* libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h,
libblock/src/nvdisk-sram.c,
libblock/src/nvdisk.c: New. A Non-volatile memory disk drive.
* Makefile.am, preinstall.am, libblock/Makefile.am: Updated for
the NV disk driver.
* Makefile.am, preinstall.am: Added
libblock/include/rtems/flashdisk.h to the installed header list.
* libblock/Makefile.am: Add flashdisk.c to the files to build.
* libblock/include/rtems/flashdisk.h, libblock/src/flashdisk.c:
New.
* ChangeLog, preinstall.am, libmisc/Makefile.am, libmisc/shell/cmds.c,
libmisc/shell/shell.c, libmisc/shell/shell.h: Split shell commands
into multiple files and add initial stages of command configuration.
This seems to work but the monitor commands need to be integrated
this way and the ability to configure user commands needs to be
tested.
* libmisc/shell/cat_file.c, libmisc/shell/cmd_alias.c,
libmisc/shell/cmd_cat.c, libmisc/shell/cmd_cd.c,
libmisc/shell/cmd_chdir.c, libmisc/shell/cmd_chmod.c,
libmisc/shell/cmd_chroot.c, libmisc/shell/cmd_date.c,
libmisc/shell/cmd_dir.c, libmisc/shell/cmd_exit.c,
libmisc/shell/cmd_help.c, libmisc/shell/cmd_id.c,
libmisc/shell/cmd_logoff.c, libmisc/shell/cmd_ls.c,
libmisc/shell/cmd_mallocdump.c, libmisc/shell/cmd_mdump.c,
libmisc/shell/cmd_medit.c, libmisc/shell/cmd_mfill.c,
libmisc/shell/cmd_mkdir.c, libmisc/shell/cmd_mmove.c,
libmisc/shell/cmd_mwdump.c, libmisc/shell/cmd_pwd.c,
libmisc/shell/cmd_rm.c, libmisc/shell/cmd_rmdir.c,
libmisc/shell/cmd_tty.c, libmisc/shell/cmd_umask.c,
libmisc/shell/cmd_whoami.c, libmisc/shell/internal.h,
libmisc/shell/shellconfig.c, libmisc/shell/shellconfig.h,
libmisc/shell/str2int.c: New files.
* Makefile.am, preinstall.am, libmisc/Makefile.am, rtems/Makefile.am,
rtems/include/rtems.h, rtems/include/rtems/rtems/ratemon.h,
rtems/inline/rtems/rtems/ratemon.inl, rtems/src/ratemoncancel.c,
rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c,
rtems/src/ratemonperiod.c, rtems/src/ratemontimeout.c,
score/Makefile.am, score/include/rtems/score/object.h,
score/src/threadhandler.c, wrapup/Makefile.am: Integrate Rate
Monotonic Statistics and Period Usage into Rate Monotonic Manager.
Added the following directives: rtems_rate_monotonic_get_statistics,
rtems_rate_monotonic_reset_statistics,
rtems_rate_montonic_reset_all_statistics,
rtems_rate_montonic_report_statistics, and rtems_object_get_name.
Obsoleted the rtems/rtmonuse.h file as a public interface.
* rtems/src/ratemongetstatistics.c,
rtems/src/ratemonreportstatistics.c, rtems/src/ratemonresetall.c,
rtems/src/ratemonresetstatistics.c, rtems/src/rtemsobjectgetname.c,
score/src/objectgetnameasstring.c: New files.
* libmisc/rtmonuse/rtmonuse.c, libmisc/rtmonuse/rtmonuse.h: Removed.
* Makefile.am, preinstall.am: Added a common irq.h
* include/rtems/irq.h: New file.
