path: root/cpukit/rtems/src/eventmp.c (follow)
* Suggested changes from Mark Jordan which eliminate warnings and errorsJoel Sherrill1996-12-021-1/+1
| | | | | | | | he received using the Microtec C++ compiler. Most of these are either missing casts from/to (void *), heavy handed use of enumerated types, or simply assumed conversions. There is at least one actual bug in an error path in thread.c in which the wrong argument was passed to _Thread_Stack_Free and was not being caught by gcc.
* posix support initially addedJoel Sherrill1995-09-261-5/+5
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-8/+10
* Initial revisionJoel Sherrill1995-05-111-0/+188
