Use common phrases for the file brief descriptions.
Update #3706.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Use rtems_mode directly. This is in line with rtems_attribute and
rtems_option.
Update #3598.
http://www.google-melange.com/gci/task/view/google/gci2012/8019205
This PR was about a warning for no previous prototype for
rtems_interrupt_level_attribute. This method exists (like
a few others) to have real bodies for Classic API services
implemented as macros. These macros are not available from
anything but C and C++. The most explicit use was in the Ada
binding but these would be needed from assembly language
or any other non-C based language.
On top of needing a prototype, the methods were misnamed.
They were related to modes. This renames them, moves the
file, fixes test code, etc.
