#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
In standard C pointer operands are not allowed in integer constant
expressions. Avoid a static assertion based on an array typedef since
this could lead to warnings ("variably modified 'x' at file scope" and
"typedef 'x' locally defined but not used");
This implementation requires unique messages.
Update #3117.
Update #3182.
Clock disciplines may be WATCHDOG_RELATIVE, WATCHDOG_ABSOLUTE,
or WATCHDOG_NO_TIMEOUT. A discipline of WATCHDOG_RELATIVE with
a timeout of WATCHDOG_NO_TIMEOUT is equivalent to a discipline
of WATCHDOG_NO_TIMEOUT.
updates #2732
Unify the status codes of the Classic and POSIX API to use the new enum
Status_Control. This eliminates the Thread_Control::Wait::timeout_code
field and the timeout parameter of _Thread_queue_Enqueue_critical() and
_MPCI_Send_request_packet(). It gets rid of the status code translation
tables and instead uses simple bit operations to get the status for a
particular API. This enables translation of status code constants at
compile time. Add _Thread_Wait_get_status() to avoid direct access of
thread internal data structures.
Drop the multiprocessing (MP) dependent callout parameter from the
thread queue extract, dequeue, flush and unblock methods. Merge this
parameter with the lock context into new structure Thread_queue_Context.
This helps to gets rid of the conditionally compiled method call
helpers.
Get rid of the mp_id parameter used for some thread queue methods. Use
THREAD_QUEUE_QUEUE_TO_OBJECT() instead.
Use _Thread_queue_Flush_critical() to atomically release the barrier.
Update #2555.
Rename _CORE_barrier_Wait() into _CORE_barrier_Seize(). Rename
_CORE_barrier_Release() into _CORE_barrier_Surrender(). This avoids
confusion with the ISR lock acquire and release.
The thread queue implementation was heavily reworked to support SMP.
This broke the multiprocessing support of the thread queues. This is
fixed by this patch.
A thread proxy is unblocked due to three reasons
1) timeout,
2) request satisfaction, and
3) extraction.
In case 1) no MPCI message must be sent. This is ensured via the
_Thread_queue_MP_callout_do_nothing() callout set during
_Thread_MP_Allocate_proxy().
In case 2) and 3) an MPCI message must be sent. In case we interrupt
the blocking operation during _Thread_queue_Enqueue_critical(), then
this message must be sent by the blocking thread. For this the new
fields Thread_Proxy_control::thread_queue_callout and
Thread_Proxy_control::thread_queue_id are used.
Delete the individual API MP callout types and use
Thread_queue_MP_callout throughout. This type is only defined in
multiprocessing configurations. Prefix the multiprocessing parameters
with mp_ to ease code review. Multiprocessing specific parameters are
optional due to use of a similar macro pattern. There is no overhead
for non-multiprocessing configurations.
This field was only by the monitor in non-multiprocessing
configurations. Add new field Thread_Wait_information::remote_id in
multiprocessing configurations and use it for the remote procedure call
thread queue.
Add _Thread_Wait_get_id() to obtain the object identifier for debug and
system information tools. Ensure the object layout via static asserts.
Add test cases to sptests/spthreadq01.
Move implementation specific parts of tqdata.h, threadq.h and
threadq.inl into new header file threadqimpl.h. The threadq.h contains
now only the application visible API.
Delete tqdata.h.
Pass the executing thread as a function parameter. Obtain the executing
thread inside a thread dispatch critical section to avoid problems on
SMP.
Move implementation specific parts of barrier.h and barrier.inl into new
header file barrierimpl.h. The barrier.h contains now only the
Add and use _Objects_Put_without_thread_dispatch(). These two functions
pair with the _Objects_Get() function. This helps to introduce object
specific SMP locks to avoid lock contention.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8025204
* rtems/src/barrierdelete.c, rtems/src/barrierrelease.c,
rtems/src/barriertranslatereturncode.c, rtems/src/barrierwait.c,
rtems/src/clockget.c, rtems/src/dpmemdelete.c,
rtems/src/dpmemexternal2internal.c,
rtems/src/eventtimeout.c, rtems/src/msgqbroadcast.c,
rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c,
rtems/src/msgqsend.c, rtems/src/msgqurgent.c, rtems/src/partdelete.c,
rtems/src/partgetbuffer.c, rtems/src/partreturnbuffer.c,
rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c,
rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c,
rtems/src/ratemontimeout.c, rtems/src/semdelete.c,
rtems/src/semflush.c, rtems/src/semobtain.c, rtems/src/semrelease.c,
rtems/src/semtranslatereturncode.c, rtems/src/signalsend.c,
rtems/src/taskissuspended.c, rtems/src/taskrestart.c,
rtems/src/taskresume.c, rtems/src/tasksetnote.c,
rtems/src/tasksetpriority.c, rtems/src/taskstart.c,
rtems/src/tasksuspend.c, rtems/src/taskvariableadd.c,
rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c,
rtems/src/timercancel.c, rtems/src/timerdelete.c,
rtems/src/timerserverfirewhen.c: Restructured all code with
the switch (location) pattern so that OBJECTS_LOCAL is first
and we can fall into it and the OBJECTS_ERROR case breaks
to a return RTEMS_INVALID_ID. This eliminates the return
RTEMS_INTERNAL_ERROR at the bottom of each of these files which
was unreachable and untestable code. This resulted in a code
savings of approximately 20 bytes per file on the SPARC/ERC32.
