path: root/cpukit/preinstall.am (follow)
* 2011-03-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-03-141-0/+8
| | | | | | | | | | | PR 1762/cpukit * Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am: Add generic serial mouse driver and mouse parser. The parser code was in the pc386 BSP but was generic so cleaned up and placed here. Serial mouse driver itself is new. * libmisc/mouse/README, libmisc/mouse/mouse_parser.c, libmisc/mouse/mouse_parser.h, libmisc/mouse/serial_mouse.c, libmisc/mouse/serial_mouse.h: New files.
* Regenerate.Ralf Corsepius2011-02-091-0/+4
* 2010-08-13 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-08-131-0/+4
| | | | | | | | * libblock/include/rtems/media.h, libblock/src/media-desc.c, libblock/src/media-dev-ident.c, libblock/src/media-path.c, libblock/src/media-server.c, libblock/src/media.c: New files. * Makefile.am, preinstall.am, libblock/Makefile.am: Reflect changes above.
* 2010-06-14 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-06-141-0/+8
| | | | | PR 1555/cpukit * Makefile.am, preinstall.am: Install md4.h and md5.h headers.
* Regenerate.Ralf Corsepius2010-06-131-4/+0
* 2010-02-18 Chris Johns <chrisj@rtems.org>Chris Johns2010-02-181-0/+77
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * libfs/src/rfs/rtems-rfs-bitmaps.c, libfs/src/rfs/rtems-rfs-bitmaps.h, libfs/src/rfs/rtems-rfs-bitmaps-ut.c, libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-block.h, libfs/src/rfs/rtems-rfs-block-pos.h, libfs/src/rfs/rtems-rfs-buffer-bdbuf.c, libfs/src/rfs/rtems-rfs-buffer.c, libfs/src/rfs/rtems-rfs-buffer-devio.c, libfs/src/rfs/rtems-rfs-buffer.h, libfs/src/rfs/rtems-rfs-data.h, libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-dir.h, libfs/src/rfs/rtems-rfs-dir-hash.c, libfs/src/rfs/rtems-rfs-dir-hash.h, libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-file.h, libfs/src/rfs/rtems-rfs-file-system.c, libfs/src/rfs/rtems-rfs-file-system-fwd.h, libfs/src/rfs/rtems-rfs-file-system.h, libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-format.h, libfs/src/rfs/rtems-rfs-group.c, libfs/src/rfs/rtems-rfs-group.h, libfs/src/rfs/rtems-rfs.h, libfs/src/rfs/rtems-rfs-inode.c, libfs/src/rfs/rtems-rfs-inode.h, libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h, libfs/src/rfs/rtems-rfs-mutex.c, libfs/src/rfs/rtems-rfs-mutex.h, libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs-rtems-dev.c, libfs/src/rfs/rtems-rfs-rtems-dir.c, libfs/src/rfs/rtems-rfs-rtems-file.c, libfs/src/rfs/rtems-rfs-rtems.h, libfs/src/rfs/rtems-rfs-rtems-utils.c, libfs/src/rfs/rtems-rfs-shell.c, libfs/src/rfs/rtems-rfs-shell.h, libfs/src/rfs/rtems-rfs-trace.c, libfs/src/rfs/rtems-rfs-trace.h: New. * Makefile.am, preinstall.am, libfs/Makefile.am, wrapup/Makefile.am: Updated with the RFS support. * libfs/README: Updated after 10 years. * libblock/src/flashdisk.c, libblock/src/nvdisk.c, libblock/src/ramdisk-driver.c: Updated to the new error reporting in libblock. * libmisc/shell/main_ls.c, libmisc/shell/print-ls.c: Fix printing the size in long mode. * libnetworking/nfs/bootp_subr.c, libnetworking/rtems/rtems_bootp.c, libnetworking/rtems/rtems_bsdnet_internal.h: Return the BOOTP/DHCP to the forever behaviour of 4.9 with the ability to call BOOTP and control the process if required.
