* include/rtems/rtems/Makefile.am: Remove.
* inline/rtems/rtems/Makefile.am: Remove.
* macros/rtems/rtems/Makefile.am: Remove.
* macros: Handle subdirs, require automake-1.5.
* macros/rtems/rtems/sem.inl: Added macro implementation of
_Semaphore_Get_interrupt_disable().
and his EPICS porting effort.
it work.
via the user api.
like signal dispatching.
correct Information block.
+ variable length messages
+ named devices
+ debug monitor
