Add basic support for the Multiprocessor Resource Sharing Protocol
(MrsP).
The Multiprocessor Resource Sharing Protocol (MrsP) is defined in A.
Burns and A.J. Wellings, A Schedulability Compatible Multiprocessor
Resource Sharing Protocol - MrsP, Proceedings of the 25th Euromicro
Conference on Real-Time Systems (ECRTS 2013), July 2013. It is a
generalization of the Priority Ceiling Protocol to SMP systems. Each
MrsP semaphore uses a ceiling priority per scheduler instance. These
ceiling priorities can be specified with rtems_semaphore_set_priority().
A task obtaining or owning a MrsP semaphore will execute with the
ceiling priority for its scheduler instance as specified by the MrsP
semaphore object. Tasks waiting to get ownership of a MrsP semaphore
will not relinquish the processor voluntarily. In case the owner of a
MrsP semaphore gets preempted it can ask all tasks waiting for this
semaphore to help out and temporarily borrow the right to execute on one
of their assigned processors.
The help out feature is not implemented with this patch.
Move implementation specific parts of attr.h and attr.inl into new
header file attrimpl.h. The attr.h contains now only the application
visible API.
* libcsupport/include/rtems/libio_.h,
libcsupport/src/fs_null_handlers.c: Null handlers are now const.
* libi2c/libi2c.c, libi2c/libi2c.h: Documentation. Do not create
semaphores on the fly.
* cpukit/libblock/src/bdpart.c: Fixed format specifier.
* cpukit/libblock/include/rtems/bdbuf.h, rtems/include/rtems.h,
rtems/include/rtems/rtems/asr.h, rtems/include/rtems/rtems/attr.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/barriermp.h,
rtems/include/rtems/rtems/cache.h, rtems/include/rtems/rtems/clock.h,
rtems/include/rtems/rtems/config.h, rtems/include/rtems/rtems/dpmem.h,
rtems/include/rtems/rtems/event.h,
rtems/include/rtems/rtems/eventmp.h,
rtems/include/rtems/rtems/eventset.h,
rtems/include/rtems/rtems/intr.h, rtems/include/rtems/rtems/message.h,
rtems/include/rtems/rtems/modes.h, rtems/include/rtems/rtems/mp.h,
rtems/include/rtems/rtems/msgmp.h, rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/part.h, rtems/include/rtems/rtems/partmp.h,
rtems/include/rtems/rtems/region.h,
rtems/include/rtems/rtems/regionmp.h,
rtems/include/rtems/rtems/rtemsapi.h, rtems/include/rtems/rtems/sem.h,
rtems/include/rtems/rtems/semmp.h, rtems/include/rtems/rtems/signal.h,
rtems/include/rtems/rtems/signalmp.h,
rtems/include/rtems/rtems/status.h,
rtems/include/rtems/rtems/support.h,
rtems/include/rtems/rtems/taskmp.h, rtems/include/rtems/rtems/tasks.h,
rtems/include/rtems/rtems/timer.h, rtems/include/rtems/rtems/types.h,
rtems/inline/rtems/rtems/support.inl: Documentation.
* include/rtems/irq-extension.h: Documentation. Added API for
interrupt servers.
* rtems/Makefile.am, rtems/include/rtems/rtems/attr.h,
rtems/include/rtems/rtems/dpmem.h, rtems/include/rtems/rtems/intr.h,
rtems/include/rtems/rtems/region.h, rtems/include/rtems/rtems/sem.h,
rtems/include/rtems/rtems/tasks.h, rtems/include/rtems/rtems/timer.h,
rtems/src/barrier.c, rtems/src/dpmem.c, rtems/src/msg.c,
rtems/src/part.c, rtems/src/ratemon.c, rtems/src/region.c,
rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/tasks.c,
sapi/src/rtemsapi.c: Convert manager initialization routines to
directly pull parameters from configuration table. Eliminate empty
routines sportted.
* rtems/src/intr.c: Removed.
* libmisc/monitor/mon-prmisc.c, rtems/include/rtems/rtems/attr.h:
Review association tables in monitor.
* rtems/Doxyfile, rtems/include/rtems/rtems/asr.h,
rtems/include/rtems/rtems/dpmem.h, rtems/include/rtems/rtems/event.h,
rtems/include/rtems/rtems/options.h,
rtems/include/rtems/rtems/sem.h, rtems/include/rtems/rtems/semmp.h,
rtems/include/rtems/rtems/types.h, rtems/inline/rtems/rtems/asr.inl,
rtems/inline/rtems/rtems/attr.inl,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/dpmem.inl,
rtems/inline/rtems/rtems/event.inl,
rtems/inline/rtems/rtems/message.inl,
rtems/inline/rtems/rtems/modes.inl,
rtems/inline/rtems/rtems/options.inl,
rtems/inline/rtems/rtems/part.inl,
rtems/inline/rtems/rtems/ratemon.inl,
rtems/inline/rtems/rtems/region.inl,
rtems/inline/rtems/rtems/sem.inl,
rtems/inline/rtems/rtems/status.inl,
rtems/inline/rtems/rtems/support.inl,
rtems/inline/rtems/rtems/timer.inl: More Doxygen improvements.
