path: root/cpukit/rtems/include/rtems/rtems/msgmp.h (follow)
* posix support initially addedJoel Sherrill1995-09-261-4/+4
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-7/+7
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-2/+2
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-171-7/+7
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* Initial revisionJoel Sherrill1995-05-111-0/+175
