Avoid Giant lock for rtems_task_set_priority(), rtems_task_suspend() and
rtems_task_resume().
Update #2555.
Notepads where a feature of RTEMS' tasks that simply functioned in
the same way as POSIX keys or threaded local storage (TLS). They were
introduced well before per task variables, which are also deprecated,
and were barely used in favor of their POSIX alternatives.
In addition to their scarce usage, Notepads took up unnecessary memory.
For each task:
- 16 32-bit integers were allocated.
- A total of 64 bytes per task per thread.
This is especially critical in low memory and safety-critical applications.
They are also defined as uint32_t, and therefore are not guaranteed to
hold a pointer.
Lastly, they are not portable solutions for SMP and uniprocessor systems,
like POSIX keys and TLS.
updates #2493.
Move implementation specific parts of mpci.h into new header file
mpciimpl.h. The mpci.h contains now only the application visible API.
Move implementation specific parts of tasks.h and tasks.inl into new
header file tasksimpl.h. The tasks.h contains now only the application
visible API.
http://www.google-melange.com/gci/task/view/google/gci2012/8024203
* libcsupport/include/rtems/libio_.h,
libcsupport/src/fs_null_handlers.c: Null handlers are now const.
* libi2c/libi2c.c, libi2c/libi2c.h: Documentation. Do not create
semaphores on the fly.
* cpukit/libblock/src/bdpart.c: Fixed format specifier.
* cpukit/libblock/include/rtems/bdbuf.h, rtems/include/rtems.h,
rtems/include/rtems/rtems/asr.h, rtems/include/rtems/rtems/attr.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/barriermp.h,
rtems/include/rtems/rtems/cache.h, rtems/include/rtems/rtems/clock.h,
rtems/include/rtems/rtems/config.h, rtems/include/rtems/rtems/dpmem.h,
rtems/include/rtems/rtems/event.h,
rtems/include/rtems/rtems/eventmp.h,
rtems/include/rtems/rtems/eventset.h,
rtems/include/rtems/rtems/intr.h, rtems/include/rtems/rtems/message.h,
rtems/include/rtems/rtems/modes.h, rtems/include/rtems/rtems/mp.h,
rtems/include/rtems/rtems/msgmp.h, rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/part.h, rtems/include/rtems/rtems/partmp.h,
rtems/include/rtems/rtems/region.h,
rtems/include/rtems/rtems/regionmp.h,
rtems/include/rtems/rtems/rtemsapi.h, rtems/include/rtems/rtems/sem.h,
rtems/include/rtems/rtems/semmp.h, rtems/include/rtems/rtems/signal.h,
rtems/include/rtems/rtems/signalmp.h,
rtems/include/rtems/rtems/status.h,
rtems/include/rtems/rtems/support.h,
rtems/include/rtems/rtems/taskmp.h, rtems/include/rtems/rtems/tasks.h,
rtems/include/rtems/rtems/timer.h, rtems/include/rtems/rtems/types.h,
rtems/inline/rtems/rtems/support.inl: Documentation.
* include/rtems/irq-extension.h: Documentation. Added API for
interrupt servers.
* rtems/Doxyfile, rtems/include/rtems/rtems/asr.h,
rtems/include/rtems/rtems/dpmem.h, rtems/include/rtems/rtems/event.h,
rtems/include/rtems/rtems/options.h,
rtems/include/rtems/rtems/sem.h, rtems/include/rtems/rtems/semmp.h,
rtems/include/rtems/rtems/tasks.h, rtems/include/rtems/rtems/timer.h,
rtems/include/rtems/rtems/types.h, rtems/inline/rtems/rtems/asr.inl,
rtems/inline/rtems/rtems/attr.inl,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/dpmem.inl,
rtems/inline/rtems/rtems/event.inl,
rtems/inline/rtems/rtems/message.inl,
rtems/inline/rtems/rtems/modes.inl,
rtems/inline/rtems/rtems/options.inl,
rtems/inline/rtems/rtems/part.inl,
rtems/inline/rtems/rtems/ratemon.inl,
rtems/inline/rtems/rtems/region.inl,
rtems/inline/rtems/rtems/sem.inl,
rtems/inline/rtems/rtems/status.inl,
rtems/inline/rtems/rtems/support.inl,
rtems/inline/rtems/rtems/timer.inl: More Doxygen improvements.
