TOD_MILLISECONDS_TO_TICKS().
http://www.google-melange.com/gci/task/view/google/gci2012/7950205
Group the global TOD variables (_TOD_Now, _TOD_Uptime, and _TOD_Is_set)
in a structure to reduce address loads in _TOD_Tickle_ticks().
* rtems/Makefile.am, rtems/include/rtems/rtems/clock.h,
rtems/src/clockget.c:
* rtems/src/clockgetsecondssinceepoch.c,
rtems/src/clockgettickspersecond.c,
rtems/src/clockgettickssinceboot.c, rtems/src/clockgettod.c,
rtems/src/clockgettodtimeval.c: New files.
Refactored rtems_clock_get into 5 methods which are single purpose
and more strongly typed. They are:
rtems_clock_get_tod - Get TOD in Classic API structure
rtems_clock_get_tod_timeval - Get TOD in struct timeval
rtems_clock_get_seconds_since_epoch - Get TOD as seconds since 1988
rtems_clock_get_ticks_since_boot - Get ticks since boot
rtems_clock_get_ticks_per_second - Get ticks per second