* rtems/include/rtems.h, rtems/include/rtems/rtems/asr.h,
rtems/inline/rtems/rtems/eventset.inl,
rtems/inline/rtems/rtems/tasks.inl,
rtems/inline/rtems/rtems/timer.inl: Initial conversion of Classic API
header files to Doxygen.
* rtems/Doxyfile: New file.
* rtems/Makefile.am, rtems/preinstall.am, rtems/include/rtems.h,
rtems/include/rtems/rtems/attr.h, rtems/include/rtems/rtems/config.h,
rtems/inline/rtems/rtems/attr.inl, rtems/macros/rtems/rtems/attr.inl:
Add Classic API Barriers.
* rtems/include/rtems/rtems/barrier.h,
rtems/macros/rtems/rtems/barrier.inl, rtems/src/barrier.c,
rtems/src/barriercreate.c, rtems/src/barrierdelete.c,
rtems/src/barrierident.c, rtems/src/barrierrelease.c,
rtems/src/barriertranslatereturncode.c, rtems/src/barrierwait.c:
New files.
rtems/include/rtems/rtems/types.h: Add doxygen preamble.
rtems/macros/rtems/rtems/part.inl,
rtems/src/attr.c,
rtems/src/dpmem.c,
rtems/src/dpmemcreate.c,
rtems/src/dpmemexternal2internal.c,
rtems/src/dpmeminternal2external.c,
rtems/src/eventseize.c,
rtems/src/msg.c,
rtems/src/msgmp.c,
rtems/src/msgqallocate.c,
rtems/src/msgqbroadcast.c,
rtems/src/msgqcreate.c,
rtems/src/msgqflush.c,
rtems/src/msgqgetnumberpending.c,
rtems/src/msgqident.c,
rtems/src/msgqreceive.c,
rtems/src/msgqsend.c,
rtems/src/msgqsubmit.c,
rtems/src/msgqtranslatereturncode.c,
rtems/src/msgqurgent.c,
rtems/src/part.c,
rtems/src/partcreate.c,
rtems/src/partident.c,
rtems/src/partmp.c,
rtems/src/region.c,
rtems/src/regioncreate.c,
rtems/src/regionextend.c,
rtems/src/regiongetsegment.c,
rtems/src/regiongetsegmentsize.c,
rtems/src/regionmp.c,
rtems/src/regionreturnsegment.c,
rtems/src/sem.c,
rtems/src/semcreate.c,
rtems/src/semident.c,
rtems/src/semmp.c,
rtems/src/semobtain.c,
rtems/src/semtranslatereturncode.c,
rtems/src/taskcreate.c,
rtems/src/taskgetnote.c,
rtems/src/taskident.c,
rtems/src/taskinitusers.c,
rtems/src/taskmp.c,
rtems/src/taskrestart.c,
rtems/src/tasks.c,
rtems/src/tasksetnote.c,
rtems/src/taskstart.c,
rtems/src/timerserver.c: Convert to using c99 fixed size types.