* Regenerate.Ralf Corsepius2009-10-141-2/+1
* 2009-10-08 Chris Johns <chrisj@rtems.org>Chris Johns2009-10-081-0/+4
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, preinstall.am: Added statvfs.h. * libcsupport/Makefile.am: Add statvfs.c. * libcsupport/include/sys/statvfs.h, libcsupport/src/statvfs.c: New. * libcsupport/include/rtems/libio.h: Add a file system handler for the statvfs call. * libfs/src/devfs/devfs_init.c, libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs_init.c, libfs/src/nfsclient/src/nfs.c: Set the statvfs handler to NULL. * include/rtems/fs.h: Add a second node access field for the RFS file system to hold a directory offset while the existing field holds the inode number. This save a rescan of the directory when working with directories. * libblock/include/rtems/bdbuf.h: Added references and user fields to the buffer descriptor. * libblock/src/bdbuf.c: Added dynamic buffer support for different block sizes. Fixed a number of bugs. * libblock/src/blkdev.c: Release the disk device on an error. * libblock/src/diskdevs.c: Set the block size to the media block size during initialisation of the disk device. * libblock/src/flashdisk.c, libblock/src/nvdisk.c, libblock/src/ramdisk.c: Updated the drivers to handle variable block sizes. * libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Release any buffers when an error occurs. The FAT buffer layer hangs onto a single buffer while mounted. This should be fixed. * sapi/inline/rtems/chain.inl: Added rtems_chain_set_off_chain, rtems_chain_is_node_off_chain, and rtems_chain_previous. * score/inline/rtems/score/chain.inl: Added _Chain_Set_off_chain, and _Chain_Is_node_off_chain. * libmisc/shell/main_ln.c, libmisc/shell/main_mknod.c, libmisc/shell/mknod-pack_dev.c, libmisc/shell/mknod-pack_dev.h: New shell commands. * libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added ln and mknod commands. * libmisc/shell/hexdump-display.c: Fixed the reopen bug which showed up as a free with a bad pointer. * libmisc/shell/main_mount.c: List the user adding file system when listing the available file systems to mount. * libmisc/shell/utils-cp.c: Remove the fixed static copy buffer and use a large dynamic buffer. * score/inline/rtems/score/address.inl, score/src/coremsgsubmit.c, score/src/objectallocate.c, score/src/objectfree.c: Remove warnings.
* 2009-08-21 Roxana Leontie <roxana.leontie@gmail.com>Joel Sherrill2009-08-211-2/+2
| | | | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am: Changed the name of mw-fb directory into fb. Relocated files. * libmisc/fb/fb.h, libmisc/fb/mw_uid.c, libmisc/fb/mw_uid.h: New files. * libmisc/mw-fb/fb.h, libmisc/mw-fb/mw_uid.c, libmisc/mw-fb/mw_uid.h: Removed.
* 2009-08-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-051-0/+4
| | | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am: Add new BSP Boot Command Line helper routines. Recently boot_card() has grown the ability to have a command line string pointer. These routines provide an interface to that string.
* 2009-08-03 Roxana Leontie <roxana.leontie@gmail.com>Joel Sherrill2009-08-031-3/+3
| | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am: changed the references to mw_fb.h into fb.h * libmisc/mw-fb/mw_fb.h: renamed fb.h
* 2009-07-22 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-07-221-0/+4
| | | | | | | | | | | | | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am: Add the stringto family of string to number converters. These are error checking wrappers for the strtoXXX methods and do their best to return false if the conversion failed. The error checking required for this is tedious and error prone. Hence better to have in a family of helper routines. * libmisc/stringto/stringto.h, libmisc/stringto/stringto_template.h, libmisc/stringto/stringtodouble.c, libmisc/stringto/stringtofloat.c, libmisc/stringto/stringtoint.c, libmisc/stringto/stringtolong.c, libmisc/stringto/stringtolonglong.c, libmisc/stringto/stringtounsignedchar.c, libmisc/stringto/stringtounsignedint.c, libmisc/stringto/stringtounsignedlong.c, libmisc/stringto/stringtounsignedlonglong.c: New files.
