http://www.google-melange.com/gci/task/view/google/gci2012/8011204
* libcsupport/include/rtems/libio_.h,
libcsupport/src/fs_null_handlers.c: Null handlers are now const.
* libi2c/libi2c.c, libi2c/libi2c.h: Documentation. Do not create
semaphores on the fly.
* cpukit/libblock/src/bdpart.c: Fixed format specifier.
* cpukit/libblock/include/rtems/bdbuf.h, rtems/include/rtems.h,
rtems/include/rtems/rtems/asr.h, rtems/include/rtems/rtems/attr.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/barriermp.h,
rtems/include/rtems/rtems/cache.h, rtems/include/rtems/rtems/clock.h,
rtems/include/rtems/rtems/config.h, rtems/include/rtems/rtems/dpmem.h,
rtems/include/rtems/rtems/event.h,
rtems/include/rtems/rtems/eventmp.h,
rtems/include/rtems/rtems/eventset.h,
rtems/include/rtems/rtems/intr.h, rtems/include/rtems/rtems/message.h,
rtems/include/rtems/rtems/modes.h, rtems/include/rtems/rtems/mp.h,
rtems/include/rtems/rtems/msgmp.h, rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/part.h, rtems/include/rtems/rtems/partmp.h,
rtems/include/rtems/rtems/region.h,
rtems/include/rtems/rtems/regionmp.h,
rtems/include/rtems/rtems/rtemsapi.h, rtems/include/rtems/rtems/sem.h,
rtems/include/rtems/rtems/semmp.h, rtems/include/rtems/rtems/signal.h,
rtems/include/rtems/rtems/signalmp.h,
rtems/include/rtems/rtems/status.h,
rtems/include/rtems/rtems/support.h,
rtems/include/rtems/rtems/taskmp.h, rtems/include/rtems/rtems/tasks.h,
rtems/include/rtems/rtems/timer.h, rtems/include/rtems/rtems/types.h,
rtems/inline/rtems/rtems/support.inl: Documentation.
* include/rtems/irq-extension.h: Documentation. Added API for
interrupt servers.
* itron/include/rtems/itron/itronapi.h, libmisc/capture/capture.c,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-mpci.c,
posix/include/rtems/posix/config.h,
posix/include/rtems/posix/posixapi.h,
rtems/include/rtems/rtems/rtemsapi.h, rtems/src/taskinitusers.c,
sapi/include/confdefs.h, sapi/include/rtems/config.h,
sapi/include/rtems/init.h, sapi/src/exinit.c, sapi/src/itronapi.c,
sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/isr.c,
score/src/thread.c, score/src/threadcreateidle.c,
score/src/threadstackallocate.c, score/src/threadstackfree.c,
score/src/wkspace.c: Eliminate pointers to API configuration tables
in the main configuration table. Reference the main configuration
table and the API configuration tables directly using the confdefs.h
version rather than obtaining a pointer to it. This eliminated some
variables, a potential fatal error, some unnecessary default
configuration structures. Overall, about a 4.5% reduction in the code
size for minimum and hello on the SPARC.
* rtems/Doxyfile, rtems/include/rtems/rtems/asr.h,
rtems/include/rtems/rtems/dpmem.h, rtems/include/rtems/rtems/event.h,
rtems/include/rtems/rtems/options.h,
rtems/include/rtems/rtems/sem.h, rtems/include/rtems/rtems/semmp.h,
rtems/include/rtems/rtems/tasks.h, rtems/include/rtems/rtems/timer.h,
rtems/include/rtems/rtems/types.h, rtems/inline/rtems/rtems/asr.inl,
rtems/inline/rtems/rtems/attr.inl,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/dpmem.inl,
rtems/inline/rtems/rtems/event.inl,
rtems/inline/rtems/rtems/message.inl,
rtems/inline/rtems/rtems/modes.inl,
rtems/inline/rtems/rtems/options.inl,
rtems/inline/rtems/rtems/part.inl,
rtems/inline/rtems/rtems/ratemon.inl,
rtems/inline/rtems/rtems/region.inl,
rtems/inline/rtems/rtems/sem.inl,
rtems/inline/rtems/rtems/status.inl,
rtems/inline/rtems/rtems/support.inl,
rtems/inline/rtems/rtems/timer.inl: More Doxygen improvements.
* rtems/include/rtems.h, rtems/include/rtems/rtems/asr.h,
rtems/inline/rtems/rtems/eventset.inl,
rtems/inline/rtems/rtems/tasks.inl,
rtems/inline/rtems/rtems/timer.inl: Initial conversion of Classic API
header files to Doxygen.
* rtems/Doxyfile: New file.
rtems/include/rtems/rtems/types.h: Add doxygen preamble.