* itron/src/can_wup.c, itron/src/chg_pri.c, itron/src/del_mbf.c,
itron/src/del_mbx.c, itron/src/del_sem.c, itron/src/del_tsk.c,
itron/src/frsm_tsk.c, itron/src/ref_mbf.c, itron/src/ref_mbx.c,
itron/src/ref_sem.c, itron/src/ref_tsk.c, itron/src/rel_wai.c,
itron/src/rsm_tsk.c, itron/src/sig_sem.c, itron/src/snd_mbx.c,
itron/src/sta_tsk.c, itron/src/sus_tsk.c, itron/src/ter_tsk.c,
itron/src/trcv_mbf.c, itron/src/trcv_mbx.c, itron/src/tsnd_mbf.c,
itron/src/twai_sem.c, posix/src/cancel.c, posix/src/conddestroy.c,
posix/src/condinit.c, posix/src/condsignalsupp.c,
posix/src/condwaitsupp.c, posix/src/keydelete.c,
posix/src/keygetspecific.c, posix/src/keysetspecific.c,
posix/src/mqueueclose.c, posix/src/mqueuegetattr.c,
posix/src/mutexinit.c, posix/src/mutexlocksupp.c,
posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c,
posix/src/pbarrierdestroy.c, posix/src/pbarrierwait.c,
posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c,
posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c,
posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c,
posix/src/pspindestroy.c, posix/src/pspinlock.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/pthreaddetach.c, posix/src/pthreadequal.c,
posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c,
posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c,
posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c,
rtems/src/barrierwait.c, rtems/src/dpmemdelete.c,
rtems/src/ratemontimeout.c, rtems/src/regiondelete.c,
rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c,
rtems/src/regionreturnsegment.c, rtems/src/semdelete.c,
rtems/src/signalsend.c, rtems/src/taskdelete.c,
rtems/src/taskgetnote.c, rtems/src/taskissuspended.c,
rtems/src/taskrestart.c, rtems/src/taskresume.c,
rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c,
rtems/src/taskvariableget.c, rtems/src/timercancel.c,
rtems/src/timerserverfirewhen.c, sapi/src/extensiondelete.c,
score/include/rtems/score/object.h, score/src/corerwlocktimeout.c,
score/src/mpci.c, score/src/objectgetnameasstring.c,
score/src/threaddelayended.c, score/src/threadqtimeout.c: When
multiprocessing is disabled, do not even allow the constant
OBJECTS_REMOTE to appear in the source. Even at -O2, the presence of
a case OBJECTS_REMOTE in each id->pointer _Objects_Get switch results
in the generation of binary code which can NOT be reached.
* posix/src/prwlockunlock.c, rtems/Makefile.am,
rtems/src/barrierrelease.c, rtems/src/barrierwait.c,
score/src/corerwlockobtainread.c, score/src/corerwlockrelease.c:
Complete implementation of barrier as the rest of the test code is
now implemented. Also add blocking code to rwlock.
* rtems/Makefile.am, rtems/preinstall.am, rtems/include/rtems.h,
rtems/include/rtems/rtems/attr.h, rtems/include/rtems/rtems/config.h,
rtems/inline/rtems/rtems/attr.inl, rtems/macros/rtems/rtems/attr.inl:
Add Classic API Barriers.
* rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/barriermp.h,
rtems/inline/rtems/rtems/barrier.inl,
rtems/macros/rtems/rtems/barrier.inl, rtems/src/barrier.c,
rtems/src/barriercreate.c, rtems/src/barrierdelete.c,
rtems/src/barrierident.c, rtems/src/barrierrelease.c,
rtems/src/barriertranslatereturncode.c, rtems/src/barrierwait.c:
New files.