* UpdateThomas Doerfler2009-05-051-0/+13
* removed obsolete references to login.hThomas Doerfler2009-04-141-4/+0
* 2009-03-27 Sebastian Huber <sebastian.huber@embedded-brains.de>Joel Sherrill2009-03-271-0/+4
| | | | | | | | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am, libmisc/shell/shell.c, libmisc/shell/shell.h, telnetd/check_passwd.c, telnetd/telnetd.c, telnetd/telnetd.h: Generalized login check. * libmisc/shell/login.h, libmisc/shell/login_check.c, libmisc/shell/login_prompt.c: New files. * libmisc/stackchk/check.c: Changed format for blown stack message. * libcsupport/src/libio_sockets.c: Removed superfluous cast. * libnetworking/rtems/ftpfs.h: Documentation.
* Regenerate.Ralf Corsepius2009-02-201-0/+4
* Regenerate.Ralf Corsepius2009-02-061-4/+0
* Regenerate.Ralf Corsepius2009-01-051-0/+4
* Regenerate.Ralf Corsepius2008-12-171-4/+0
* 2008-10-14 Wei Shen <cquark@gmail.com>Joel Sherrill2008-10-141-0/+4
| | | | | | | | | | | | * Makefile.am, preinstall.am, libcsupport/src/mknod.c, libcsupport/src/open.c, libcsupport/src/pipe.c, libfs/Makefile.am, libfs/preinstall.am, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_creat.c, libfs/src/imfs/imfs_debug.c, libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_initsupp.c, libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/imfs_stat.c, libfs/src/imfs/memfile.c: Initial commit of POSIX pipe support. * libfs/src/imfs/imfs_fifo.c, libfs/src/pipe/fifo.c, libfs/src/pipe/pipe.c, libfs/src/pipe/pipe.h: New files.
* 2008-09-17 Miao Yan <yanmiaobest@gmail.com>Joel Sherrill2008-09-171-0/+4
| | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, preinstall.am, libcsupport/Makefile.am, libcsupport/include/rtems/libcsupport.h, libcsupport/include/rtems/libio.h, libcsupport/src/base_fs.c, libcsupport/src/libio_init.c, libcsupport/src/newlibc_exit.c, libcsupport/src/newlibc_init.c, libcsupport/src/sync.c, libfs/Makefile.am, libfs/src/imfs/deviceio.c, sapi/include/confdefs.h: Merge GSOC project code to add simple device only filesystem (devfs), optionally completely drop out filesystem, and to clean up disabling newlib reentrancy support. This dropped 17K from the minimum.exe for sparc/sis and arm/rtl22xx_t now has a 15K code space. * libcsupport/src/__usrenv.c, libcsupport/src/newlibc_reent.c, libfs/src/devfs/devclose.c, libfs/src/devfs/devfs.h, libfs/src/devfs/devfs_eval.c, libfs/src/devfs/devfs_init.c, libfs/src/devfs/devfs_mknod.c, libfs/src/devfs/devfs_node_type.c, libfs/src/devfs/devfs_show.c, libfs/src/devfs/devioctl.c, libfs/src/devfs/devopen.c, libfs/src/devfs/devread.c, libfs/src/devfs/devstat.c, libfs/src/devfs/devwrite.c, libfs/src/imfs/deviceerrno.c: New files. * libcsupport/src/newlibc.c: Removed.
* added haleakala BSP contributed by Michael HamelThomas Doerfler2008-07-141-0/+8
* 2008-05-01 Chris Johns <chrisj@rtems.org>Chris Johns2008-05-011-0/+8
| | | | | | | | | * libblock/include/rtems/nvdisk-sram.h, libblock/include/rtems/nvdisk.h, libblock/src/nvdisk-sram.c, libblock/src/nvdisk.c: New. A Non-volatile memory disk drive. * Makefile.am, preinstall.am, libblock/Makefile.am: Updated for the NV disk driver.
* 2007-12-12 Chris Johns <chrisj@rtems.org>Chris Johns2007-12-141-1/+4
| | | | | | | | * Makefile.am, preinstall.am: Added libblock/include/rtems/flashdisk.h to the installed header list. * libblock/Makefile.am: Add flashdisk.c to the files to build. * libblock/include/rtems/flashdisk.h, libblock/src/flashdisk.c: New.
