* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | config: Bring back RTEMS 4.11 configuration table | Sebastian Huber | 2020-02-25 | 1 | -0/+18 |
| | | | | | This improves API backward compatibility of RTEMS 5.1 to previous versions. | ||||
* | config: Simplify initialization task config | Sebastian Huber | 2020-02-25 | 1 | -0/+46 |
With the removal of the CONFIGURE_HAS_OWN_INIT_TASK_TABLE configuration option at most one Classic API user initialization task can be configured. Provide an RTEMS API configuration table for backward compatibility. Update #3873. |
