line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This is a preparation to remove the Giant lock.
Update #2555.
Rename _ISR_Disable() into _ISR_Local_disable(). Rename _ISR_Enable()
into _ISR_Local_enable(). Remove _Debug_Is_owner_of_giant().
Update #2555.
Rename _ISR_Disable_without_giant() into _ISR_Local_disable(). Rename
_ISR_Enable_without_giant() into _ISR_Local_enable().
Update #2555.
Update #2707.
Add rtems_interrupt_local_disable|enable() as suggested by Pavel Pisa to
emphasize that interrupts are only disabled on the current processor.
Do not define the rtems_interrupt_disable|enable|flash() macros and
functions on SMP configurations since they don't ensure system wide
mutual exclusion.
Update #2273.
Add a local context structure to the SMP lock API for acquire and
release pairs. This context can be used to store the ISR level and
profiling information. It may be later used to enable more
sophisticated lock algorithms, e.g. MCS locks.
There is only one lock that cannot be used with a local context. This
is the per-CPU lock since here we would have to transfer the local
context through a context switch which is very complicated.
ISR locks are low-level locks to protect critical sections accessed by
threads and interrupt service routines.
On single processor configurations the ISR locks degrade to simple ISR
disable/enable sequences. No additional storage or objects are
required.
This synchronization primitive is supported on SMP configurations. Here
SMP locks are used.
Interrupt locks are low-level lock to protect critical sections accessed
by threads and interrupt service routines.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8025203
In particular CPU_INTERRUPT_NUMBER_OF_VECTORS and
CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER are only used on
Simple Vectored Architectures, so do not depend on
them being defined. This disables as much as possible
that is specific to the Simple Vectored Model and
not expected to be used on architectures which use
the Programmable Interrupt Controller model for
interrupt handler vectoring.
* libcsupport/include/rtems/libio_.h,
libcsupport/src/fs_null_handlers.c: Null handlers are now const.
* libi2c/libi2c.c, libi2c/libi2c.h: Documentation. Do not create
semaphores on the fly.
* cpukit/libblock/src/bdpart.c: Fixed format specifier.
* cpukit/libblock/include/rtems/bdbuf.h, rtems/include/rtems.h,
rtems/include/rtems/rtems/asr.h, rtems/include/rtems/rtems/attr.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/barriermp.h,
rtems/include/rtems/rtems/cache.h, rtems/include/rtems/rtems/clock.h,
rtems/include/rtems/rtems/config.h, rtems/include/rtems/rtems/dpmem.h,
rtems/include/rtems/rtems/event.h,
rtems/include/rtems/rtems/eventmp.h,
rtems/include/rtems/rtems/eventset.h,
rtems/include/rtems/rtems/intr.h, rtems/include/rtems/rtems/message.h,
rtems/include/rtems/rtems/modes.h, rtems/include/rtems/rtems/mp.h,
rtems/include/rtems/rtems/msgmp.h, rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/part.h, rtems/include/rtems/rtems/partmp.h,
rtems/include/rtems/rtems/region.h,
rtems/include/rtems/rtems/regionmp.h,
rtems/include/rtems/rtems/rtemsapi.h, rtems/include/rtems/rtems/sem.h,
rtems/include/rtems/rtems/semmp.h, rtems/include/rtems/rtems/signal.h,
rtems/include/rtems/rtems/signalmp.h,
rtems/include/rtems/rtems/status.h,
rtems/include/rtems/rtems/support.h,
rtems/include/rtems/rtems/taskmp.h, rtems/include/rtems/rtems/tasks.h,
rtems/include/rtems/rtems/timer.h, rtems/include/rtems/rtems/types.h,
rtems/inline/rtems/rtems/support.inl: Documentation.
* include/rtems/irq-extension.h: Documentation. Added API for
interrupt servers.
* rtems/include/rtems/rtems/intr.h, rtems/src/intrcatch.c: Disable
rtems_interrupt_catch on targets which do not use the simple vectored
interrupt model.