* rtems/include/rtems.h, rtems/include/rtems/rtems/asr.h,
rtems/inline/rtems/rtems/eventset.inl,
rtems/inline/rtems/rtems/tasks.inl,
rtems/inline/rtems/rtems/timer.inl: Initial conversion of Classic API
header files to Doxygen.
* rtems/Doxyfile: New file.
rtems/include/rtems/rtems/types.h: Add doxygen preamble.
rtems/macros/rtems/rtems/part.inl,
rtems/src/attr.c,
rtems/src/dpmem.c,
rtems/src/dpmemcreate.c,
rtems/src/dpmemexternal2internal.c,
rtems/src/dpmeminternal2external.c,
rtems/src/eventseize.c,
rtems/src/msg.c,
rtems/src/msgmp.c,
rtems/src/msgqallocate.c,
rtems/src/msgqbroadcast.c,
rtems/src/msgqcreate.c,
rtems/src/msgqflush.c,
rtems/src/msgqgetnumberpending.c,
rtems/src/msgqident.c,
rtems/src/msgqreceive.c,
rtems/src/msgqsend.c,
rtems/src/msgqsubmit.c,
rtems/src/msgqtranslatereturncode.c,
rtems/src/msgqurgent.c,
rtems/src/part.c,
rtems/src/partcreate.c,
rtems/src/partident.c,
rtems/src/partmp.c,
rtems/src/ratemon.c,
rtems/src/region.c,
rtems/src/regioncreate.c,
rtems/src/regionextend.c,
rtems/src/regiongetsegment.c,
rtems/src/regiongetsegmentsize.c,
rtems/src/regionmp.c,
rtems/src/regionreturnsegment.c,
rtems/src/rtemstimer.c,
rtems/src/sem.c,
rtems/src/semcreate.c,
rtems/src/semident.c,
rtems/src/semmp.c,
rtems/src/semobtain.c,
rtems/src/semtranslatereturncode.c,
rtems/src/taskcreate.c,
rtems/src/taskgetnote.c,
rtems/src/taskident.c,
rtems/src/taskinitusers.c,
rtems/src/taskmp.c,
rtems/src/taskrestart.c,
rtems/src/tasks.c,
rtems/src/tasksetnote.c,
rtems/src/taskstart.c,
rtems/src/timerserver.c: Convert to using c99 fixed size types.
* include/rtems.h, include/rtems/rtems/asr.h,
include/rtems/rtems/attr.h, include/rtems/rtems/cache.h,
include/rtems/rtems/clock.h, include/rtems/rtems/config.h,
include/rtems/rtems/dpmem.h, include/rtems/rtems/event.h,
include/rtems/rtems/eventmp.h, include/rtems/rtems/eventset.h,
include/rtems/rtems/intr.h, include/rtems/rtems/message.h,
include/rtems/rtems/modes.h, include/rtems/rtems/mp.h,
include/rtems/rtems/msgmp.h, include/rtems/rtems/options.h,
include/rtems/rtems/part.h, include/rtems/rtems/partmp.h,
include/rtems/rtems/ratemon.h, include/rtems/rtems/region.h,
include/rtems/rtems/regionmp.h, include/rtems/rtems/rtemsapi.h,
include/rtems/rtems/sem.h, include/rtems/rtems/semmp.h,
include/rtems/rtems/signal.h, include/rtems/rtems/signalmp.h,
include/rtems/rtems/status.h, include/rtems/rtems/support.h,
include/rtems/rtems/taskmp.h, include/rtems/rtems/tasks.h,
include/rtems/rtems/timer.h, include/rtems/rtems/types.h,
inline/rtems/rtems/asr.inl, inline/rtems/rtems/attr.inl,
inline/rtems/rtems/dpmem.inl, inline/rtems/rtems/event.inl,
inline/rtems/rtems/eventset.inl, inline/rtems/rtems/message.inl,
inline/rtems/rtems/modes.inl, inline/rtems/rtems/options.inl,
