path: root/cpukit/rtems/inline (follow)
* 2001-01-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-161-1/+1
| | | | | | | | | | | | | | | | | | | | * Added task-based timers to the Timer Manager. This added three new directives: - rtems_timer_initiate_server - rtems_timer_server_fire_after - rtems_timer_server_fire_when In the process of doing this, a number of cleanups were made. * src/timerserver.c, src/timerserverfireafter.c, src/timerserverfirewhen.c: New files. * include/timer/timer.h: Added new prototypes and supporting types. * inline/rtems/rtems/timer.h, macros/rtems/rtems/timer.h: Enhanced _Timer_Is_interval_class() to cover the class TIMER_INTERVAL_ON_TASK. * src/Makefile.am: Accounted for new files. * src/rtemstimer.c: Added initialization of _Timer_Server variable. * src/timercancel.c, src/timerreset.c: Account for addition of timer classes. Also corrected the headers. * src/timercreate.c, src/timerdelete.c, src/timerfireafter.c, src/timerfireafter.c, src/timerident.c: Corrected header.
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-161-3/+21
| | | | | | | | | | | | | * include/rtems/Makefile.am: Remove. * include/rtems/rtems/Makefile.am: Remove. * include/Makefile.am: Handle subdirs, require automake-1.5. * inline/rtems/Makefile.am: Remove. * inline/rtems/rtems/Makefile.am: Remove. * inline/Makefile.am: Handle subdirs, require automake-1.5. * macros/rtems/Makefile.am: Remove. * macros/rtems/rtems/Makefile.am: Remove. * macros: Handle subdirs, require automake-1.5. * Makefile.am: require automake-1.5.
* 2001-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-301-1/+1
| | | | | * inline/rtems/rtems/attr.inl: Correct typo and use correct attribute RTEMS_SYSTEM_TASK. Reported by Chris Johns <ccj@acm.org>.
* Added _Semaphore_Get_interrupt_disable.Joel Sherrill2000-07-061-0/+10
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-133-0/+6
| | | | adds .cvsignore.
* Added support for simple binary semaphores in addition to the highJoel Sherrill2000-01-051-15/+33
| | | | | | | | | | | | power binary/mutex style semaphores already supported by RTEMS. This was done at the request of Eric Norum <eric@cls.usask.ca> in support of his effort to port EPICS to RTEMS. This change consisted of changing the nesting_allowed boolean into a lock_nesting_behavior enumerated value as well as allowing the core mutex object to optionally support ensuring that the holder of a binary semaphore released it. Finally, a more subtle enhancement was to allow the non-holder to release a priority inheritance/ceiling mutex and still allow the holding task to return to its original priority.
* First attempt at adding simple binary semaphore in addition to the currentJoel Sherrill1999-12-131-0/+17
| | | | | "mutex" and counting semaphore. This is at the request of Eric Norum and his EPICS porting effort.
* Updated copyright notice.Joel Sherrill1999-11-1716-32/+16
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1999-10-041-3/+3
* Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1999-09-071-0/+10
* Added --disable-multiprocessing flag and modified a lot of files to makeJoel Sherrill1998-11-231-0/+2
| | | | it work.
* Added system task attribute to allow one to create a task with "0" priorityJoel Sherrill1998-08-211-0/+17
| | | | via the user api.
* updated copyright to 1998Joel Sherrill1998-02-1716-16/+16
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-0816-32/+32
* Make Post an atomic operation.Joel Sherrill1997-10-061-1/+5
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-2216-80/+80
* switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE"Joel Sherrill1996-07-0315-74/+74
* event.h: _Event_Manager_initialization no longer a static inlineJoel Sherrill1996-04-191-19/+0
* Removed prototyes for static inline routines and moved the comments intoJoel Sherrill1996-03-0616-12/+334
| | | | | | | | | | | | | | | the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana.
* new isr synchronization algorithm using a single enumerated set of states.Joel Sherrill1996-02-091-1/+1
* posix support initially addedJoel Sherrill1995-09-262-2/+2
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-95/+0
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-117-67/+37
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-282-15/+31
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1995-08-231-2/+2
| | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-232-0/+59
* make inline and macro implementations matchJoel Sherrill1995-08-221-4/+3
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-172-31/+19
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* Initial revisionJoel Sherrill1995-05-1115-0/+1455
