path: root/cpukit/rtems/inline (unfollow)
1995-09-26posix support initially addedJoel Sherrill2-2/+2
1995-09-19Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1-95/+0
single biggest changes were the expansion of the workspace size macro to include other types of objects and the increase in the minimum stack size for most CPUs.
1995-09-11The word "RTEMS" almost completely removed from the core.Joel Sherrill7-67/+37
Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API.
1995-08-28Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill2-15/+31
Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
1995-08-23Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1-2/+2
Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
1995-08-23Support for variable length names added to Object Handler. This supportsJoel Sherrill2-0/+59
both fixed length "raw" names and strings from the API's point of view. Both inline and macro implementations were tested.
1995-08-22make inline and macro implementations matchJoel Sherrill1-4/+3
1995-08-17Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill2-31/+19
(tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
