path: root/cpukit/rtems/src/event.c (follow)
* Split Event Manager into one routine per file.Joel Sherrill1999-05-171-342/+0
* Added --disable-multiprocessing flag and modified a lot of files to makeJoel Sherrill1998-11-231-3/+7
| | | | it work.
* event.c: _Event_Manager_initialization no longer a static inlineJoel Sherrill1996-04-191-0/+20
| | | | sem.c: modified to eliminate Purify warnings
* comment added to describe synchronization logic in timeout routineJoel Sherrill1996-02-131-0/+21
* new isr synchronization algorithm using a single enumerated set of states.Joel Sherrill1996-02-091-10/+27
* Insert mode argument to _Watchdog_Insert removed. Now are watchdog timersJoel Sherrill1995-12-011-5/+1
| | | | are automatically activated upon insertion.
* Changed code for exit from synchronization state to a switch on theJoel Sherrill1995-12-011-11/+19
| | | | | possible synchronization actions. This should have made it harder to avoid a case.
* Replaced critical section algorithm to correct race conditions.Joel Sherrill1995-12-011-10/+19
* SPARC port passes all testsJoel Sherrill1995-10-301-0/+202
* posix support initially addedJoel Sherrill1995-09-261-4/+4
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-14/+21
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-281-3/+3
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* split out event support functions in anticipation of making a handlerJoel Sherrill1995-08-041-191/+0
* Initial revisionJoel Sherrill1995-05-111-0/+294