inline/rtems/rtems/part.inl, inline/rtems/rtems/ratemon.inl,
inline/rtems/rtems/region.inl, inline/rtems/rtems/sem.inl,
inline/rtems/rtems/status.inl, inline/rtems/rtems/support.inl,
inline/rtems/rtems/tasks.inl, inline/rtems/rtems/timer.inl,
macros/rtems/rtems/asr.inl, macros/rtems/rtems/attr.inl,
macros/rtems/rtems/dpmem.inl, macros/rtems/rtems/event.inl,
macros/rtems/rtems/eventset.inl, macros/rtems/rtems/message.inl,
macros/rtems/rtems/modes.inl, macros/rtems/rtems/options.inl,
macros/rtems/rtems/part.inl, macros/rtems/rtems/ratemon.inl,
macros/rtems/rtems/region.inl, macros/rtems/rtems/sem.inl,
macros/rtems/rtems/status.inl, macros/rtems/rtems/support.inl,
macros/rtems/rtems/tasks.inl, macros/rtems/rtems/timer.inl,
src/attr.c, src/clockget.c, src/clockset.c, src/clocktick.c,
src/dpmem.c, src/dpmemcreate.c, src/dpmemdelete.c,
src/dpmemexternal2internal.c, src/dpmemident.c,
src/dpmeminternal2external.c, src/event.c, src/eventmp.c,
src/eventreceive.c, src/eventseize.c, src/eventsend.c,
src/eventsurrender.c, src/eventtimeout.c, src/intr.c, src/intrbody.c,
src/intrcatch.c, src/mp.c, src/msg.c, src/msgmp.c,
src/msgqallocate.c, src/msgqbroadcast.c, src/msgqcreate.c,
src/msgqdelete.c, src/msgqflush.c, src/msgqgetnumberpending.c,
src/msgqident.c, src/msgqreceive.c, src/msgqsend.c, src/msgqsubmit.c,
src/msgqtranslatereturncode.c, src/msgqurgent.c, src/part.c,
src/partcreate.c, src/partdelete.c, src/partgetbuffer.c,
src/partident.c, src/partmp.c, src/partreturnbuffer.c, src/ratemon.c,
src/ratemoncancel.c, src/ratemoncreate.c, src/ratemondelete.c,
src/ratemongetstatus.c, src/ratemonident.c, src/ratemonperiod.c,
src/ratemontimeout.c, src/region.c, src/regioncreate.c,
src/regiondelete.c, src/regionextend.c, src/regiongetinfo.c,
src/regiongetsegment.c, src/regiongetsegmentsize.c,
src/regionident.c, src/regionmp.c, src/regionreturnsegment.c,
src/rtclock.c, src/rtemsidtoname.c, src/rtemstimer.c, src/sem.c,
src/semcreate.c, src/semdelete.c, src/semflush.c, src/semident.c,
src/semmp.c, src/semobtain.c, src/semrelease.c,
src/semtranslatereturncode.c, src/signal.c, src/signalcatch.c,
src/signalmp.c, src/signalsend.c, src/taskcreate.c, src/taskdelete.c,
src/taskgetnote.c, src/taskident.c, src/taskinitusers.c,
src/taskissuspended.c, src/taskmode.c, src/taskmp.c,
src/taskrestart.c, src/taskresume.c, src/tasks.c, src/tasksetnote.c,
src/tasksetpriority.c, src/taskstart.c, src/tasksuspend.c,
src/taskvariableadd.c, src/taskvariabledelete.c,
src/taskvariableget.c, src/taskwakeafter.c, src/taskwakewhen.c,
src/timercancel.c, src/timercreate.c, src/timerdelete.c,
src/timerfireafter.c, src/timerfirewhen.c, src/timergetinfo.c,
src/timerident.c, src/timerreset.c, src/timerserver.c,
src/timerserverfireafter.c, src/timerserverfirewhen.c: URL for
license changed.
like signal dispatching.
