path: root/cpukit/rtems/include/rtems/rtems/regionmp.h (follow)
* posix support initially addedJoel Sherrill1995-09-261-3/+3
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-7/+8
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-4/+4
* fix broken RCS Ids -- $ accidentally lost merging changes earlierJoel Sherrill1995-08-221-1/+1
* bug fixes to make macro implementations workJoel Sherrill1995-08-161-2/+2
* Initial revisionJoel Sherrill1995-05-111-0/+165