* rtems/Makefile.am, rtems/include/rtems/rtems/attr.h,
rtems/include/rtems/rtems/dpmem.h, rtems/include/rtems/rtems/intr.h,
rtems/include/rtems/rtems/region.h, rtems/include/rtems/rtems/sem.h,
rtems/include/rtems/rtems/tasks.h, rtems/include/rtems/rtems/timer.h,
rtems/src/barrier.c, rtems/src/dpmem.c, rtems/src/msg.c,
rtems/src/part.c, rtems/src/ratemon.c, rtems/src/region.c,
rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/tasks.c,
sapi/src/rtemsapi.c: Convert manager initialization routines to
directly pull parameters from configuration table. Eliminate empty
routines sportted.
* rtems/src/intr.c: Removed.
(shared handler and handler with a handle).
* rtems/Doxyfile, rtems/include/rtems/rtems/asr.h,
rtems/include/rtems/rtems/dpmem.h, rtems/include/rtems/rtems/event.h,
rtems/include/rtems/rtems/options.h,
rtems/include/rtems/rtems/sem.h, rtems/include/rtems/rtems/semmp.h,
rtems/include/rtems/rtems/types.h, rtems/inline/rtems/rtems/asr.inl,
rtems/inline/rtems/rtems/attr.inl,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/dpmem.inl,
rtems/inline/rtems/rtems/event.inl,
rtems/inline/rtems/rtems/message.inl,
rtems/inline/rtems/rtems/modes.inl,
rtems/inline/rtems/rtems/options.inl,
rtems/inline/rtems/rtems/part.inl,
rtems/inline/rtems/rtems/ratemon.inl,
rtems/inline/rtems/rtems/region.inl,
rtems/inline/rtems/rtems/sem.inl,
rtems/inline/rtems/rtems/status.inl,
rtems/inline/rtems/rtems/support.inl,
rtems/inline/rtems/rtems/timer.inl: More Doxygen improvements.
* rtems/include/rtems.h, rtems/include/rtems/rtems/asr.h,
rtems/inline/rtems/rtems/eventset.inl,
rtems/inline/rtems/rtems/tasks.inl,
rtems/inline/rtems/rtems/timer.inl: Initial conversion of Classic API
header files to Doxygen.
* rtems/Doxyfile: New file.
rtems/include/rtems/rtems/types.h: Add doxygen preamble.
* include/rtems.h, include/rtems/rtems/asr.h,
include/rtems/rtems/attr.h, include/rtems/rtems/cache.h,
include/rtems/rtems/clock.h, include/rtems/rtems/config.h,
include/rtems/rtems/dpmem.h, include/rtems/rtems/event.h,
include/rtems/rtems/eventmp.h, include/rtems/rtems/eventset.h,
include/rtems/rtems/intr.h, include/rtems/rtems/message.h,
include/rtems/rtems/modes.h, include/rtems/rtems/mp.h,
include/rtems/rtems/msgmp.h, include/rtems/rtems/options.h,
include/rtems/rtems/part.h, include/rtems/rtems/partmp.h,
include/rtems/rtems/ratemon.h, include/rtems/rtems/region.h,
include/rtems/rtems/regionmp.h, include/rtems/rtems/rtemsapi.h,
include/rtems/rtems/sem.h, include/rtems/rtems/semmp.h,
include/rtems/rtems/signal.h, include/rtems/rtems/signalmp.h,
include/rtems/rtems/status.h, include/rtems/rtems/support.h,
include/rtems/rtems/taskmp.h, include/rtems/rtems/tasks.h,
include/rtems/rtems/timer.h, include/rtems/rtems/types.h,
inline/rtems/rtems/asr.inl, inline/rtems/rtems/attr.inl,
inline/rtems/rtems/dpmem.inl, inline/rtems/rtems/event.inl,
inline/rtems/rtems/eventset.inl, inline/rtems/rtems/message.inl,
