/dpmem.h, include/rtems/rtems/event.h, include/rtems/rtems/eventmp.h, include/rtems/rtems/eventset.h, include/rtems/rtems/intr.h, include/rtems/rtems/message.h, include/rtems/rtems/modes.h, include/rtems/rtems/mp.h, include/rtems/rtems/msgmp.h, include/rtems/rtems/options.h, include/rtems/rtems/part.h, include/rtems/rtems/partmp.h, include/rtems/rtems/ratemon.h, include/rtems/rtems/region.h, include/rtems/rtems/regionmp.h, include/rtems/rtems/rtemsapi.h, include/rtems/rtems/sem.h, include/rtems/rtems/semmp.h, include/rtems/rtems/signal.h, include/rtems/rtems/signalmp.h, include/rtems/rtems/status.h, include/rtems/rtems/support.h, include/rtems/rtems/taskmp.h, include/rtems/rtems/tasks.h, include/rtems/rtems/timer.h, include/rtems/rtems/types.h, inline/rtems/rtems/asr.inl, inline/rtems/rtems/attr.inl, inline/rtems/rtems/dpmem.inl, inline/rtems/rtems/event.inl, inline/rtems/rtems/eventset.inl, inline/rtems/rtems/message.inl, inline/rtems/rtems/modes.inl, inline/rtems/rtems/options.inl, inline/rtems/rtems/part.inl, inline/rtems/rtems/ratemon.inl, inline/rtems/rtems/region.inl, inline/rtems/rtems/sem.inl, inline/rtems/rtems/status.inl, inline/rtems/rtems/support.inl, inline/rtems/rtems/tasks.inl, inline/rtems/rtems/timer.inl, macros/rtems/rtems/asr.inl, macros/rtems/rtems/attr.inl, macros/rtems/rtems/dpmem.inl, macros/rtems/rtems/event.inl, macros/rtems/rtems/eventset.inl, macros/rtems/rtems/message.inl, macros/rtems/rtems/modes.inl, macros/rtems/rtems/options.inl, macros/rtems/rtems/part.inl, macros/rtems/rtems/ratemon.inl, macros/rtems/rtems/region.inl, macros/rtems/rtems/sem.inl, macros/rtems/rtems/status.inl, macros/rtems/rtems/support.inl, macros/rtems/rtems/tasks.inl, macros/rtems/rtems/timer.inl, src/attr.c, src/clockget.c, src/clockset.c, src/clocktick.c, src/dpmem.c, src/dpmemcreate.c, src/dpmemdelete.c, src/dpmemexternal2internal.c, src/dpmemident.c, src/dpmeminternal2external.c, src/event.c, src/eventmp.c, src/eventreceive.c, src/eventseize.c, src/eventsend.c, src/eventsurrender.c, src/eventtimeout.c, src/intr.c, src/intrbody.c, src/intrcatch.c, src/mp.c, src/msg.c, src/msgmp.c, src/msgqallocate.c, src/msgqbroadcast.c, src/msgqcreate.c, src/msgqdelete.c, src/msgqflush.c, src/msgqgetnumberpending.c, src/msgqident.c, src/msgqreceive.c, src/msgqsend.c, src/msgqsubmit.c, src/msgqtranslatereturncode.c, src/msgqurgent.c, src/part.c, src/partcreate.c, src/partdelete.c, src/partgetbuffer.c, src/partident.c, src/partmp.c, src/partreturnbuffer.c, src/ratemon.c, src/ratemoncancel.c, src/ratemoncreate.c, src/ratemondelete.c, src/ratemongetstatus.c, src/ratemonident.c, src/ratemonperiod.c, src/ratemontimeout.c, src/region.c, src/regioncreate.c, src/regiondelete.c, src/regionextend.c, src/regiongetinfo.c, src/regiongetsegment.c, src/regiongetsegmentsize.c, src/regionident.c, src/regionmp.c, src/regionreturnsegment.c, src/rtclock.c, src/rtemsidtoname.c, src/rtemstimer.c, src/sem.c, src/semcreate.c, src/semdelete.c, src/semflush.c, src/semident.c, src/semmp.c, src/semobtain.c, src/semrelease.c, src/semtranslatereturncode.c, src/signal.c, src/signalcatch.c, src/signalmp.c, src/signalsend.c, src/taskcreate.c, src/taskdelete.c, src/taskgetnote.c, src/taskident.c, src/taskinitusers.c, src/taskissuspended.c, src/taskmode.c, src/taskmp.c, src/taskrestart.c, src/taskresume.c, src/tasks.c, src/tasksetnote.c, src/tasksetpriority.c, src/taskstart.c, src/tasksuspend.c, src/taskvariableadd.c, src/taskvariabledelete.c, src/taskvariableget.c, src/taskwakeafter.c, src/taskwakewhen.c, src/timercancel.c, src/timercreate.c, src/timerdelete.c, src/timerfireafter.c, src/timerfirewhen.c, src/timergetinfo.c, src/timerident.c, src/timerreset.c, src/timerserver.c, src/timerserverfireafter.c, src/timerserverfirewhen.c: URL for license changed.
* posix support initially addedJoel Sherrill1995-09-261-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-83/+4
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-281-1/+1
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* deleted unused codeJoel Sherrill1995-08-011-38/+0
* Switched to events for mp receive server and eliminated the specialJoel Sherrill1995-07-311-18/+49
| | | | blocking mechanism for it.
* Initial revisionJoel Sherrill1995-05-111-0/+128
