Use a real function for rtems_clock_get_uptime_seconds().
Update #3598.
Move the __getreent() variant using the global reentrancy structure to
librtemscpu.a. This avoids a definition of __getreent() in the
configuration module if CONFIGURE_DISABLE_NEWLIB_REENTRANCY is defined.
This avoids all the dependencies which would be exposed by a reference
to the global reentrancy structure.
This change is only possible since the default configuration moved to
librtemsdefaultconfig.a recently.
Update #3507.
Add rtems_counter_frequency() API function. Use it to initialize the
counter value converter via the new system initialization step
(RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation
and the counter converter. It avoids an unnecessary pull in of the
64-bit integer division from libgcc.
Update #3456.
Close #3320.
Fixes link failure when linking Ada programs on the raspberry pi