inline/rtems/rtems/modes.inl, inline/rtems/rtems/options.inl,
inline/rtems/rtems/part.inl, inline/rtems/rtems/ratemon.inl,
inline/rtems/rtems/region.inl, inline/rtems/rtems/sem.inl,
inline/rtems/rtems/status.inl, inline/rtems/rtems/support.inl,
inline/rtems/rtems/tasks.inl, inline/rtems/rtems/timer.inl,
macros/rtems/rtems/asr.inl, macros/rtems/rtems/attr.inl,
macros/rtems/rtems/dpmem.inl, macros/rtems/rtems/event.inl,
macros/rtems/rtems/eventset.inl, macros/rtems/rtems/message.inl,
macros/rtems/rtems/modes.inl, macros/rtems/rtems/options.inl,
macros/rtems/rtems/part.inl, macros/rtems/rtems/ratemon.inl,
macros/rtems/rtems/region.inl, macros/rtems/rtems/sem.inl,
macros/rtems/rtems/status.inl, macros/rtems/rtems/support.inl,
macros/rtems/rtems/tasks.inl, macros/rtems/rtems/timer.inl,
src/attr.c, src/clockget.c, src/clockset.c, src/clocktick.c,
src/dpmem.c, src/dpmemcreate.c, src/dpmemdelete.c,
src/dpmemexternal2internal.c, src/dpmemident.c,
src/dpmeminternal2external.c, src/event.c, src/eventmp.c,
src/eventreceive.c, src/eventseize.c, src/eventsend.c,
src/eventsurrender.c, src/eventtimeout.c, src/intr.c, src/intrbody.c,
src/intrcatch.c, src/mp.c, src/msg.c, src/msgmp.c,
src/msgqallocate.c, src/msgqbroadcast.c, src/msgqcreate.c,
src/msgqdelete.c, src/msgqflush.c, src/msgqgetnumberpending.c,
src/msgqident.c, src/msgqreceive.c, src/msgqsend.c, src/msgqsubmit.c,
src/msgqtranslatereturncode.c, src/msgqurgent.c, src/part.c,
src/partcreate.c, src/partdelete.c, src/partgetbuffer.c,
src/partident.c, src/partmp.c, src/partreturnbuffer.c, src/ratemon.c,
src/ratemoncancel.c, src/ratemoncreate.c, src/ratemondelete.c,
src/ratemongetstatus.c, src/ratemonident.c, src/ratemonperiod.c,
src/ratemontimeout.c, src/region.c, src/regioncreate.c,
src/regiondelete.c, src/regionextend.c, src/regiongetinfo.c,
src/regiongetsegment.c, src/regiongetsegmentsize.c,
src/regionident.c, src/regionmp.c, src/regionreturnsegment.c,
src/rtclock.c, src/rtemsidtoname.c, src/rtemstimer.c, src/sem.c,
src/semcreate.c, src/semdelete.c, src/semflush.c, src/semident.c,
src/semmp.c, src/semobtain.c, src/semrelease.c,
src/semtranslatereturncode.c, src/signal.c, src/signalcatch.c,
src/signalmp.c, src/signalsend.c, src/taskcreate.c, src/taskdelete.c,
src/taskgetnote.c, src/taskident.c, src/taskinitusers.c,
src/taskissuspended.c, src/taskmode.c, src/taskmp.c,
src/taskrestart.c, src/taskresume.c, src/tasks.c, src/tasksetnote.c,
src/tasksetpriority.c, src/taskstart.c, src/tasksuspend.c,
src/taskvariableadd.c, src/taskvariabledelete.c,
src/taskvariableget.c, src/taskwakeafter.c, src/taskwakewhen.c,
src/timercancel.c, src/timercreate.c, src/timerdelete.c,
src/timerfireafter.c, src/timerfirewhen.c, src/timergetinfo.c,
src/timerident.c, src/timerreset.c, src/timerserver.c,
src/timerserverfireafter.c, src/timerserverfirewhen.c: URL for
license changed.
like signal dispatching.
