path: root/cpukit/rtems/src/clockgetsecondssinceepoch.c (follow)
* rtems: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-3/+5
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* score: Add and use _TOD_Is_set()Sebastian Huber2013-08-011-1/+1
* score: Rename tod.h to todimpl.hSebastian Huber2013-08-011-1/+1
* score: Merge tod implementation into one fileSebastian Huber2013-07-261-5/+0
| | | | | Delete TOD_MICROSECONDS_PER_SECOND, TOD_MICROSECONDS_TO_TICKS() and TOD_MILLISECONDS_TO_TICKS().
* score misc: Clean up Doxygen #12 (GCI 2012)Alex Ivanov2012-12-021-2/+7
| | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/8025203
* score: New structure TOD_ControlSebastian Huber2012-06-141-1/+1
| | | | | Group the global TOD variables (_TOD_Now, _TOD_Uptime, and _TOD_Is_set) in a structure to reduce address loads in _TOD_Tickle_ticks().
* 2008-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-081-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | * libcsupport/src/__times.c, libmisc/cpuuse/cpuusagereport.c, libmisc/cpuuse/cpuusagereset.c, posix/src/clockgettime.c, posix/src/pthread.c, posix/src/timersettime.c, rtems/include/rtems/rtems/ratemon.h, rtems/src/clockgetsecondssinceepoch.c, rtems/src/clockgetuptime.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonperiod.c, rtems/src/ratemonreportstatistics.c, rtems/src/taskwakewhen.c, rtems/src/timerfirewhen.c, rtems/src/timerserver.c, rtems/src/timerserverfirewhen.c, score/Makefile.am, score/preinstall.am, score/include/rtems/score/thread.h, score/include/rtems/score/tod.h, score/src/coretod.c, score/src/coretodget.c, score/src/coretodgetuptime.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/threaddispatch.c, score/src/threadinitialize.c: Add SuperCore handler Timestamp to provide an opaque class for the representation and manipulation of uptime, time of day, and the difference between two timestamps. By using SuperCore Timestamp, it is clear which methods and APIs really have to be struct timespec and which can be in an optimized native format. * score/include/rtems/score/timestamp.h, score/src/coretodgetuptimetimespec.c: New files.
* 2008-03-11 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-03-111-0/+38
* rtems/Makefile.am, rtems/include/rtems/rtems/clock.h, rtems/src/clockget.c: * rtems/src/clockgetsecondssinceepoch.c, rtems/src/clockgettickspersecond.c, rtems/src/clockgettickssinceboot.c, rtems/src/clockgettod.c, rtems/src/clockgettodtimeval.c: New files. Refactored rtems_clock_get into 5 methods which are single purpose and more strongly typed. They are: rtems_clock_get_tod - Get TOD in Classic API structure rtems_clock_get_tod_timeval - Get TOD in struct timeval rtems_clock_get_seconds_since_epoch - Get TOD as seconds since 1988 rtems_clock_get_ticks_since_boot - Get ticks since boot rtems_clock_get_ticks_per_second - Get ticks per second