* include/rtems.h, include/rtems/rtems/asr.h,
include/rtems/rtems/attr.h, include/rtems/rtems/cache.h,
include/rtems/rtems/clock.h, include/rtems/rtems/config.h,
include/rtems/rtems/dpmem.h, include/rtems/rtems/event.h,
include/rtems/rtems/eventmp.h, include/rtems/rtems/eventset.h,
include/rtems/rtems/intr.h, include/rtems/rtems/message.h,
include/rtems/rtems/modes.h, include/rtems/rtems/mp.h,
include/rtems/rtems/msgmp.h, include/rtems/rtems/options.h,
include/rtems/rtems/part.h, include/rtems/rtems/partmp.h,
include/rtems/rtems/ratemon.h, include/rtems/rtems/region.h,
include/rtems/rtems/regionmp.h, include/rtems/rtems/rtemsapi.h,
include/rtems/rtems/sem.h, include/rtems/rtems/semmp.h,
include/rtems/rtems/signal.h, include/rtems/rtems/signalmp.h,
include/rtems/rtems/status.h, include/rtems/rtems/support.h,
include/rtems/rtems/taskmp.h, include/rtems/rtems/tasks.h,
include/rtems/rtems/timer.h, include/rtems/rtems/types.h,
inline/rtems/rtems/asr.inl, inline/rtems/rtems/attr.inl,
inline/rtems/rtems/dpmem.inl, inline/rtems/rtems/event.inl,
inline/rtems/rtems/eventset.inl, inline/rtems/rtems/message.inl,
inline/rtems/rtems/modes.inl, inline/rtems/rtems/options.inl,
inline/rtems/rtems/part.inl, inline/rtems/rtems/ratemon.inl,
inline/rtems/rtems/region.inl, inline/rtems/rtems/sem.inl,
inline/rtems/rtems/status.inl, inline/rtems/rtems/support.inl,
inline/rtems/rtems/tasks.inl, inline/rtems/rtems/timer.inl,
macros/rtems/rtems/asr.inl, macros/rtems/rtems/attr.inl,
macros/rtems/rtems/dpmem.inl, macros/rtems/rtems/event.inl,
macros/rtems/rtems/eventset.inl, macros/rtems/rtems/message.inl,
macros/rtems/rtems/modes.inl, macros/rtems/rtems/options.inl,
macros/rtems/rtems/part.inl, macros/rtems/rtems/ratemon.inl,
macros/rtems/rtems/region.inl, macros/rtems/rtems/sem.inl,
macros/rtems/rtems/status.inl, macros/rtems/rtems/support.inl,
macros/rtems/rtems/tasks.inl, macros/rtems/rtems/timer.inl,
src/attr.c, src/clockget.c, src/clockset.c, src/clocktick.c,
src/dpmem.c, src/dpmemcreate.c, src/dpmemdelete.c,
src/dpmemexternal2internal.c, src/dpmemident.c,
src/dpmeminternal2external.c, src/event.c, src/eventmp.c,
src/eventreceive.c, src/eventseize.c, src/eventsend.c,
src/eventsurrender.c, src/eventtimeout.c, src/intr.c, src/intrbody.c,
src/intrcatch.c, src/mp.c, src/msg.c, src/msgmp.c,
src/msgqallocate.c, src/msgqbroadcast.c, src/msgqcreate.c,
src/msgqdelete.c, src/msgqflush.c, src/msgqgetnumberpending.c,
src/msgqident.c, src/msgqreceive.c, src/msgqsend.c, src/msgqsubmit.c,
src/msgqtranslatereturncode.c, src/msgqurgent.c, src/part.c,
src/partcreate.c, src/partdelete.c, src/partgetbuffer.c,
src/partident.c, src/partmp.c, src/partreturnbuffer.c, src/ratemon.c,
src/ratemoncancel.c, src/ratemoncreate.c, src/ratemondelete.c,
src/ratemongetstatus.c, src/ratemonident.c, src/ratemonperiod.c,
src/ratemontimeout.c, src/region.c, src/regioncreate.c,
src/regiondelete.c, src/regionextend.c, src/regiongetinfo.c,
src/regiongetsegment.c, src/regiongetsegmentsize.c,
src/regionident.c, src/regionmp.c, src/regionreturnsegment.c,
src/rtclock.c, src/rtemsidtoname.c, src/rtemstimer.c, src/sem.c,
src/semcreate.c, src/semdelete.c, src/semflush.c, src/semident.c,
src/semmp.c, src/semobtain.c, src/semrelease.c,
src/semtranslatereturncode.c, src/signal.c, src/signalcatch.c,
src/signalmp.c, src/signalsend.c, src/taskcreate.c, src/taskdelete.c,
src/taskgetnote.c, src/taskident.c, src/taskinitusers.c,
src/taskissuspended.c, src/taskmode.c, src/taskmp.c,
src/taskrestart.c, src/taskresume.c, src/tasks.c, src/tasksetnote.c,
src/tasksetpriority.c, src/taskstart.c, src/tasksuspend.c,
src/taskvariableadd.c, src/taskvariabledelete.c,
src/taskvariableget.c, src/taskwakeafter.c, src/taskwakewhen.c,
src/timercancel.c, src/timercreate.c, src/timerdelete.c,
src/timerfireafter.c, src/timerfirewhen.c, src/timergetinfo.c,
src/timerident.c, src/timerreset.c, src/timerserver.c,
src/timerserverfireafter.c, src/timerserverfirewhen.c: URL for
license changed.
and his EPICS porting effort.
via the user api.
software floating point emulation code. Code implemented by
Karen Sara Looney <Karen.Looney@colorado.edu> with much
email assistance from Joel.
like signal dispatching.
correct Information block.
