Use common phrases for the file brief descriptions.
Update #3706.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Avoid using newlib's gmtime_r call which fails with a max signed int.
Add an RTEMS specific version for 1/1/1988 to 31/12/2100.
Update sp2038 to test every day from 1/1/1988 to 31/12/2100. Only days
need be tested as the code splits the seconds based on days.
TOD_MILLISECONDS_TO_TICKS().
http://www.google-melange.com/gci/task/view/google/gci2012/8015207
Group the global TOD variables (_TOD_Now, _TOD_Uptime, and _TOD_Is_set)
in a structure to reduce address loads in _TOD_Tickle_ticks().
* libcsupport/src/__times.c, posix/src/adjtime.c,
posix/src/clockgetres.c, posix/src/sysconf.c,
rtems/src/clockgettickspersecond.c, rtems/src/clockgettod.c,
rtems/src/clockset.c, rtems/src/clocktodvalidate.c,
score/src/timespecfromticks.c, score/src/timespectoticks.c,
score/src/ts64toticks.c: More case converted to use configuration
table entry not _TOD_Microseconds_per_tick.
* rtems/Makefile.am, rtems/include/rtems/rtems/clock.h,
rtems/src/clockget.c:
* rtems/src/clockgetsecondssinceepoch.c,
rtems/src/clockgettickssinceboot.c, rtems/src/clockgettod.c,
rtems/src/clockgettodtimeval.c: New files.
Refactored rtems_clock_get into 5 methods which are single purpose
and more strongly typed. They are:
rtems_clock_get_tod - Get TOD in Classic API structure
rtems_clock_get_tod_timeval - Get TOD in struct timeval
rtems_clock_get_seconds_since_epoch - Get TOD as seconds since 1988
rtems_clock_get_ticks_since_boot - Get ticks since boot
rtems_clock_get_ticks_per_second - Get ticks per second
