Rename rtems_smp_get_current_processor() in
rtems_get_current_processor(). Make rtems_get_current_processor() a
function in uni-processor configurations to enable ABI compatibility
with SMP configurations.
Rename rtems_smp_get_processor_count() in rtems_get_processor_count().
Make rtems_get_processor_count() a function in uni-processor
configurations to enable ABI compatibility with SMP configurations.
Add and use _SMP_Get_current_processor() and
rtems_smp_get_current_processor().
Delete bsp_smp_interrupt_cpu().
Change type of current processor index from int to uint32_t to match
_SMP_Processor_count type.
Rename in rtems_smp_get_processor_count(). Always provide
<rtems/score/smp.h> and <rtems/rtems/smp.h>. Add
_SMP_Get_processor_count(). This function will be a compile time
constant defined to be one on uni-processor configurations. This allows
iterations over all processors without overhead on uni-processor
configurations.
Delete rtems_configuration_get_smp_maximum_processors(). Delete
rtems_configuration_smp_maximum_processors variable. Add
maximum_processors field to rtems_configuration_table if RTEMS_SMP is
defined. Add rtems_configuration_get_maximum_processors().
PR 1826/cpukit
* libmisc/cpuuse/cpuusagereport.c, rtems/Makefile.am,
rtems/preinstall.am, rtems/include/rtems.h: Add SMP Helper methods to
Classic API.
* rtems/include/rtems/rtems/smp.h: New file.