* include/rtems.h, include/rtems/rtems/asr.h,
include/rtems/rtems/attr.h, include/rtems/rtems/cache.h,
include/rtems/rtems/clock.h, include/rtems/rtems/config.h,
include/rtems/rtems/dpmem.h, include/rtems/rtems/event.h,
include/rtems/rtems/eventmp.h, include/rtems/rtems/eventset.h,
include/rtems/rtems/intr.h, include/rtems/rtems/message.h,
include/rtems/rtems/modes.h, include/rtems/rtems/mp.h,
include/rtems/rtems/msgmp.h, include/rtems/rtems/options.h,
include/rtems/rtems/part.h, include/rtems/rtems/partmp.h,
include/rtems/rtems/ratemon.h, include/rtems/rtems/region.h,
include/rtems/rtems/regionmp.h, include/rtems/rtems/rtemsapi.h,
include/rtems/rtems/sem.h, include/rtems/rtems/semmp.h,
include/rtems/rtems/signal.h, include/rtems/rtems/signalmp.h,
include/rtems/rtems/status.h, include/rtems/rtems/support.h,
include/rtems/rtems/taskmp.h, include/rtems/rtems/tasks.h,
include/rtems/rtems/timer.h, include/rtems/rtems/types.h,
inline/rtems/rtems/asr.inl, inline/rtems/rtems/attr.inl,
inline/rtems/rtems/dpmem.inl, inline/rtems/rtems/event.inl,
inline/rtems/rtems/eventset.inl, inline/rtems/rtems/message.inl,
inline/rtems/rtems/modes.inl, inline/rtems/rtems/options.inl,
inline/rtems/rtems/part.inl, inline/rtems/rtems/ratemon.inl,
inline/rtems/rtems/region.inl, inline/rtems/rtems/sem.inl,
inline/rtems/rtems/status.inl, inline/rtems/rtems/support.inl,
inline/rtems/rtems/tasks.inl, inline/rtems/rtems/timer.inl,
macros/rtems/rtems/asr.inl, macros/rtems/rtems/attr.inl,
macros/rtems/rtems/dpmem.inl, macros/rtems/rtems/event.inl,
macros/rtems/rtems/eventset.inl, macros/rtems/rtems/message.inl,
macros/rtems/rtems/modes.inl, macros/rtems/rtems/options.inl,
macros/rtems/rtems/part.inl, macros/rtems/rtems/ratemon.inl,
macros/rtems/rtems/region.inl, macros/rtems/rtems/sem.inl,
macros/rtems/rtems/status.inl, macros/rtems/rtems/support.inl,
macros/rtems/rtems/tasks.inl, macros/rtems/rtems/timer.inl,
src/attr.c, src/clockget.c, src/clockset.c, src/clocktick.c,
src/dpmem.c, src/dpmemcreate.c, src/dpmemdelete.c,
src/dpmemexternal2internal.c, src/dpmemident.c,
src/dpmeminternal2external.c, src/event.c, src/eventmp.c,
src/eventreceive.c, src/eventseize.c, src/eventsend.c,
src/eventsurrender.c, src/eventtimeout.c, src/intr.c, src/intrbody.c,
src/intrcatch.c, src/mp.c, src/msg.c, src/msgmp.c,
src/msgqallocate.c, src/msgqbroadcast.c, src/msgqcreate.c,
src/msgqdelete.c, src/msgqflush.c, src/msgqgetnumberpending.c,
src/msgqident.c, src/msgqreceive.c, src/msgqsend.c, src/msgqsubmit.c,
src/msgqtranslatereturncode.c, src/msgqurgent.c, src/part.c,
src/partcreate.c, src/partdelete.c, src/partgetbuffer.c,
src/partident.c, src/partmp.c, src/partreturnbuffer.c, src/ratemon.c,
src/ratemoncancel.c, src/ratemoncreate.c, src/ratemondelete.c,
src/ratemongetstatus.c, src/ratemonident.c, src/ratemonperiod.c,
src/ratemontimeout.c, src/region.c, src/regioncreate.c,
src/regiondelete.c, src/regionextend.c, src/regiongetinfo.c,
src/regiongetsegment.c, src/regiongetsegmentsize.c,
src/regionident.c, src/regionmp.c, src/regionreturnsegment.c,
src/rtclock.c, src/rtemsidtoname.c, src/rtemstimer.c, src/sem.c,
src/semcreate.c, src/semdelete.c, src/semflush.c, src/semident.c,
src/semmp.c, src/semobtain.c, src/semrelease.c,
src/semtranslatereturncode.c, src/signal.c, src/signalcatch.c,
src/signalmp.c, src/signalsend.c, src/taskcreate.c, src/taskdelete.c,
src/taskgetnote.c, src/taskident.c, src/taskinitusers.c,
src/taskissuspended.c, src/taskmode.c, src/taskmp.c,
src/taskrestart.c, src/taskresume.c, src/tasks.c, src/tasksetnote.c,
src/tasksetpriority.c, src/taskstart.c, src/tasksuspend.c,
src/taskvariableadd.c, src/taskvariabledelete.c,
src/taskvariableget.c, src/taskwakeafter.c, src/taskwakewhen.c,
src/timercancel.c, src/timercreate.c, src/timerdelete.c,
src/timerfireafter.c, src/timerfirewhen.c, src/timergetinfo.c,
src/timerident.c, src/timerreset.c, src/timerserver.c,
src/timerserverfireafter.c, src/timerserverfirewhen.c: URL for
license changed.
like signal dispatching.