* 2007-12-10 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-12-101-0/+5
| | | | | | | | | | | | | | | | | | | | | | | | | * ChangeLog, preinstall.am, libmisc/Makefile.am, libmisc/shell/cmds.c, libmisc/shell/shell.c, libmisc/shell/shell.h: Split shell commands into multiple files and add initial stages of command configuration. This seems to work but the monitor commands need to be integrated this way and the ability to configure user commands needs to be tested. * libmisc/shell/cat_file.c, libmisc/shell/cmd_alias.c, libmisc/shell/cmd_cat.c, libmisc/shell/cmd_cd.c, libmisc/shell/cmd_chdir.c, libmisc/shell/cmd_chmod.c, libmisc/shell/cmd_chroot.c, libmisc/shell/cmd_date.c, libmisc/shell/cmd_dir.c, libmisc/shell/cmd_exit.c, libmisc/shell/cmd_help.c, libmisc/shell/cmd_id.c, libmisc/shell/cmd_logoff.c, libmisc/shell/cmd_ls.c, libmisc/shell/cmd_mallocdump.c, libmisc/shell/cmd_mdump.c, libmisc/shell/cmd_medit.c, libmisc/shell/cmd_mfill.c, libmisc/shell/cmd_mkdir.c, libmisc/shell/cmd_mmove.c, libmisc/shell/cmd_mwdump.c, libmisc/shell/cmd_pwd.c, libmisc/shell/cmd_rm.c, libmisc/shell/cmd_rmdir.c, libmisc/shell/cmd_tty.c, libmisc/shell/cmd_umask.c, libmisc/shell/cmd_whoami.c, libmisc/shell/internal.h, libmisc/shell/shellconfig.c, libmisc/shell/shellconfig.h, libmisc/shell/str2int.c: New files.
* Regenerate.Ralf Corsepius2007-06-121-1/+0
* 2007-05-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-05-151-3/+0
| | | | | | | | | | | | | | | | | | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am, rtems/Makefile.am, rtems/include/rtems.h, rtems/include/rtems/rtems/ratemon.h, rtems/inline/rtems/rtems/ratemon.inl, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemontimeout.c, score/Makefile.am, score/include/rtems/score/object.h, score/src/threadhandler.c, wrapup/Makefile.am: Integrate Rate Monotonic Statistics and Period Usage into Rate Monotonic Manager. Added the following directives: rtems_rate_monotonic_get_statistics, rtems_rate_monotonic_reset_statistics, rtems_rate_montonic_reset_all_statistics, rtems_rate_montonic_report_statistics, and rtems_object_get_name. Obsoleted the rtems/rtmonuse.h file as a public interface. * rtems/src/ratemongetstatistics.c, rtems/src/ratemonreportstatistics.c, rtems/src/ratemonresetall.c, rtems/src/ratemonresetstatistics.c, rtems/src/rtemsobjectgetname.c, score/src/objectgetnameasstring.c: New files. * libmisc/rtmonuse/rtmonuse.c, libmisc/rtmonuse/rtmonuse.h: Removed.
* Regenerate.Ralf Corsepius2007-05-101-4/+0
* Regenerate.Ralf Corsepius2007-05-101-0/+4
* Regenerate.Ralf Corsepius2007-05-101-0/+9
* Regenerate.Ralf Corsepius2007-05-091-0/+4
* Regenerate.Ralf Corsepius2007-01-081-5/+5
* Regenerate.Ralf Corsepius2006-12-131-103/+0
* Regenerate.Ralf Corsepius2006-11-181-3/+3
* Regenerate.Ralf Corsepius2006-11-171-3/+3
* Regenerate.Ralf Corsepius2006-11-121-10/+0
* Regenerate.Ralf Corsepius2006-01-141-1/+15
* Regenerate.Ralf Corsepius2005-08-051-0/+4
* Regenerate.Ralf Corsepius2005-05-241-4/+4
* 2005-05-17 Jennifer Averett <jennifer.averett@oarcorp.com>Jennifer Averett2005-05-171-0/+4
| | | | | * Makefile.am, preinstall.am: Added a common irq.h * include/rtems/irq.h: New file.
* Regenerate.Ralf Corsepius2005-05-091-0/+15
* Regenerate.Ralf Corsepius2005-03-041-2/+4
* Auto-generated update.Ralf Corsepius2005-02-191-1/+1
* New.Ralf Corsepius2005-02-081-0/+306
